Old 11-09-2004, 10:41 PM   #4771
JimmyMac's Avatar
Forty6, yeah.. passing up on the SDW. The yok looks cool and all. But I don't like how the batteries sit farther back. Plus it looks to be a pain to maintain. Just looking it over in the Japanese RC World mag. Also, sometimes I run on parkling lot tracks.. so the open diff is a no-no. I'm pretty satisfied with my RaySpeed SD. Plus I'm looking forward to the new RaySpeed chassis for more battery placement forward (trying to get it like a TC3/4 with battery forward). Anyways.. I'm selling my 415 for $200 to offset the cost of the 415MS. Not that I need the MS. But it would be nice to have. The 415 is just an awesome smooth car. Can't wait til asphalt season opens back up......... next year... Till then... TC4 on carpet.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-09-2004, 11:08 PM   #4772
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
KilRuf..
There are a few people looking for a 415 in the Wanted section... you should be able to sell that thing rather quick
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-10-2004, 01:02 AM   #4773
Anyone know where to find a 415 setup sheet for the LW suspension?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 11-10-2004, 02:53 AM   #4774
Hebiki's Avatar
Trader Rating: 26 (100%+)
its coming... i made one. it should be up on the TAOB Racing site sometime tomorrow.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-10-2004, 04:23 AM   #4775
Trader Rating: 45 (100%+)
Default trf 415
does anyone know the part numbers for the yokomo differential parts that will fit the 415?
Apex is offline   Reply With Quote
Old 11-10-2004, 07:25 AM   #4776
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Kilruf: ask Anthony S. to give me a call (201) 788-5525 or use my new e-mail [email protected]. The ROAR webstie should have been updated with my new contact information.
Koabich: My Tamiya Frog kicked ass in straight line racing. Thorp diff and an astroflight motor....sweet. What really sold me on Tamiya was the Holiday Buggy.
Apex: yok diff set: MR4TC ZS-501
V12: Thanks for the spur gear update. I was on the speedtech site and I can't believe how many Xenon gear sizes are availble. Not sure what range to start with for stock. Someone earlier mentioned 100-102. That seems small for a touring car?
And for the record, Raul's Mi2 has some modifications. Its really an Mi2BMITRF chassis. Which will be paired against my stock TRF 415.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-10-2004, 07:39 AM   #4777
Ballsie's Avatar
Default Re: trf 415
What you need is:
Yokomo
1 x ZS-501 DIFF HALVES - you will get two sets one for the front and one for the rear. you will use the REAR parts, these will have the equal spacing for the outer bearings. It's obvious, as the other set is offset (like it is on the rear diff of the TRF 415).
ZS-506 DIFF RINGS - you will get two (i believe you can use the Tamiya ones too, but I thought it best to use the Yokomo ones just incase).
ZS-507 THRUST BALLS AND WASHERS - these are a real pain! You use both washers and about 6 of the small bearings (you can use ZC-507T if you want Tungsten Carbride Balls, but I couldn't find them anywhere.
ZS-508 DIFF SCREW AND LOCK NUT. - you will get 2 of everything but you only need to use one.
Tamiya
1 x 51055 TRF415 Ball Diff Pulley - the one that's on the rear of the car as standard
1 x 53124 3mm TUNGSTEN-CARBIDE DIFF BALL SET - you could use any 3mm balls, but I think these ones are extremely smooth, they are quite pricey tho
1 x 51092-Tamiya TB Evolution IV,TRF415 46mm Swing Shaft - you could use the aluminium ones too, but I used these just to be on the safe side.
Misc.
Ball Diff grease of some sort, I am using Team Associated Stealth Lube as it was recommended to me by Apex Models (It's much cheaper than the Tamiya stuff too).
2 x 850 Size Ballrace Bearings
Hope this helps
Ballsie is offline   Reply With Quote
Old 11-10-2004, 10:25 AM   #4778
V12
V12's Avatar
Carl
No problem. Yes there are a lot of spur gears available from Xenon.
Its just a pain finding the right one if you have soo many choices.
Im using a 72 teeth/48 DP gear currently on my TRF415. This is the same size as a 96 teeth/64 DP. Works very good and Im running 27T or 17T motors usually.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 11-10-2004, 10:35 AM   #4779
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by V12
Carl
V12, I've ordered some Kimbrough spurs - I couldn't find the Xenon ones except in Japan and other far away places (Bamberg for example *cough* )
Hopefully the Spurs won't take too long - when they are here I shall take a couple of days off work and test the 415 against the Xray fully!
markp27 is offline   Reply With Quote
Old 11-10-2004, 10:54 AM   #4780
V12
V12's Avatar
Mark
The gears sold with the Yokomo SD or HPI Pro4 are Xenon gears.
Also available as spares.
Will post a picture later.
Old 11-10-2004, 10:58 AM   #4781
markp27's Avatar
Mark
You mean I should buy a Yokomo or HPI, so I can get the gears
Old 11-10-2004, 11:07 AM   #4782
V12
V12's Avatar
.... and throw away the rest of the parts as you dont need them.
Old 11-10-2004, 11:14 AM   #4783
V12
V12's Avatar
Heres a picture Xenon vs Yokomo gear.
Old 11-10-2004, 11:16 AM   #4784
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Should i buy a 415? i live in Florida and i dont know if theres any parts support here ?
Roberto Falcon is offline   Reply With Quote
Old 11-10-2004, 12:28 PM   #4785
You can get spares from speedtech ( www.speedtechrc.com ), i don't have a 415 but i know speedtech have lots of parts for it
Chazz
Chazz is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
