Old 01-08-2005, 03:53 PM   #6331
TC3
TC3's Avatar
very nice pics, thx for sharing
TC3 is offline   Reply With Quote
Old 01-08-2005, 04:32 PM   #6332
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by John Doucakis
I can confirm the following:
During the whole event Marc's car was fitted with:
1. Alu. spool up front with derlin outdrives. You cannot find it anywhere...
2. HPI rear uprights (not TAMIYA aluminum)
3. HPI silver springs
4. Non Tamiya sway bars
for the sway bars it would have to be ALEX Racing or..AE TC3 sway bars... most of the Tamiya guys were running them at the Japanese Nationals
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-08-2005, 04:58 PM   #6333
TRF415boy's Avatar
First time out with the car tonight, at last. only 4 runs but I'm well impressed with the car so far, I've put Marc's LRP TCM setup (carpet with rubber) and the car was just spot on, I just had to get used to the car and track. Ended up 3rd but I was only lacking power, need new cells and to get some pinions to gear the car up properly.
TRF415boy is offline   Reply With Quote
Old 01-08-2005, 10:39 PM   #6334
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Originally posted by Randy Caster
are his batteries more forward than the normal chassis would be?
Randy...If you look at one of the close up pictures you will notice Marc has spaced his servo forward giving you the impression that his batteries are further forward. It allows a little more room for the radio gear. I have done the same thing except I used Yokomo SD servo mounts(blue as well)
SchuMi2 is offline   Reply With Quote
Old 01-08-2005, 10:45 PM   #6335
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by s2
on the pictures of Marc's car there is, i guess 4mm of spacing on the steering rack under the ball-end, using this as a tuning option is somthing ive never tried mainly because i dont really know what the effects of changing this spacing are, what are they?
thanks
That would take out steering putting the spacers on the steering rack, putting them under the ballstuds on the spindles would give more steering.
I dont think he was taking out steering there, I think he was spacing them back up to stock, the bellcranks look really low there, propably took out the shims from under the bellcranks and put them on top.
Old 01-08-2005, 10:46 PM   #6336
I guess I havent seen a pic of the 415 3mm chassis in a while, but the front battery slot just looked far forward, I guess it was just me though.
Old 01-08-2005, 11:53 PM   #6337
JimmyMac's Avatar
Just ran some carpet/foams with the 415. Car ran pretty good. Did some testing with Parma vs Jaco. To me.. I found that Parma tires (Cyan/Magenta) offer more steering and traction than Jaco tires (DblPink/Orange and DblPink). But the Jaco's felt more consistant throughout the run. The Parma's might of had a bit too much traction to the point of traction rolling... or almost.
Also, didn't quite like the softer spring setup (AE copper/gold vs yellow/copper). Seemed like the softer setup made the car roll too much. I dunno... I'll test it out more next weekend. This weekend was a bit too hectic since I had to work and got to the track too late for more testing.
Anyways, gonna try out more stuff next weekend... til then, here's my current 19t setup for carpet with foams.
Jimmy Mac
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-09-2005, 12:25 AM   #6338
Trader Rating: 74 (100%+)
Default carpet setup
Well,
After a night of practice, and no broken parts this is what I came up with.
First, front:
2 hole, 40 wt 25lb spring
droop 5 on hudy
no sway
1mm spacer behind wheels 4mm hex
dual oneways
standard suspension, 1mm spacer in rear of arm, and 2mm anti dive.
shocks one hole in on tower
-1.5 neg camber
A bridge, frt a block
cyan tires glued outside edge
Rear:
2 hole 40 wt 27.5lb spring
droop 6 hudy
no sway
standard suspension, 1mm spacer in frt of arm, no riser
shock one hole in on tower
-2 neg camber
a block frt and rear.
1 degree alloy hubs
wht belts.
Parma Alfa was body of choice, but tried the Tamiya Subuaru, not as consistent as the Parma.
Genesis Binary ROAR stock 102/28---fast..
I may try a little different stuff real soon.....
Randy, or some one else, can you please tell me if there is a height difference of shock towers on the 415, to the MS? It looks like the frt tower is a little lower on the MS???? Where can I get it if so?
Reinhardt gave me some ideas....
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-09-2005, 12:28 AM   #6339
Default editable setup sheet
Kilruf how do I get a blank editable setup to post like you have???? I want to be cool, PLEASE?
Old 01-09-2005, 12:50 AM   #6340
JimmyMac's Avatar
Raul, it's actually the blank PDF file off of the Tamiya Japan website. I just opened it up in Photoshop and tossed in my own info. Then resized it down and saved it as a GIF file for up loading on the net. Makes it easier to read I think.
Also, not sure, but I thought that the front tower on the MS was actually taller than the Regular 415. But the rear tower is lower on the MS due to the "lower" body mounts. I might be mistaken about the front though...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 01-09-2005, 10:01 AM   #6341
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Goon: Did George change the track and what type of lap times are you taking about? No racing for me this weekend. I had a big poker game at my apartment on Friday night, which had me up till 5am. Still cleaning the mess.....LOL
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-09-2005, 10:45 AM   #6342
Default Diff. which to those
Should I buy the diff from Tamiya (51058+50880+51055) to rear end of my Trf 415 or is there anything better for it, and the balls to put in it, what about them, I have heard that the Tamiya balls are not the best.
racerkorer is offline   Reply With Quote
Old 01-09-2005, 10:47 AM   #6343
Default HC
Carl,
HC did put up a new layout, it has changed a little from the first posted pics, but still very fast....We did not have the jlap running yesterday, it was open practice. The car was good, but needs a little refinement. Take a look at the setup. SO this poker game is where you get all your money, or was it a STRIP POKEHER night? Call me.
Old 01-09-2005, 10:48 AM   #6344
dawgmeat's Avatar
Default 415 vs 415ms parts
does the Ms shock towers and bulkheads sit lower than the stock towers and bulkhead.
dawgmeat is offline   Reply With Quote
Old 01-09-2005, 11:14 AM   #6345
Send a message via ICQ to Jan Larsen
bulkheads are the same, but the towers are lower. just a little, but it allows you to slam the body just that bit more.
Jan Larsen is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
