Like Tree2Likes
Tamiya TRF415
Old 12-05-2004, 09:39 PM
  #5281
Turbonium's Avatar
Trader Rating: 27 (100%+)
depends on what you buy.. my order was about 13800 yen, with the 20% off, keeps the price in line...
Turbonium is offline
Old 12-05-2004, 09:53 PM
  #5282
forty6's Avatar
That's true especially if you're running the LW suspension or an EVO4, you'll need all the discount you can get on those susp bits. j/k
forty6 is offline
Old 12-05-2004, 09:58 PM
  #5283
Turbonium's Avatar
actually, i have been putting the E-IV on the track, and have yet to break anything. but.. our track is pretty forgiving. doubt the boards on the average indoor track will be as car-friendly! i actually ordered more stuff for the 415... extra belts, etc. i did order some hopups for the Evo, and some general hardware.
Old 12-05-2004, 10:04 PM
  #5284
dawgmeat's Avatar
Default 190mm Foams
For the front and rear stock arms, what combination of suspension blocks will you under 190mm usung 28 foams tires
dawgmeat is offline
Old 12-05-2004, 10:41 PM
  #5285
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
What is the internal ratio on the 415?
Randy Caster is offline
Old 12-05-2004, 10:44 PM
  #5286
forty6's Avatar
35/16=2.1875
forty6 is offline
Old 12-05-2004, 10:46 PM
  #5287
KREATOR1's Avatar
its 2.187
KREATOR1 is offline
Old 12-05-2004, 10:54 PM
  #5288
Thank You guys.
Old 12-05-2004, 11:03 PM
  #5289
KREATOR1's Avatar
Its amazing how this car handles out of corners using SS front arms.
Maybe some of you guys try it b4?
KREATOR1 is offline
Old 12-05-2004, 11:19 PM
  #5290
Hebiki's Avatar
Trader Rating: 26 (100%+)
try it using the whole set!
Hebiki is offline
Old 12-05-2004, 11:30 PM
  #5291
RCGaryK's Avatar
sigh..I won't even bother...lol....
RCGaryK is offline
Old 12-05-2004, 11:32 PM
  #5292
KREATOR1's Avatar
my purpose is to get the front smaller than rear. so that its better for thight corners.
Did you install both front n rear? hows the results?
KREATOR1 is offline
Old 12-05-2004, 11:40 PM
  #5293
over gear's Avatar
Trader Rating: 16 (100%+)
what is SS ?
over gear is offline
Old 12-06-2004, 12:57 AM
  #5294
kentech's Avatar
After all of the years of racing, I have never tried dual 1 ways, I think I heard the MS comes with a locked pulley, would you guys suggest I get the 1 way pulley as well?
The MS comes with a dual one ways.
Originally posted by 190mph
Does anyone know of the part numbers on any of the Shim sets for the wheels? The ones that go on the wheel hexes before putting on your wheels. I think there should be 0.5mm and 1mm thickness ones. Red Blue or Silver.
53646 Wheel Spacer Set (Blue) (4 pcs. each)
kentech is offline
Old 12-06-2004, 01:19 AM
  #5295
kentech's Avatar
Default TRF415MS Testing
Run the car for the first time this weekend, Saturday and Sunday on a fairly large but technical carpet track. I run Sorex 28R tyres with JB 1-piece blue thin inserts on Orion hard wheels.
The car handled pretty well from the beginning with the setup I started off with. That setup was the standard setup but with Orion 40wt oil and AE blue springs front and silver rear. I did a few changes that improved the car and overall I was really pleased with the car.
I broke no parts at all even though I had a few bad crashes so imo. the lightweight suspension is not fragile at all. The biggest impression of the TRF415MS is the corner speed the car carries, it's really impressive!
Here is the setup that worked best for me (everything not mentioned is same as standard setup):
- front:
shock position: 4 on tower and 1 on arm
oil: Orion 60wt
spring: Associated gold
droop: 6mm on droop gauge (under arm)
ride height: 4.5mm
- rear:
shock position: 5 on tower and 3 on arm
oil: 40wt Orion
spring: Associated silver
droop: 4mm
ride height: 4.7mm
- suspension mounts:
front: A - A
rear: X - D
Orion 12x1 Hara motor
4mm timing
gearing 79/22 (7.85)
Ride Accord Body
Flap high downforce wing
Sorex 28R
JB thin blue insert
Orion hard yellow wheel
kentech is offline
