Old 12-01-2004, 12:58 PM   #5161
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: Re: Re: A suspension bridge and direct center pulley pricing??
Originally posted by Apex
man, i definitely overpaid for those parts...forget ordering from etamiya.com again...
There is an ebay store called Walawala. You can search for it on ebay. The guys is the best for Tamiya and has the absolute best prices. He is located in Japan but I have my stuff I order from him in under 2 weeks and the shipping is cheaper than if I were to order it in the US. Check him out!
koabich is offline   Reply With Quote
Old 12-01-2004, 02:34 PM   #5162
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Hey Guys,
JRRobiso posted a few days back asking for an assphalt spool setup and it kinda got bumped out of site really fast. I am also looking for one, if anyone has something please post it.
Thanks,
Blake
Blakesrc is offline   Reply With Quote
Old 12-01-2004, 07:12 PM   #5163
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Is the 415 gonna be legal for TCS in 2005 GT1 class?
Old 12-01-2004, 07:14 PM   #5164
ChadCapece's Avatar
Does anybody have a 415 that they want to trade for a Pro 4?
email [email protected]
ChadCapece is offline   Reply With Quote
Old 12-01-2004, 07:28 PM   #5165
hey guys...jus got meself a n MS...wondering if any one of u guys hav had any probs on da 415 diffs...i cant seem to tighten mine..da nut jus turns along when i try to tighten da diff screw...also any reccomendations on belt tension?
razi is offline   Reply With Quote
Old 12-01-2004, 07:41 PM   #5166
jeffreylin's Avatar
R/C Tech Charter Subscriber
The nut holder in the diff is probably stripped. Replace it and tight the nut more carefully next time. Alternatively, you can drop a tiny bit of CA between the nut and the nut holder so the nut won't move when you try to tighten/untighten.
I run my belt one notch loose in front and 0 in the rear.
jeffreylin is offline   Reply With Quote
Old 12-01-2004, 07:43 PM   #5167
thkx bro..is there anyway i can actually get da nut holder...or is there any alternatives to it?
Old 12-01-2004, 07:55 PM   #5168
jeffreylin's Avatar
You have to get the parts tree the nut holder came with. I am not sure what the part nuber or which tree it is but you can certainly find it in the manual.
Alternative would be what i said. Use CA.
Old 12-01-2004, 08:04 PM   #5169
koabich's Avatar
I had the same problem. The nut always slips in the tamiya diff holder...no matter how carefull I am. I normally do one of two things: put a drop of CA on the nut and the holder or use the Associated piece that has the nut molded into the plastic retainer.
When I use the Tamiya stuff, it always seems the the diff loosens too easily. With the Associated piece (the one they use for the steel outdrives only) the diff always stays as tight as i need it. The threads are different sizes (Associated nut and Tamiya screw) so I just cross thread the Tamiya Diff scew in the Associated piece. Never had any problem this way and when i set the diff it stays that way until i decide to change it.
Old 12-01-2004, 08:48 PM   #5170
cool..guess i jus have to try da ca method again...
Old 12-01-2004, 09:08 PM   #5171
rtypec's Avatar
psst. Wanna hear a little secret to the diff nut holders?
Pick up the TA04 Ball Diff Pulley #50877. It comes with a pulley you won't use but it comes with a much better diff nut holder. The plastic on this one is harder/stiffer less likely to booger on you. The tree existing 415/Evo4 nut holders come molded on are of the bumper stuff (soft) Set it and forget it!
rtypec is offline   Reply With Quote
Old 12-01-2004, 09:26 PM   #5172
C_O_jones's Avatar
To keep the nut holder from stripping, compress the new spring once gently with a pair of pliers. Seems to set the spring, not sure why ,but it works. Also holds the first run tension better.
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 12-01-2004, 09:39 PM   #5173
maxepower's Avatar
Default I'm with you!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-01-2004, 09:42 PM   #5174
maxepower's Avatar
Default TAO4 diff!
I did the same thing by accident, when I put my diff together the first time I stripped it right from the start. So, I had a bunch of TA04 diff parts handy so I used one and it works great!
So far so good no slipped diff problems!!
Old 12-01-2004, 09:46 PM   #5175
I am not sure how you are havuing probs. I have rebulit my diff once since I got the car (3months ago) and have not had to readjust it once.
My only prob is you can't do the diff up tight enough to make increase the limited slip effect.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
