Like Tree2Likes
Tamiya TRF415
Old 10-26-2004, 12:51 PM
  #4441
Formula1fan's Avatar
I run tamiya shocks on a different car. Is there a part number for a shock rebuild kit?
Formula1fan is offline
Old 10-26-2004, 02:29 PM
  #4442
Regional Moderator
kansasracer's Avatar
Setup sheet, anyone...
editable with LW suspension?
kansasracer is offline
Old 10-26-2004, 06:02 PM
  #4443
ngo8's Avatar
rebiuld what? only 2 orings no?
ngo8 is offline
Old 10-26-2004, 07:09 PM
  #4444
TryHard's Avatar
Check the link in my sig, you'll find a lightweight suspension sheet there, plus a few other extras I find useful (plus removal of japanese texts, and a few other bits)
Regards
Ed
TryHard is offline
Old 10-27-2004, 05:02 AM
  #4445
Sorry never took them apart to check, just looking to do some preventative maintenance
Old 10-27-2004, 05:04 AM
  #4446
Hardriven RC's Avatar
It took me a while because i overlooked your post but here is your answer,
TRF Damper Rod Guide & O-Ring Set (4) 53574
Hardriven RC is offline
Old 10-27-2004, 05:39 AM
  #4447
|8t
|8t's Avatar
Originally posted by dawgmeat
www.yokomousa.com
look under parts list
We ship to USA address only!
this is my prob...I live in Canada!
|8t is offline
Old 10-27-2004, 07:22 AM
  #4448
Hi I'm new to this forum but I remember reading peoples posts about the ooo1 worlds 414m2 motor plate.
Here it is.
ashto is offline
Old 10-27-2004, 10:21 AM
  #4449
SpeedTech's Avatar
Formula1fan,
I believe the o-rings, shock guide and spacer is part number 53574 (going off of memory here so someone correct me if I'm wrong) and the pistons are: 53572 (2 hole), 53573 (3 hole)
Steve Wang
SpeedTech is offline
Old 10-27-2004, 10:22 AM
  #4450
SpeedTech's Avatar
We ship to Canada
Steve Wang
Old 10-27-2004, 10:46 AM
  #4451
|8t
|8t's Avatar
thats cool but can you get me a complete front diff for the 415???
|8t is offline
Old 10-27-2004, 11:14 AM
  #4452
koabich's Avatar
If you are having such problems finding the parts for a front diff, do what I did, look a couple of pages back and order the aluminum outdrives from the guy in germany. You use all the stock Tamiya parts and the quality is excellent. If you order your diff from him you will need all the standard stuff that Tamiya used for the rear diff (gear, bearings, thrust bearing, diff rings, balls, diff screw...etc.). All this stuff can be found on Ebay for really cheap.
koabich is offline
Old 10-27-2004, 12:55 PM
  #4453
dawgmeat's Avatar
Default making the the switch from Yok CGM to 415 thursday
I love my CGM, but I want try new things. I understand that to get the 415 set up for carpet will take a great deal of work, i.e front and a center lock layshaft.
Can some body give the part # for the locked layshaft pulley for the 415 and 3MM diff balls because I plan Buying this from speed tech tomorrow.
To back me up ,these are the parts that i need:
TAMIYA 51092 Tamiya EVO IV 46mm Swing Shaft (standard arms)
TAMIYA 51055 415 Diff Pully
TAMIYA 53522 F201 Unversal shaft (for LW conversion)
YOKOMO ZS-501 Diff Joints
YOKOMO ZS-506 Diff Rings
YOKOMO ZS-507 Diff Thrust Bearing Set
YOKOMO ZS-508 Diff Adjusting Kit"
P.s. I know what a lot of you are thinking" just learn how to drive the car first", true. Unlike most of you on the west coast who have to drive for hours to find a carpet track, there two major carpet tracks within 50 minutes away from me, beside I'm station in CT., outdoor racing is long gone.
dawgmeat is offline
Old 10-27-2004, 01:12 PM
  #4454
forty6's Avatar
53379 3mm LIGHTWEIGHT DIFFERENTIAL BALL SET
53708 Tamiya TRF415 Center Direct Pulley
forty6 is offline
Old 10-27-2004, 01:20 PM
  #4455
forty6's Avatar
You can also get 10mm shims to take out some play and center the pulley better.
forty6 is offline
