Old 11-23-2004, 01:30 PM   #4996
raffaelli's Avatar
Default HELP!!!!
Where are all the kits!??!??!???!
I can't seem to find them. I need 4!!!! Plus hop-ups and spares. Does anyone have an inside track that I could get in on?
24ITA
raffaelli is offline   Reply With Quote
Old 11-23-2004, 01:40 PM   #4997
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Default Re: HELP!!!!
Our shop has at least one and possibly two in stock. You can call RCO Hobbies in Hanover PA and ask for Allison. They are open from 3PM to 8 tonight and then again on Thur and Fri 11 to 8. 717-633-9490. Tell Allison that Brian sent you.
Brian
ST Racing Concepts (STRC)
Old 11-23-2004, 01:48 PM   #4998
rcmaniax's Avatar
Default GEAR RATIO
hi there
what is the gear ratio of a 415 MS?
i want to change to 64 DP instead of Module4, which main spur gear do i have to use (no. of teeth?) for a proper work?
thank you!
frank
rcmaniax is offline   Reply With Quote
Old 11-23-2004, 01:57 PM   #4999
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Raffaelli,
I beleive speedtech has them in stock right now, check them out here, www.speedtechrc.com.
Rcmaniax,
I am not sure if the MS version you are talking about has a different drive ratio but the 415's ratio is 2.1875. I think last week sombody posted a link to this site:
http://www.thard.co.uk/rc/
It has some really nice excel sheets for gear ratios and suspension blocks.
Good Luck,
Blake
Blakesrc is offline   Reply With Quote
Old 11-23-2004, 02:01 PM   #5000
raffaelli's Avatar
thanks guys!!!
24ITA
Old 11-23-2004, 02:27 PM   #5001
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: GEAR RATIO
Originally posted by rcmaniax
hi there
thank you!
frank
edit
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-23-2004, 03:39 PM   #5002
V12
V12's Avatar
Originally posted by Carl Giordano
Thanks for the feelback. I now this was posted earlier, but does anyone know the part # for the 6mm hex.
Sounds like I will most likely stick with the Parma rims and tires. I prefer the GRP rubber. I beleive you are correct, JACO uses a different rubber compund. Besides my car ran great with the Parma's mounted.
This sunday is a race at Hobby Chamber in CT. I will most likely run the dual one-way setup and then switch to the spool to see the difference. (provided I have time, since teching electric guys is always a process.....you don't find tech headaches in nitro)
The 6mm hexes are # 53569
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 11-23-2004, 08:54 PM   #5003
maxepower's Avatar
Default trf 414.5 M2
I tried an experiment putting the 415 blocks on my 414M2. I even went so far as adding the blue alum. turnbuckles and the 1 deg. alum rear uprights, I then put the 4 mm blue hexes with the blue spacers for the wheels. Then put the short 415 shock kit with all the new blue anodized shock cap, retainers and adjusters and used the same color springs as my 415. I tested it at the Tamiya track and found the car really snapped around the corners hard but it was breaking loose in the rear coming out fo the sweeper. I ended up going to softer springs in the rear(old light blue) the car really came alive. With med. traction and cs27 tires. The car handled nice but not as good as my 415, but with all the blue anodized parts it sure looked good on my 414!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 11-23-2004, 11:23 PM   #5004
Hebiki's Avatar
Default Re: trf 414.5 M2
hey max.. are you and timmy gonna make it out to the Toys for Tots race? if you see alex and christian this weekend.. please let them know. (second sunday of dec).
lets try to have all of TAOB there and we can run mabuchi/stock again!
btw.. no tamiya for me this sat. ill be up north with family (and in gilroy racing carpet again! )
Hebiki Design Works
Old 11-23-2004, 11:54 PM   #5005
maxepower's Avatar
Default Toys for tot race!
Chris,
I'm planning on going but were we going to do the thing at California speedway? Isn't that in December also? Isn't Charlie organizing the race? I will let Alex and Christian know about the toys for tots race and if you tell me your speed secrets for the Mabuchi motor I would love to do that race!
Max
Old 11-24-2004, 02:55 AM   #5006
Hebiki's Avatar
max..YGPM
Hebiki Design Works
Old 11-24-2004, 08:22 AM   #5007
Trader Rating: 74 (100%+)
Default the point
Raf,
I just want to settle a little confusion, I was not calling in reguards for myself, I was calling to see if you had gotten a better price. You have, gotten a price, but it really is not good now is it. You should have just gone with your innermost feelings! Good luck with your second mortgage.....
Carl G.,
I hope to meet up with you @ HC on Sunday, but not sure yet. We will talk then. Make sure you wash your TRF shirt/ wardrobe for the next race day...
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 11-24-2004, 08:26 AM   #5008
raffaelli's Avatar
Default Raul is jealous of pretty blue
I will be placing the order for the kit today (raul....price is not object when it comes to putting you a lap down )
I will get the low friction belts, front A and flourentine suspension balls. Anything else I need?
24ITA
Old 11-24-2004, 08:45 AM   #5009
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Chris: get the belt tensioner (part #?)
Tamiya Gray / purple springs #'s 53635 & 53636
and a really cool TRF shirt.
YES Raul: I have my TRF shirt on so everyone knows what chassis I'm kicking you a$$ with.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-24-2004, 11:21 AM   #5010
Hebiki's Avatar
Default Re: Raul is jealous of pretty blue
Hopups:
Lightweight suspension - $85
TRF blue threaded shock caps, cap bottoms, and collar. - $35
Aluminum shock retainer - $7
Heat sink bar (for stiffening the rear bulkheads) - $5
Ceramic bearings - $100
Finishing 9th ...and you friend finishing 10th... PRICELESS!
(its hilarious how you guys talk trash.. its very identical to how me and my friends talk trash! )
Hebiki Design Works
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
