Like Tree2Likes
Tamiya TRF415
Old 12-07-2004, 07:36 AM
  #5371
rtypec's Avatar
Originally posted by Chazz
Just wondering will tamiya still make the MS edition or will it be one pre order like the yokomo and that's it
Chazz
Does the kit's part number start with 49? or does it start with a 5?
Umm yeah...sanding and cutting a 9mm rear shock tower mount out of carbon is bad for the skin...I STILL feel kinda ichy...
rtypec is offline
Old 12-07-2004, 09:04 AM
  #5372
hey guys...i'm in the process of ordering my ms kit ...question though...is the Ti screw set worth the 30-40$ extra? thx.
Gary
loosenut is offline
Old 12-07-2004, 10:12 AM
  #5373
RCGaryK's Avatar
Originally posted by jeffreylin
for the MS:
5mm x 9mm 8 each
5mm x 8mm 2 each
10mm x 15mm 4each
4mm x 8mm 2 each
for the regualr 415
5mm x 11mm 8 each
5mm x 8mm 2 each
10mm x 15mm 4each
4mm x 8mm 2 each
Thanks Jeffrey, that was what I needed.
RCGaryK is offline
Old 12-07-2004, 10:49 AM
  #5374
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by TryHard
I've been running 3 hole pistons with 60wt oil recently. But I think I might drop down to 50, and generate a little more grip.
Originally I went with 2 hole pistons and 50wt oil, and thta feels pretty similar.
I'm not sure thats what you want to hear though....
HiH
Ed
I'm running on asphault, please tell me that's for carpet
Randy Caster is offline
Old 12-07-2004, 10:51 AM
  #5375
Gary
That's up to you, I opted to get it. If you want it thrown in with the price of the kit and dont necissarely need everything right this second, pre-order one at Speedtech.
Old 12-07-2004, 10:57 AM
  #5376
49, is that good or bad
Chazz
Chazz is offline
Old 12-07-2004, 11:04 AM
  #5377
Randy, are you going to Tamiya this Saturday?
tcmerf is offline
Old 12-07-2004, 11:41 AM
  #5378
forty6's Avatar
Chazz
Don't worry, there will be plenty to go around. The 414m2 and the Surikarn were both "limited" with 49xxx kit #. I guess they were limited to 50,000 kits. The 414 WCR however, was really limited to 1,700 kits as numbered on the motor plate. I don't believe the MS is a true 415 WC replica though.
forty6 is offline
Old 12-07-2004, 12:09 PM
  #5379
Sorry I wont be able to make it this saturday. I'll be at SoCal next Tuesday most likely.
Old 12-07-2004, 02:16 PM
  #5380
Default Re: Servo Horn
Originally posted by Hugo
From which manufacturer is the servo horn (aluminium blue) that M.Rheinard and S.Maezumi were using at the worlds.
I can see in the pictures that is a long one.
Any answer?
Hugo is offline
Old 12-07-2004, 02:22 PM
  #5381
Ballsie's Avatar
Default Re: Re: Servo Horn
Any answer?
I'd love to know too - anyone?
Ballsie is offline
Old 12-07-2004, 03:00 PM
  #5382
forty6's Avatar
It looks like they were both using 9550 servos, Futaba makes long alu horns
long
standard
just a guess
forty6 is offline
Old 12-07-2004, 03:07 PM
  #5383
Ballsie's Avatar
Thanks man - i've got a ko servo, so I'm pretty sure they won't fit!
Ballsie is offline
Old 12-07-2004, 05:19 PM
  #5384
dawgmeat's Avatar
Default new front end
carpet racing can be ruff
dawgmeat is offline
Old 12-07-2004, 08:40 PM
  #5385
Default Kawada Spurs
I have the following Kawada 64P spurs(hexa Spurs)
NIP !! @ $4.00 each + $ 1.95 shipping for up to 10 spurs, to the lower 48 only, others must email for shipping.
(5) S64-104
(27) S64-106
(9) S64-108
(9) S64-110
(13) S64-112
(32) S64-114
Paypal is the preferred method of payment.
hardadz is offline
