Like Tree2Likes
Tamiya TRF415
Old 11-29-2004, 08:10 AM
  #5071
BlackKat's Avatar
You can use XRAY spools in the 415
Speedtech makes one too.....
BlackKat is offline
Old 11-29-2004, 08:17 AM
  #5072
Trader Rating: 47 (100%+)
So does that mean I can use and XRAY Diff in the TRF415 also??
Apex is offline
Old 11-29-2004, 08:21 AM
  #5073
BlackKat's Avatar
Don't know....Depends on if the pulley is left or center aligned..
BlackKat is offline
Old 11-29-2004, 08:49 AM
  #5074
Ballsie's Avatar
Default 9805939 2x30mm Cap Screw (BB5 x2)
I'm looking for screws for the 415 diff - I believe they are this :
I can't find them anywhere online!!!
Is there an alternative (even non-tamiya) that I can use?
Alan
Ballsie is offline
Old 11-29-2004, 09:01 AM
  #5075
Turbonium's Avatar
Trader Rating: 27 (100%+)
i have used some HPI diff screws.. they were 2mmx30. had a flat screwdriver head, instead of allen tip.
Turbonium is offline
Old 11-29-2004, 09:27 AM
  #5076
raffaelli's Avatar
try www.mcmaster.com for hardware
raffaelli is offline
Old 11-29-2004, 09:30 AM
  #5077
V12
V12's Avatar
From which car? On the HPI partslist I found the Pro4 uses a 2x25mm screw and the Pro3 uses a 2x39mm screw.
V12 is offline
Old 11-29-2004, 10:32 AM
  #5078
Turbonium's Avatar
hmmm.. i dont remember which car. i think i went to the Tower Hobbies website and searched for "2x30" maybe?
might be able to use the 39s and cut it off? just a thought, in a pinch it may work.
Old 11-29-2004, 11:54 AM
  #5079
Blakesrc's Avatar
Trader Rating: 22 (100%+)
Apex,
www.speedtechrc.com makes spools for the 415, i just got one and they are very nice. If you go to their website and click on "aftermarket parts" on the left, then on "speedtech hopups" you will find them there. I dont think he has any in stock for another week or so but its worth the wait. As for a diff, looks like everyone is making them from a combination of yokomo and tamiya parts. If you look through the last 8-10 pages on this thread you will find a couple of parts lists that will help you.
Blake
Blakesrc is offline
Old 11-29-2004, 01:50 PM
  #5080
Ballsie's Avatar
Thanks for your replies guys - I think I have managed to source the tamiya ones
Ballsie is offline
Old 11-29-2004, 02:57 PM
  #5081
dawgmeat's Avatar
Default Raul Garcia a 415 guy?
He finally did it, welcome to the 415 family Raul. This has been confirmed and Raul if you ever feel the need to miss that purple Mi2 of yours you can add these purple parts to your 415
For starters the part that you need" castor block"
http://integy.automated-shops.com/cg...05104396432.47
All this stuff should keep you from getting home sick
dawgmeat is offline
Old 11-29-2004, 03:12 PM
  #5082
Trader Rating: 78 (99%+)
Default the change
Thanks Dawgmeat. I made a step to the darkside I know. Now I can be fast like you and Carl G...., and dont forget Raf..
Raul Garcia is offline
Old 11-29-2004, 03:28 PM
  #5083
raffaelli's Avatar
Raul,
I am glad that you have come to this side young grasshopper. Finally, you are doing the right thing!
Noe try to find some parts!
Old 11-29-2004, 05:16 PM
  #5084
Speed Demon's Avatar
Default difference between 415 & 415MS
what are the difference in terms of parts that's inclued in the kit??
Anybody??
Speed Demon is offline
Old 11-29-2004, 05:22 PM
  #5085
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: difference between 415 & 415MS
Anybody??
LW suspension
heatsink bulkhead
low friction belts
revised front and rear shock towers
2.5mm lower chassis
more info can be found on the tamiyausa.com website.
Hebiki is offline
