Old 01-09-2005, 10:17 PM   #6361
Entropy's Avatar
Originally posted by SchuMi2
Randy...If you look at one of the close up pictures you will notice Marc has spaced his servo forward giving you the impression that his batteries are further forward. It allows a little more room for the radio gear. I have done the same thing except I used Yokomo SD servo mounts(blue as well)
Don't forget he uses the Futaba 9550 servo which is slimmer than standard servos. That alone will free up more space than the 2-3 mm spacers he used on his servo mounts.
Entropy is offline   Reply With Quote
Old 01-09-2005, 11:11 PM   #6362
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I use all the same electronics as Marc, so I have the same amount of free space, it definately helps to have everything compact on this chassis, keep the ESC right off the motor so it isnt getting all the heat transfered.
Old 01-09-2005, 11:33 PM   #6363
SpeedTech's Avatar
Default Re: Diff. Ball Size
Originally posted by RC Professor
Can anybody tell me the size of the diff. balls for the 415? I'm looking to upgrade to ceramic and need to know the size. Thanks.
RC Professor,
3mm ceramic diff balls for the 415 are available from Xenon Racing Japan as well.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-09-2005, 11:47 PM   #6364
Steve, thank you for trading out the knuckles for me, got them from Patrick, look good
Old 01-10-2005, 01:05 AM   #6365
JimmyMac's Avatar
Just thought I'd post a pic of my 415 setup for carpet...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-10-2005, 03:58 AM   #6366
TryHard's Avatar
Default Shock shafts
Does anyone know if the Alex Racing shock shafts marc was using at the worlds are any longer than the std 415 ones?
It's just i find that to get the required shock length's (62mm F and 62.5mm r) for the droop i run, I have to unscrew the ball end... something I'm not too hot on doing. Just wondered if anyone has any experience with these?
Thanks in advance
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-10-2005, 04:14 AM   #6367
Eirik's Avatar
Default Shock Shaft's
I just use Yokomo ones, they are about 1.5mm longer....
Works really great!!
Eirik is offline   Reply With Quote
Old 01-10-2005, 08:11 AM   #6368
Has anyone done some serious testing themselves to prove that either of the suspension systems is better than the other??
I have had the chance to compare the two a few times now and I think the difference is almost nothing on the track.
I think the LW gives better stability and mid corner steering.
I think the standard is more responsive and more reliable.
Wat are your thoughts?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-10-2005, 08:49 AM   #6369
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Can anyone tell me the part # for the blue upper shock mounts? I wanna put the TRF shocks on my Xray and can't seem to find the right mount. Thanks.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-10-2005, 10:40 AM   #6370
53640 Should be what you need David.
Old 01-10-2005, 10:42 AM   #6371
PMR
Post
Tried the MS kit for the very first time on a tight outdoor asphalt track with standard settings and I'm a bit hmmmmmm......lets just say I expected to much. The lap times where about the same as my Pro4 which is good, considering I had the pro4 for almost a year but after 6 runs the diffs and the rear 950 bearings became gritty which is not good at all considering it is still Bnew. In fairness to Ms kit I still have to give more time and try new set ups. Any of you guys have a good set up to try. By the way my car tends to push using the std. set up. Hope you guys can help me.
PMR is offline   Reply With Quote
Old 01-10-2005, 10:44 AM   #6372
Thank you sir, thats what I needed. Hows the new car working for ya?
Old 01-10-2005, 10:45 AM   #6373
Hi guys...
Wat is the difference between shock towers on the standard 415 and the MS?
can someone post a pic of them side by side? (front vs frontMS, rear vs rearMS)
Part No. 50985 is a 4degree c-hub for the standard suspension. I belive there was another outhere. I'm sure I had a 6degree when I had my 04R. Anyone know wat the castor was and the part number?
Thanx....
Powered by Falco
Old 01-10-2005, 10:51 AM   #6374
If you are running on a high bite track, try my setup on TryHards website.
Old 01-10-2005, 10:52 AM   #6375
The MS is dialed, couldnt ask for much more out of it, everything I try just seems to make it better though.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
