Tamiya TRF415
#5551
R/C Tech Elite Member
Originally posted by rcnewb2004
what do these lbs/cubic inch mean?
those are the density of the balls? so the nitride balls have the lowest density, therefore the lightest when comparing ot the other two? or is it how much pressure those balls could take before they crack? sorry my physics and units are horrible.
#5553
Rick Draper: A few pages earlier you have a photo of a 415 set-up for carpet. WHo's car is that? Not sure if you meant to say Marks.
If it is, its very interesting. Seems like dual one-ways, even with rubber tires in modified may be the way to go. I will probably ditch the spool and try a diff.
And no sway bars.
Chris: FYI I just got a few of the hardened rear diff halfs, white ones.
Question to the UK crowd: what rubber tires are the best to run on carpet?
And no sway bars.
#5554
And no sway bars.
And no sway bars.
Tyres wise, I've been using Sorex 24R's, mainly with the B-med insert, seem like a good combination. I have heard the Take off CS22's and Sorex 28's are also good.
I have tried the Sorex 20's. but I found they overheated a bit to quick, basically ruining the run in the last minute. the 24R's take longer to overheat, and the wear is quite good, especially for club racing.
HiH
Ed
#5557
Hi, I am a newbie to 415MS.
Which spur gear should be used for 23T motor?
I think 102T is suited for modified motor.
Thanks.
Thanks.
#5558
Gearing issues!
Thanks.
Thanks.
Enjoy your new found obsession!
#5559
does the 415 toe blocks fit on the evo 4?
#5560
Ceramic balls/bearings - I agree that ceramic bearings are a bit lighter but I don't believe that is a strong enough reason to run them. In most cases, ceramic bearings are of a tighter tolerance or grade of ball. They also have a much higher hardness rating. Sometimes you'll see a measurement in "Rockwell" which is a unit of measure for the hardness of a metal surface. So increased longevity, smoother operation, and a slight increased performance are the main motivations for running ceramic bearings. I can see some guys justifying ceramic diff balls for the decrease in weight but you can throw most of this out the window if you can't get your car to corner fast. That is bar none the most important thing to get nailed down on your car before jumping on ceramic parts. I believe Speedtech has a bearing set for sale for the 415 so you don't need to know all the sizes.
Spur gears - I've been running a 104T Spur gear in stock. Looks like the car would max out at about 108T. The only reason to change the spur is to try and get finer adjustments to your gear ratios or to try to match a rollout from somebody with another car.
#5561
Originally posted by KREATOR1
some off you guys cut the bumper smaller, why? does it got to do with speed?
#5562
I got to run my first day with the 415MS today, car is really impressive right out of the box. Made a lot of changes, and got it working pretty well. Today was mainly just a test day, and I did learn a lot about the car, it is really stable, too stable, I was trying to get some traction out of the rear end, and some more steering up front. I gotta admit I wish I would have gone into racing to be more competitive and glued up a new set of tires, rather than running the ratty old ones I had on the car, because the car definately would have been a good competitor tonight. I'll be mounting up some new tires for next weeks racing, and see what this car is capable of
#5563
#5564
And no sway bars.
And no sway bars.
#5565
Hey Rick, will you still run Tamiyacup races next year? You'll have to arrange a beer trip to Belgium with some of the blokes to participate in a Belgian Tamiya race otherwise.
