Old 12-22-2004, 10:27 AM   #5776
s2
s2's Avatar
the yokomo parts are for making a diff.
if you want a spool buy a speedtech one or you can grind and epoxy your oneway...
i bought the parts for a second oneway to epoxy as a spool, works very well, less chatter than the speedtech i found also (and more blue haha)...
s2 is offline   Reply With Quote
Old 12-22-2004, 10:31 AM   #5777
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally posted by racer
and as for foam tires, what size do most people run on carpet? are you required to trim down the tires?
Thanks in advance!
The tires are way too big out of the package. I start mine at 2.35 for club racing and run them from there. Big races most guys start the tires smaller than that. Some guys run their club race tires down to a certain point, true them to around 2.3 or smaller and then bag them up and save them for the big races.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 12-22-2004, 10:48 AM   #5778
dawgmeat's Avatar
Originally posted by BlackKat
I found a worn-out XRay T1 spool at my track a month ago and recently tried to fit it into my 415. It fit perfectly!
This makes me wonder if the diff from an XRay will fit into a 415
1. how many teeth are on the diff pully? hope it 35
2. would the 415 belt be too wide for the x-ray diff pully?
3. can 415 diff pully fit the x-ray diff halves and diff rings?
dawgmeat is offline   Reply With Quote
Old 12-22-2004, 10:49 AM   #5779
well if the outdrives didnt brake it would have been ok.more research i think lol
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-22-2004, 10:58 AM   #5780
BlackKat's Avatar
I don't know on all counts
I said spool...So maybe the diff parts will work
I'll try to follow up on this within the next month
BlackKat is offline   Reply With Quote
Old 12-22-2004, 11:00 AM   #5781
TryHard's Avatar
i appologize if this question has been asked before.
where do you place weights on the car and how much?
i have seen people place them beside the motor and down the centre.
would it be easier to weight the motor/electronics and batteries off the car and then distribute the weight accordingly?
Thanks in advance!
I always weight it with batts motor etc in place. Then I set the shocks with the same amount of pre-load, and then place it on a tweak boards and position the weight as required.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-22-2004, 11:02 AM   #5782
koabich's Avatar
Send a message via Yahoo to koabich
#1: the diff pulley's do have 35 teeth.
#2: no, the belts should fit...I do believe the the Tamiya belts are wider though (I could be wrong)...3mm v.s 2.5mm
#3: it would be nice to be able to use the X-Ray diff becuase it is sealed...after every day I have to rebuild my current diffs to pull the carpet fibers out of them!
koabich is offline   Reply With Quote
Old 12-22-2004, 12:13 PM   #5783
The last time i checked i am sure xray diffs were off center? I presumethe spool will fit as you can just mount the diff pully on the other side of the mounting flange so its centered on the spool and not off centered like how the xrays run it, this is not possible on a diff though. Rick
Rick Draper is offline   Reply With Quote
Old 12-22-2004, 02:35 PM   #5784
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Default First time with the 415MS
I finished building the car at 4PM yesterday then crawled through traffic to race it at SoCal Raceway. For my first time racing electric. I am excited that the car was easy to get used to and only got better as the night went on. The car was a dream to build and much faster than I expected. One thing I noticed was that the car has lots of steering. I had to dial down the speed to 50%. I am sure I will do good wiht the car at the next race.
What kind of tires and inserts should I be using at SoCal?
Racing4Evo is offline   Reply With Quote
Old 12-22-2004, 02:41 PM   #5785
Default MS Part Number
Anyone that has a MS what are the part numbers for the chassis and top deck?
JC
tiggersz is offline   Reply With Quote
Old 12-22-2004, 03:11 PM   #5786
Trader Rating: 62 (100%+)
Default SoCal tires
Sorex 36r with Yokomo super thin medium inserts work very well, and last for many runs.
patrick is offline   Reply With Quote
Old 12-22-2004, 03:16 PM   #5787
TJ
TJ's Avatar
A question you guys might be able to help me out on. I thought I have seen alumimum c hubs and front steering blocks for the 415 what car are they from and if a can what part numbers are they?
Castle Hill Raceway: www.castlehillraceway.com
Facebook: https://www.facebook.com/groups/121817254587521/
"Anything I say can or will be used against me at a later date":
TJ is offline   Reply With Quote
Old 12-22-2004, 03:32 PM   #5788
Wink ms part numbers
lower deck-- 4004032
upper deck-- 4005104
Old 12-22-2004, 03:34 PM   #5789
forty6's Avatar
If the car is running the old suspension, it is probably the parts made by Square for the EvoIII. If the car is running the LW suspension, again from Square for the EvoIV. If you want something cheaper, Eagle racing makes some knuckles but in purple. Speedtech should have the Square bits.
forty6 is offline   Reply With Quote
Old 12-22-2004, 06:01 PM   #5790
TJ Square has the new hub front and rear for the LW suspension.
How are things over there at Castle Hill
D
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
