Tamiya TRF415
#5208
Id be willing to bet that Randy shows up with a red 415! Did you ever get your GSXR?
#5212
Thats cool. AS much as i like to ride you still cant control everyone around you. Welcome to the ranks.
#5213
Originally posted by TryHard
Hi Koabich,
on mine to stop the posts moving up and down I run 3 of the 0.1mm axle spacers (the ones that you place between the hub bearings and the hex retaining pin). I place 1 between the bottom alloy collar and steering arm (underneath) and the other two on top of the arm, beneath the two alloy spacers.
completely eleminates all the slop, works well.
HiH
Ed
Hi Koabich,
HiH
Ed
II run 3 of the 0.1mm axle spacers (the ones that you place between the hub bearings and the hex retaining pin)
#5215
Originally posted by |8t
Do you have a part number for theses...Cant find them!!
I'm sure, but they may come in the spacer bag (9400096), but as I've never had to order any, and have always seemed to have an excess (1 415 kit, and 2 lwt suspension kits
HiH
Ed
#5217
Originally posted by over gear
kentech: what kind of front suspension bridge does the MS comes with? D/D ???
Front:
F: 1 A
R: 1 A (bridge)
Rear:
F: 1 A
R: 1 C
In addition you get these:
1 B
1 D
1 X
1 D bridge
#5218
53585,TAMIYA, 3mm SHIM SET 10PCS
53586,TAMIYA, 4mm SHIM SET 10PCS
53587,TAMIYA, 5mm SHIM SET 10PCS
53588,TAMIYA, 10mm SHIM SET 10PCS
Each bag includes 0.1, 0.2 and 0.3mm thick shims.
#5219
Originally posted by jeffreylin
New 415MS WC parts set just announced for 12/16 release on Tamiya's web site.
#5220
Originally posted by Ballsie
I couldn't find these details on the site - can you post a link please?
