Like Tree2Likes
Tamiya TRF415
Old 12-19-2004, 12:11 AM
  #5686
racer's Avatar
Originally posted by TeamPRP
It looks as though our spur gear plate will work for the 415 too. I will have one of the local guys try it on his car to make sure it fits. It looks like it will. Here's a photo of it on a Xenon spur.
Thanks!
Ben
correction: have tried it on the 415. the opening needs to be slightly bigger.
racer is offline
Old 12-19-2004, 01:46 AM
  #5687
what is the weight of the yellow springs
ptjonesus is offline
Old 12-19-2004, 02:53 AM
  #5688
V12
V12's Avatar
Originally posted by KilRuf
Comment on Rubber tire carpet with old suspension vs. new LW. I remember I kept reading that Marc R prefers the old style on high tracion surfaces like carpet. The LW is more for asphalt. That is my take on what I have read since the LW suspension came out.
Yes itīs exactly as you said Marc is using the old suspension on carpet. Pictures from the Touring Car Carpet World Cup in Switzerland confirm this.
http://www.ps93.ch/galerie/2004/carpet-wc/carpet05g.jpg
V12 is offline
Old 12-19-2004, 03:15 AM
  #5689
Tommy Bergfeldt's Avatar
OK, then i will order some original arms too and try.
Springs.. Does Yokomo springs fit on the shocks with no modification? Because some Tamiyadamper-guys here say they will work, it would be awsome if i don't have to buy another whole springset
Tommy Bergfeldt is offline
Old 12-19-2004, 07:25 AM
  #5690
The old arms will not fit on the new MS chassis plate, the blocks are now closer together. Rick
Rick Draper is offline
Old 12-19-2004, 07:49 AM
  #5691
forty6's Avatar
That chassis seems very narrow, the batteries are almost sitting on the edge.
forty6 is offline
Old 12-19-2004, 07:50 AM
  #5692
hmm, but LW arms fit on regular chassis plate? Or does the LW kit include a new chassis?
I'm leaning towards buying a regular 415 though, it's cheaper and the old susp looks like it's better on carpet, and the towers and LW set are available later if i want to race on asphalt, which is seldom more than 1 race a year..
Old 12-19-2004, 07:52 AM
  #5693
forty6's Avatar
Also the rear droop screws are barely touching the chassis too?
forty6 is offline
Old 12-19-2004, 07:55 AM
  #5694
forty6's Avatar
??? I thought the blocks are the same as the LW suspension just like Sparx said. Can somebody confirm this?
forty6 is offline
Old 12-19-2004, 08:01 AM
  #5695
The MS's chassis is 2.5mm thick and is designed for the new suspension. When fitting the new suspension on the old 415 you needed masses of spacers to shim it out where as with the new shassis you only need about 3mm of spacers to adjust the wheel base. Its got the blocks about as far apart as the evo 4 has and they have to cut the old wishbones to make them fit on that car.
The blocks themselves are the same on the MS and the old 415.
Rick
Old 12-19-2004, 09:08 AM
  #5696
SpeedTech's Avatar
I don't think the Yokomo springs fit. The Associated spring will work on the Tamiya shocks
Steve Wang
SpeedTech is offline
  #5697
V12
V12's Avatar
Rick
This means the old arms wonīt fit the new chassis without dremeling?
Hmm, Sleini told me the old arms will fit but itīs not possible changing the wheelbase.
V12 is offline
Old 12-19-2004, 09:46 AM
  #5698
Anyone knows which front shock tower this is???
benoitrdv is offline
Old 12-19-2004, 10:30 AM
  #5699
kentech's Avatar
That's the shock towers (both front and rear) from the first prototype TRF415 cars that Tamiya made around a year ago.
The Yokomo springs do fit the TRF dampers. They are a bit shorter than Associated and Tamiya springs though.
kentech is offline
Old 12-19-2004, 11:20 AM
  #5700
They possibly do fit but you will need the adjustment to get the wheelbase correct. Rick
Copyright Đ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
