Old 12-15-2004, 08:36 AM   #5566
rraden's Avatar
Trader Rating: 235 (100%+)
Does anyone know which swing shafts need to be used when running a ball diff in the front of the car? I've heard you can run the ones from the F201 or the 415MS. Are they aluminum or steel?
What are the part numbers for these universal shafts?
rraden is online now   Reply With Quote
Old 12-15-2004, 08:51 AM   #5567
Trader Rating: 45 (100%+)
You have to run the 46mm swing shafts. They come in both aluminum and steel. I don't know the part number off hand, but I know the shafts do come with the LW suspension kit.
Apex is offline   Reply With Quote
Old 12-15-2004, 08:56 AM   #5568
TryHard's Avatar
TAM51092 Tamiya EVO IV 46mm Swing Shaft
Not sure if their alu or steel, try asking steve at speedtech, thats where i got the info from.
Hope it helps
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-15-2004, 09:21 AM   #5569
BlackKat's Avatar
Originally posted by Randy Caster
I was trying to get some traction out of the rear end, and some more steering up front.
Try the A-bridge block up front and 2 degrees toe in the rear...
Car gets good steering, rear traction yet still rotates well
BlackKat is offline   Reply With Quote
Old 12-15-2004, 09:37 AM   #5570
V12
V12's Avatar
51092 is the steel swing shaft
53724 is the aluminium
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 12-15-2004, 09:45 AM   #5571
Default Foam tires??
What foam tires for mod sedan (on carpet) have you guys been using?
Old 12-15-2004, 09:45 AM   #5572
raffaelli's Avatar
Default trying to avoid doing it myself...
Has anyone added information to the suspension block toe chart to list the width of the car?
24ITA
raffaelli is offline   Reply With Quote
Old 12-15-2004, 09:54 AM   #5573
rcfiend's Avatar
Trader Rating: 30 (100%+)
Dave you have PM.
Keith
rcfiend is offline   Reply With Quote
Old 12-15-2004, 10:03 AM   #5574
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Default Re: Foam tires??
Orange/ dbl Pink fronts & dbl pink rears are the only way to go.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 12-15-2004, 11:30 AM   #5575
raffaelli's Avatar
I really like the cyan/magenta combo from TM
24ITA
Old 12-15-2004, 12:00 PM   #5576
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Already have both of those things on the car I also raised the rear blocks up 1mm to get the back end to rotate better. I did have 1.5mm spacers under them which worked even better, but the belt hit the rear A block. I'll grind down the block where the belt was hitting and experiment with raising it higher yet. I also ditched the center 1 way pulley and that helped with turn-in. Switching to the 2 degree caster blocks helped as well.
Old 12-15-2004, 12:01 PM   #5577
Default Re: Re: Foam tires??
I agree with this one, that has been the best combo I have run.
Old 12-15-2004, 12:48 PM   #5578
TRF415boy's Avatar
By the way guys, I'm sure this have been already asked, but how does the stock 415 blocks compares to the TB Evo 3 ones in terms of RC position ? I've got all the Evo 3 blocks and was wondering if they'd be of any use...
TRF415boy is offline   Reply With Quote
Old 12-15-2004, 12:50 PM   #5579
What would running the front one way without the mid one way do?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 12-15-2004, 01:38 PM   #5580
rtypec's Avatar
The 415 blocks are a little lower than the Evo3/4 blocks. Approximately 1mm lower. Hole pattern is identical. When I need a higher RC than normal, I typically use Evo blocks on my 415 to avoid having too many spacers under them.
Randy, have you tried going back to 4 degree caster? The 2 degree caster doesn't necessarily give more steering throughout the corner, just more initial and a "twitchy" feeling. Also have you tried running 1D and A bridge with a maybe .7-1.0mm spacer underneath the A in the front? Try lengthening the rear camberlinks. Drop the front inner camberlinks a bit. Put in about 7 degrees of front camber (just kidding) hehe.
rtypec is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
