Old 12-24-2004, 10:31 AM   #5881
forty6's Avatar
Originally posted by rayhuang
Theres got to be smeone who makes a lt. weight universal shaft that will work instead of the steel F201 universals right?
Wow-the $470 415ms is starting to edge towards a $550++ 415. But-I suppose Ive got that much tied into one of my Xrays.
Ray,
Most people use the regular 415 for carpet since it has the stiffer chassis and more durable suspension bits than the MS. It is also about $100 cheaper than the MS too. So if you go with the non-MS 415, the parts in my sig will work just fine.
forty6 is offline   Reply With Quote
Old 12-24-2004, 10:39 AM   #5882
rayhuang's Avatar
Originally posted by forty6
Ray,
Thanks SO much. Good to know I dont need to et the MS version.
I am hearing totally conflicting reports about it on foam tires. One guy says fine-another says-28mm will hit 2 or 3 parts of the front suspension. I know the camber link ball cup will hit the inside of the rim (my EvoIII did that). But what concerns me is if the rim hits the steering blocks or the spring perches-then you have to mount the shocks more inboard-which screws with the intended wheelrates. Then car might handle right-maybe not.
I am on a fact finding mission!! Can you tell? if this doesnt wotrk out-I might buy a TB02 and race GT2 and maybe see if I can run GT1 with it too at a Regional TCS event. My ultimate goal for this spring.
Old 12-24-2004, 10:49 AM   #5883
forty6's Avatar
There are several guys here that regularly use the 415 with foamies on carpet. They can provide you with more insight.
Old 12-24-2004, 11:03 AM   #5884
rayhuang's Avatar
Thanks forty6. All but one part to build the diff is in stock at SpeedtechRC!!! Not too shabby!! The only missing part is a diff adjusting kit.
Ray
Old 12-24-2004, 11:19 AM   #5885
Trader Rating: 14 (100%+)
Ray:
changing cars again??? just when I thought you had found one you like. sorry about the other day. no internet was using my phone to surf. the GTX is gone I traded it for a KO speedo. Mini wanted it for the 1.12th scale. I sent out the other package out already.
call me whenever.
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 12-24-2004, 11:20 AM   #5886
rayhuang's Avatar
Originally posted by TimXLB
Ray:
call me whenever.
yeah-I am pretty pathetic-arent I?? Its the wnter blahs-I think. need a new toy!! I got a ton to talk to you about-I am at work.
Old 12-24-2004, 11:20 AM   #5887
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Put one on preorder at Speedtech, $470 with titanium screws.
Old 12-24-2004, 11:23 AM   #5888
I'm pretty well known for switching cars, but I think I can say the MS will be my car through 05 (or at least for the next 3 months before they come out with a new version of it)
Old 12-24-2004, 11:26 AM   #5889
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
It is fun switching cars but sometimes it slows me down a tad as I'm always working on new setups and I never have a car long enough to really get her dialed in the way I would like on many different tracks.
I feel like you do. I'm staying with my EVO IV til another version comes out. I just like shaft cars plus I can use a standard diff for my car and I will be running some TCS races with it so I need to keep it all Tamiya.
ST Racing Concepts (STRC)
Old 12-24-2004, 01:02 PM   #5890
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally posted by Hebiki
were you jeff lin's friend by chance?
Yeah, that was me. I take it you were the Chris who helped me out with gearing? Thanks! It was a lot better.
Racing4Evo is offline   Reply With Quote
Old 12-24-2004, 01:09 PM   #5891
Trader Rating: 74 (100%+)
Default rubbing points
Ray,
The only places we have had consistent problems is with the upper kingpin- the stock one will never clear without machining, so we use EVO IV upper kingpin's. No mor rubbing. THe next spot is the lower swaybar mount. I was thinking of flipping the arms over on moving the mount to the inner shock hole, since I only use one position for my shocks on the arm(outer). I am using the 1mm spacer, with 4mm hexes, and TM wheels 28 mm frt and rear. These are the only problems we have. The EVO IV frt knuckles rub with wheels wider than 25mm, and need modifications, the 415 frt knuckles have a more sweeped arm. Which is nice. I hope this helps, we have a major race happening on the 2nd, I will give more insight then... Happy holidays to all...
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 12-24-2004, 01:17 PM   #5892
Default driveshafts
Ray, I have been toiying with making up a CVD style driveshaft instead of the the internal driveshafts. I have old Schumacher Mi2 stub axles, and I am in the hunt for shafts that fit the cups, Schuies are to large. Maybe Associated shafts, they definitely fit Schuie's stubs. I just have to test some stuff. I will keep you posted. Everyone makes alloy CDV wannabee's I just have to find the right one..
Old 12-24-2004, 05:51 PM   #5893
For those TCS races that are too tight for a 1 way, I didnt see anything in the rulebook about lubricating my 1 way with JB weld
Old 12-24-2004, 05:53 PM   #5894
Default Re: driveshafts
I actually find that the stock CVA's seem to last a lot longer than a CVD style driveshaft. With my Losi I was replacing the dogbone after every raceday.
Old 12-24-2004, 05:54 PM   #5895
Hebiki's Avatar
Trader Rating: 26 (100%+)
hey dude... whats up? yah that was me. talk to jeff.. he can hook you up with some good motors. or you can try the EA Motorsports monster stock. thats the one i was using and same with Robert Morris.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
