Tamiya TRF415
#4667
Re: 190mm
Originally posted by dawgmeat
I'm back to the stock arms, anyway will i exceed 190mm using 28mm foams tires, what is max amount of spacers that I can use without exceedind 190mm?
A1 and C1 front blocks
1.5mm worth of spacers on each corner.
#4668
Hi koabich
I race a 415 at larry's performance rc. I do pretty good with it with foam tires. I have done some modifications to my car so that I can run foams without to much interference. I was wondering who you are since it says you are from the detroit area. Do you run at larry's, if so drop me a line and I can share set ups with you. Its good to see another tamiya driver at larry's I seem to be the only one.
#4669
Originally posted by mrodney
Hi koabich
Hi koabich
I posted my carpet set up a couple pages back. i am still tweaking it but so far I love the car. I have the front diff from the guy in Germany and have made other typical changes to the car so I can run it on carpet. I also have gotten it so I can run 28mm foams with no rubbing. I would love to know your setup!
Talk to you soon!
Joe
#4670
And you are ?
#4671
And you are ?
And you are ?
#4672
I contacted the guy from germany about the diffs, he responded but he didn't tell me how much a set would cost. What did you pay for the set of diff halfs from jergen.
#4673
#4674
koabich
regarding the aluminium frontdiff there were some changes in the meantime for some reasons. Jürgen started with the EVO3 diffrings as at that time the 415 diffrings were hardly available here. Now also the 415 diffrings can be used so both should work now. Regarding the blades this seem to work even better but was developed later. I have to say I never heard of much wear with the diffhalves. I have no personal experience in this area but I know Alan from the UK is using one of the very first samples of the frontdiff. Itīs a long time since heīs using the frontdiff and from what he told me he has very little wear after all the time. Donīt know exactly but maybe itīs a good idea using some Tamiya Antiwear grease in this area if blades arenīt used.
Regarding the blades there are two versions. The Corally blades are the ones Jürgen used during redesign of the diff. Later he made some own blades using a lowfriction stuff (something as Teflon) but I have heard now downside is this isnīt as strong as the Corally blades. As itīs very new I donīt know if anybody tried the new (white) blades. I just got my diffs now but I have to wait until I get all the other parts as I have no diffrings, diffspring and thrustbearings here.
#4675
Hi, it's nearly the winter season over here in the UK (or it's just started) and i'm going to be racing on high grip carpet which is on quiet a big circuit. I was wondering what the 415 is like on carpet in stock . At the moment i've got $540 to play with, from selling a few of my un-wanted cars and i want really the best i can aford. Also after the winter i'll be racing outside on ashphalt . Is there anything bad about the 415 and any tips on building it and any set up difficulties.
Thanks Chazz
Thanks Chazz
#4676
Originally posted by V12
koabich
koabich
I might have to get a new set if they can currently use the 415 diff rings, it sucks having to stock 2 different sets. For the parts you need check out a store on ebay called walawala. The guy is located in Hong Kong. He has the best pricing (by far) and you get the stuff quick. The pricing he charges for shipping from Hong kong to the states is much cheaper than if I were to pay shipping by ordering the parts from stores in the States. It usually takes 1.5 weeks to get something from him. I have done over 80 ebay transactions with him...he is good!!
#4677
Hmm I think for a set of new diffhalves you could buy a lot of diffrings. So if it works now there isnīt really a need for new ones.
But maybe you could just file away a little so the 415 diff rings will work.
#4678
Thanks on the advice with walawala.
#4679
Originally posted by koabich
Yeah, I thought it was weird that they would wear so fast but they did! I started using the Corrally blades and everything is now fine. I did have to woden the slots in the outdrives but now, with the blades, they work perfect.
http://stores.ebay.com/WalawalaStore...isplayZ2QQtZkm
this is there ebay store.
http://search.stores.ebay.com/ws/sea...textsearched=2
