Old 12-08-2004, 11:37 AM   #5401
razzo's Avatar
Send a message via Yahoo to razzo
Originally posted by JDM_DOHC_SiR
You`ll see the 416 before you`ll see a TC5 or Pro5
-Dave
you sure? considering how pity the new TC4 is, may be they won't take 4+ years to release TC5
razzo is offline   Reply With Quote
Old 12-08-2004, 12:22 PM   #5402
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by TryHard
Yup it is (for caprpet that is)
Ed
Thank god! lol
Old 12-08-2004, 01:12 PM   #5403
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
hey randy last time i was at socal i was running AE 50wt with 2 hole pistions
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 12-08-2004, 01:36 PM   #5404
dawgmeat's Avatar
Default Re: Re: new front end
[QUOTE]Originally posted by razzo
eek! purple?! that purple and blue just don't mix... j/k
how's the slop on that system? I tried Eagle (Integy) ones on my old 414M and they were POS. Bent on one crash, and sloppier then original plastic.
[/QUOTE
no slop on steering knuckle, hub carrier required some work and yes the Yok front bumper kit is a perfect fit. Tamiya and Yokomo must have something going because a lot of their parts are interchangeble, i.e. diff outdrive bearing, front dif, etcf
dawgmeat is offline   Reply With Quote
Old 12-08-2004, 03:29 PM   #5405
The 40wt was rediculously thick, I like the car to react quick, so my 30wt should be good..
Old 12-08-2004, 05:57 PM   #5406
TRF415boy's Avatar
49 is for limited edition items, it means they will make only a selected number of kits, so you gotta pic yours before they all go.
TRF415boy is offline   Reply With Quote
Old 12-09-2004, 04:25 AM   #5407
PMR
Default Asphalt Set up
Do you know where I can find setups for the 415 for asphalt? Thanks
PMR is offline   Reply With Quote
Old 12-09-2004, 06:03 AM   #5408
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default twisting front belt
how often did you change your front and rear belt?
my front belt keep twisting even the diff holder at 4 clicks.
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 12-09-2004, 09:09 AM   #5409
Kreator--sounds bad, but check that you have the diff in the correct alignment holes i.e. both nubs are in 4 forward or 4 back. I watched a local tear his hair out along with going thru 2 or 3 belts.
Aside from that you should not be going thru belts often. If you race Open Mod often maybe every 2 months. That would be on carpet with locked center and a spool.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 12-09-2004, 10:14 AM   #5410
rtypec's Avatar
What's up Dan!
...or every 2 days in my case hehe. I'm gonna stick with black belts for winter time play and save the white ones for racing
rtypec is offline   Reply With Quote
Old 12-09-2004, 10:42 AM   #5411
BlackKat's Avatar
Default Re: Asphalt Set up
Try: Stock setup w/40wt oil & the front A-bridge block
Lots of emphasis on the front A block. Without it you won't get enough steering
This setup works at most tracks I race at pretty good (Carpet Rubber Tire & Pavement)
BlackKat is offline   Reply With Quote
Old 12-09-2004, 10:51 AM   #5412
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: twisting front belt
I have been hearing of people flipping the belts on the 415. I cannot understand how this is happening. I have had my belts so loose and have never had a problem. I have been running the belt stabilizer since day one though. That may be the reason i have not had any problems. Might want to check that part out!
koabich is offline   Reply With Quote
Old 12-09-2004, 10:56 AM   #5413
KREATOR1's Avatar
Default Re: Re: twisting front belt
Lucky for you... I might want to get that belt stabilizer, even thou my belts is tight enough.
Old 12-09-2004, 11:10 AM   #5414
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
it may be that they are too tight. plus, if i remember from my automotive days, once a belt has flipped, it will have a bigger tendency to do so again.
i have been running mine at 1 click tighter since the 2nd month i got it, and no problems, stock or 19T indoors, outdoors mod 8x2. and i havent got the upper tensioner yet, either...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 12-09-2004, 11:12 AM   #5415
maxepower's Avatar
I think once that belt twists it will tend to keep twisting because it is now deformed. You may not be able to see it but the rubber is internally damaged!
Belt tensioner will help but you should tighten belt after 4 or 5 hard runs. One to two clicks at a time.
Some drivetrains on the 415 vary a little as far as side play. If there is a lot of side to side movement on the pully you may want to shim it out, this too will help.
Last, like Rod said save the white belts for racing and the black belts for practice. The black ones are a little stiffer and hold up better than the white.
Just my 2 !
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
