Old 12-13-2004, 08:22 PM   #5536
Send a message via ICQ to rcnewb2004
if the nitride layer is only a few microns think... then how does it reduce the amount of rotating mass? surely a few microns of nitride will not be able to reduce rotating mass to a significant measureable point?
rcnewb2004 is offline   Reply With Quote
Old 12-13-2004, 09:35 PM   #5537
SpeedTech's Avatar
Originally posted by raffaelli
What is the diameter of those sways?
they vary from 0.8-1.8 I believe (in increments of .2)
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-13-2004, 09:43 PM   #5538
raffaelli's Avatar
Thanks Steve.
24ITA
raffaelli is offline   Reply With Quote
Old 12-13-2004, 10:32 PM   #5539
Default Diff Balls
There is no core to the Silicon Nitride Diff Balls and they are not coated. This is pure solid Silicon Nitride Ceramic material that is formed and shaped to be spherically round and then polished up to be metal like smoothness and superior hardness.
Tungsten Carbide Balls = .54 lbs/cubic inch
Chrome Steel Balls = .283 lbs/cubic inch
Silicon Nitride Balls = .116 lbs/cubic inch
It can't be just a coating or there would not be this much of weight difference for a couple microns thickness.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 12-13-2004, 10:47 PM   #5540
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Carl Giordano
Randy, what servo horn is that? I'm still using the Tamiya servo savor which seems to work fine. Are your using a full metal servo?
It's an Ofna servo horn on a Futaba S9550. I never run any kind of servo savers, even in off-road, and never broken a servo yet.
Old 12-13-2004, 10:49 PM   #5541
Originally posted by rcnewb2004
randy,
i just want to see what hte difference is. I heard a lot of good stuff about ceramics, reducing rotating mass and such. But i want to buy a set of bearings, and not go thru all the measurements and stuff myself. so if anyone can offer a website that has a set of trf415ms quality ceramic bearings for sale, that'd be nice.
and ur new born trf415ms is the cutest thing. that aluminum servo horn looks cool, where'd u get it? does it get rid of the slack that the tamiya horn has sometimes?
To be perfectly honest with you, you wont notice any difference on the track with ceramic bearings as opposed to stock ones. Use the cash to get a good battery and motor instead.
Old 12-13-2004, 10:51 PM   #5542
Originally posted by Blakesrc
Randy,
Looks good dude. Deffinetly let us know how it goes on Tuesday night, i might be in the area and make it to race on the tuesday evening after christmas.
Good Luck,
Blake
If you make it, drop by my pit and say whats up Hopefully pro-mod gets a good turnout, I dont wanna make this thing run a 19 turn motor
Old 12-13-2004, 10:53 PM   #5543
Originally posted by Ballsie
Randy, did you trim the foam bumper (fender) or is that a different part?
It's a trimmed stock bumper. Removed some material that was hitting the front of the body so that it should give more steering.
Old 12-13-2004, 10:53 PM   #5544
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Did Rheinhard use the Alex Racing Barracuda R3 sway bar kit
(Product # A6341-A6343) during the worlds?
I noticed the decal on his car as well as the black sway bars like these ones -
The ALEX Parts that Marc Rheinhard used was the Ti Coated shock shafts for the TFR Dampers...... that I know of... but the Sway bars might have been used also
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-13-2004, 10:56 PM   #5545
Originally posted by MikeR
Eww it looks terrible Randy... you need to sell it to me right away.
I'm sure that in a month or so I'll have a couple more as backup cars, and maybe a carpet car with a 3mm chassis, so this one might be able to be sold
Old 12-14-2004, 02:32 AM   #5546
Ballsie's Avatar
Thanks, I'll probably try the same myself
Ballsie is offline   Reply With Quote
Old 12-14-2004, 02:45 AM   #5547
maxepower's Avatar
Default Re: Diff Balls
DING DING DING
GIVE THE MAN A CIGAR! HE IS ABSOLUTELY CORRECT, I'M GLAD SOMEONE IS ON THE BALL
The great thing about this website is everybody is entitled to give their opinion! It's up to us to decide which one we acknowledge!!!
Just my 2!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-14-2004, 03:35 AM   #5548
what do these lbs/cubic inch mean?
those are the density of the balls? so the nitride balls have the lowest density, therefore the lightest when comparing ot the other two? or is it how much pressure those balls could take before they crack? sorry my physics and units are horrible.
Old 12-14-2004, 06:15 AM   #5549
TRF415boy's Avatar
well it's the first time i hear of an engineering material that is full ceramic. Even for machining tools the ceramic is only a coating, because making them a full material would be well too difficult and expensive, plus it would break at the first shock on it.
Anyway, I agree with Randy, better invest in some batteries of even better, spend the money into racing more (i.e. instead of spending $100 for a set of bearings, buy some tyres and spend some fuel with the cash to go racing). This way you'll have more FUN.
TRF415boy is offline   Reply With Quote
Old 12-14-2004, 09:13 AM   #5550
Just beware your car will be much more prone to breaking on front end impacts if you cut the bumper.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
