Old 12-23-2004, 11:33 PM   #5866
forty6's Avatar
haha, thanks!
forty6 is offline   Reply With Quote
Old 12-23-2004, 11:37 PM   #5867
forty6's Avatar
Originally posted by wyd
That is a great sig. It will help out alot of the 415 guys!!!!!!
Thanks, hopefully it will reduce the frequency of this question being asked over and over.
Old 12-23-2004, 11:41 PM   #5868
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the only reason i suggested the F201 bones is cause the LW suspension already uses the 46mm ones, so the shorter Yoke diff may require an even longer bone on the MS/LW suspension....
the reason for the longer bones is (of course) because the total overall width of the diff assy with Yoke/TRF parts is slightly narrower than the oneway. and yes, the Tamiya rings with the double flats work just fine on the Yoke drives. should be from the TA04/414/415 diffs...
i put the reg back on mine after TCS Nats, so i didnt get a chance to try that one out.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 12-23-2004, 11:43 PM   #5869
FW-05RR's Avatar
FW-05RR is offline   Reply With Quote
Old 12-24-2004, 12:36 AM   #5870
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I havent tried to run my front diff yet, basically just have it for rare carpet occasions so I dont know if the driveshafts are too short or the right length...
Old 12-24-2004, 12:58 AM   #5871
BKK
I use the bones from an F201 too. I found out that the 46mm ones pop out sometimes with the YOKOMO(when I turn)diff in the front.
BKK is offline   Reply With Quote
Old 12-24-2004, 01:10 AM   #5872
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by Racing4Evo
Were you there this past Tuesday? I was racing for the first time that day. My car has a total of 20min of use. I really like how I was able to forget about the car enough to actually learn the track. I'm hoping to do well at the next race granted I receive some batteries and a suitable motor(was running a brand new MVP).
were you jeff lin's friend by chance?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-24-2004, 03:41 AM   #5873
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
does the 415MS already have the aluminum rear hubs or do i still have to buy them seperately
buboy28 is offline   Reply With Quote
Old 12-24-2004, 04:07 AM   #5874
Eirik's Avatar
buboy28,
You will have to buy the Alu hubs seperately, but they are worth it!!
Eirik is offline   Reply With Quote
Old 12-24-2004, 06:36 AM   #5875
rayhuang's Avatar
Thanks for the great sig!!!
Old 12-24-2004, 09:16 AM   #5876
dawgmeat's Avatar
Default 415/evo 4 manauls
is there a web site that you can down load these two manuals?
dawgmeat is offline   Reply With Quote
Old 12-24-2004, 09:20 AM   #5877
TEAM BOGART™
TRF415 Front Diff Parts (TRF415 Thread's Most FAQ)
YOKOMO ZS-501 Diff Joints
YOKOMO ZS-506 Diff Rings
YOKOMO ZS-507 Diff Thrust Bearing Set
YOKOMO ZS-508 Diff Adjusting Kit
YOKOMO ZC-S100 Shim Kit (10.0mm diam) 20 pieces
(2) 5x8mm bearings
TAMIYA 51055 415 Diff Pulley
TAMIYA 53379 3mm Lighweight Diff ball set or any 3mm diff ball
TAMIYA 53708 Tamiya TRF415 Center Direct Pulley
TAMIYA 51092 Tamiya EVO IV 46mm Swing Shaft (old suspension
with the new suspension wont you need longer dogbones?also how long are the f201 dogbones?
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-24-2004, 10:03 AM   #5878
forty6's Avatar
I don't have the LW suspension and my MS is still sitting in pieces in its box so I really don't know. The F201 bones are longer though, not sure by how much. The TAMIYA 53522 F201 Unversal shaft is the complete assembly. Does anyone have the part # just for the F201 swingshaft for this?
Old 12-24-2004, 10:07 AM   #5879
forty6's Avatar
I'm glad you liked it. I figured to use the space for something useful for a change.
Old 12-24-2004, 10:24 AM   #5880
rayhuang's Avatar
Theres got to be smeone who makes a lt. weight universal shaft that will work instead of the steel F201 universals right?
Wow-the $470 415ms is starting to edge towards a $550++ 415. But-I suppose Ive got that much tied into one of my Xrays.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
