Like Tree2Likes
Tamiya TRF415
Old 11-26-2004, 07:44 AM
  #5041
prodrive's Avatar
Default to masa
a couple of months ago i was in tokyo and i went to one of your store in akihabara. at that time i wanted to buy trf 415 but it was out of stock. i was only visiting japan for a week, so i couldnt wait, but any way i ended up spending alot of money, around total of 70000+++ is spare parts and option for trf 415, tb evo 3, and trf 414. any way, when i got back to indonesia i immediately bought trf 415 and hop it up. now its exactly the same as the ms version except for the shock tower. so if you have in stock the front and rear shock tower of the 415ms edition and also the low friction belt, please pm me and may be we can arrange something. i think that your store is great and you have good prices. i still have so many things that i wanted to buy but i could not fit it into my bag.
prodrive is offline
Old 11-26-2004, 08:24 AM
  #5042
TC3
TC3's Avatar
Originally posted by Leini
i changed my 415s front suspension a bit. i put the evo4 c-hubs in the old 415 sosupension.v12, what is "kein spiel mehr" in english??? it fits perfect and i can change the castor now....
i think i can help
to eliminate slop, u can use the evo4 c-hubs with the old suspension..
for the ones who don't know, leini is one of the fast guys here in germany, his sugestions are worth to be tried out.
TC3 is offline
Old 11-26-2004, 08:52 AM
  #5043
Hardriven RC's Avatar
"No more play"
Hardriven RC is offline
Old 11-26-2004, 09:38 AM
  #5044
koabich's Avatar
Default 415 Steering
Hey guys,
I have been running the 415 on carpet with foams and love it. I just need to get a little more steering...
This is the first Tamiya I've had since the Frog. I was wondering if there is any way to get the slop out of the steering. The steering racks are able to move up and down on the posts and the carbon firber piece that attaches to each rack has some play where the bearings fit.
What have you guys done to remove this slop?
koabich is offline
Old 11-26-2004, 09:49 AM
  #5045
Tamiya has spacers you can use to take the slop out of that and other places.
Don't know the exact part numbers, but they are being refered to somewhere on this thread.
Old 11-26-2004, 11:05 AM
  #5046
Leini's Avatar
i think "no more play" is not that right, but thanks
i don't have any pics but perhaps i'll meet v12 at the next cs-cup and he could do some....
one more important thing:i removed the servo saver and put a fixed steering arm on the servo. i couldn't believe how much better the car is to drive. it's so exact now...
Leini is offline
Old 11-26-2004, 11:16 AM
  #5047
Leini,
Doch ist es so.
The translation i mean
Old 11-26-2004, 11:30 AM
  #5048
raffaelli's Avatar
Cars here. Will start building after lunch.
raffaelli is offline
Old 11-26-2004, 12:06 PM
  #5049
TryHard's Avatar
Default Re: 415 Steering
Originally posted by koabich
Hey guys,
Hi Koabich,
on mine to stop the posts moving up and down I run 3 of the 0.1mm axle spacers (the ones that you place between the hub bearings and the hex retaining pin). I place 1 between the bottom alloy collar and steering arm (underneath) and the other two on top of the arm, beneath the two alloy spacers.
completely eleminates all the slop, works well.
HiH
Ed
TryHard is offline
Old 11-26-2004, 01:25 PM
  #5050
V12
V12's Avatar
some people say slop and some say play. Play sounds a little weird but should be OK as long as everybody understand this.
Leini
your modification is interesting. Does it really make a difference in slop or is it the old hub was worn a little?
When is the CS-Cup and what track?
V12 is offline
Old 11-26-2004, 02:30 PM
  #5051
dawgmeat's Avatar
Default carpet set up
Does anybody have a carpet set-up for the spool?
dawgmeat is offline
Old 11-26-2004, 04:09 PM
  #5052
Leini's Avatar
v12, in sandhausen am 12.12.
its a really big difference.i'll show you....
Leini is offline
Old 11-26-2004, 04:49 PM
  #5053
koabich's Avatar
Default Re: Re: 415 Steering
Originally posted by TryHard
Hi Koabich,
HiH
Ed
Thanks...I will try that. Unfortunatley the only shims that came with my car were for the diff. I will have to pick some of those up!
koabich is offline
Old 11-26-2004, 09:17 PM
  #5054
raffaelli's Avatar
Whats the deal with the battery slots? Why arent they rectangles?
Old 11-26-2004, 10:57 PM
  #5055
Blakesrc's Avatar
Trader Rating: 15 (100%+)
Dawgmeat,
Jimmy Jacobson just posted his carpet/foam tire spool setup on rcracing.com, take a look here...
http://www.rcracing.com/msgthread.cf...iteMessages=19
Blake
Blakesrc is offline
