Tamiya TRF415
#5434
Re: Re: Re: Re: twisting front belt
Originally posted by koabich
The belt stabilizer could be just that...stabilizes the belt so it doesn't flip over. Like I said I run my belts pretty loose, anywhere from 1-3 clicks. Most of the time I leave them on 2. If you go with the stabilizer, you will be able to loosen your belts and not have them flip!
#5435
TRF415. I call it the bridge because it has the cut out for the belt to ride under.
Randy Korey did run that there at Nats it works good but not as well as it did with the E3. It will aid turn-in. To aid turn-in I have been running around 2mm under the front link. A bridge, play with the front block A-D and .5mm kickup. I also have been running thinner and thinner oils during the summer I was 40-50 with the 3 hole piston.
To clarify the A-D helps the mid corner not neccessarily the turn-in
#5436
Re: Re: Re: Re: Re: twisting front belt
Originally posted by KREATOR1
well my stabilizer is on the way.. Will tell you if the stabilizer solve my problems..
#5437
Re: Re: Re: Re: Re: Re: twisting front belt
Originally posted by BlackKat
Stabilizer did crap to help my belts not flip
#5438
Belt Flip
The only time I've flipped a belt is after a crash. Its happened because my battery shifted due to old tape in the car and the battery seems to be the guilty party. Maybe some people's belts have more of a twist to them than others?
#5440
No belt problem here either. I run 1 loose in front with the stablizer and 0 in the rear. Stock and 19T only.
#5441
Blakesrc - yeah. I run just one notch tighter than the center setting (lined up with white line) so its one notch past the white line. It depends on your belt.
The funny thing is the time that my belt flipped, the entire belt was inverted so it was running on the flat side. And when it flipped, my car was still going around the track pretty good. That 415 want to just keep ripping it up.
#5443
#5444
Hmm....Belts probably streched. I'm running atleast 1 or 2 notches tight up front. Probably cause I got it used (like everything else expensive) The front D-block looked like it had been through a few stages of hell too...
I got a spare front white belt I'll replace it with...hopefully it lasts
#5445
Hi, i was looking on speedtechrc to see if there was any more news on the 415ms and i was looking in the tamiya section of the kits and it says 'pre-orders closed' does this meen there is none left or you just need to wait for some to come into stock ?
Chazz
Chazz
