Old 10-15-2004, 11:26 PM   #4306
ghoppa's Avatar
Trader Rating: 54 (98%+)
Default set up
anybody got a good starting set up for "mod" for Scott's track in Hesperia????
couple of us Vegas guys are heading over there on Sunday.
ghoppa is offline   Reply With Quote
Old 10-16-2004, 01:27 AM   #4307
Default Re: Diff Balls
Originally posted by 190mph
Actually a good place to buy diff balls for Silicon Nitride if you don't mind spending up front to buy a bag of 100 is Salem Specialty Ball Company. There is no minimum order. I am going to order some 100 packs of 3/32" and 3mm.
I had a quote in March 2002 for 3/32" at $0.64 each for 100 qty that I was going to use for the TC3. That is grade 5 ones. 100 pcs will last for a long time.
I am going to order some this week.
Isn't Si nitride balls commonly called ceramic balls? 64cents each is not bad considering it is sold for more than a buck each. Good find John.
nolan_racing is offline   Reply With Quote
Old 10-16-2004, 08:26 AM   #4308
Yes Silicon Nitride is a Ceramic. This is the 2nd hardest material after diamond. Their website claims no lubing required as the balls are very spherically correct (round) being Grade 5 or 3 and that the ball is so hard it can work with the diff rings with no lube.
That is actually better as it won't attract any dirt towards the rings and diff pulley area. It should work longer as it won't build up grit like a lubed up one. It should even keep the diff rings better longer.
I was thinking at one time to also get my diff rings coated for all my cars (TRF415, TC3, NTC3, B4, RC12L4) with Titanium Nitride or Graphit-IC (Diamond Like Carbon) coatings but I think the diff would just never work right as you would have 2 super hard surfaces and you need probably a little give on the rings. That is why some people sand the rings with very fine sandpaper to remove the grooves created by the balls and allow some grip for proper diff action. Some people sand new rings to take the smooth finish off from the factory.
I will call Salem on Monday and post the price I got so anyone interested can call and order a bunch. If you buy a thousand and split it up with 10 friends you would probably save another 15 to 20 cents per ball. Remember that 64 cents per ball I said a few posts ago for 3/32" size, well in a pack of 1000 they were quoted at 45 cents each. I have a feeling 3mm will be slightly higher prices being metric and not overly common.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-16-2004, 09:37 AM   #4309
wont that just totally screw up the diff rings though?
Evo_Uk is offline   Reply With Quote
Old 10-16-2004, 11:30 AM   #4310
I checked their website and it's pretty cool. I'll probably opt for the tungsten carbide though because ceramic balls tend to eat up diff rings quickly, plus it might be cheaper. They said you can order from 1 to 1 million balls.
Old 10-16-2004, 12:53 PM   #4311
PizzaDude's Avatar
Could you post or PM me the URL please.
thanks dude
PizzaDude is offline   Reply With Quote
Old 10-16-2004, 01:03 PM   #4312
Yes they have 2 websites:
http://www.salemball.com
http://www.salemballworldwide.com
Old 10-16-2004, 09:36 PM   #4313
foampervert's Avatar
Send a message via MSN to foampervert
Default wheelbase question...
hiya guys!
thanks for looking in, any opinions will be greatly appreciated!
our local track is a small twisty affair. the main straight is only about 30 meters long.
does a short wheel base help in this instance?
i have ta04 SS arms i wish to try on my 415... is that a good idea?
the rear axles become angled forward , is this ok? won't this cause a lot of friction?
-FP
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 10-16-2004, 10:24 PM   #4314
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: wheelbase question...
Originally posted by foampervert
hiya guys!
-FP
one of the local fast guys here once put in the SS arms on his 414...and he was wicked fast. his car rotated very well and lots of steering. this year.. he won the North America 2004 TCS Nationals. might wanna ask him how much it helped?
adding the SS arms is a lot of work.. if you have plenty of track time i say do it. if not, you can just shorten the wheelbase by adjusting the spacers on the regular suspension arms. OR if you pick up the lightweight set... it has more tuning options for setting wheelbase. you can actually get it really short.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-18-2004, 12:04 PM   #4315
Does someone tried to run a spool on carpet with Rubber tyres?
Do you prefer One way or spool on these conditions?
Hugo is offline   Reply With Quote
Old 10-18-2004, 12:15 PM   #4316
Hi, i was wondering what the trf 415 is like on high grip carpet and outside on tarmac with different grips. Also i was wondering what are the usual parts that brake on the 415 and what option parts i should get for xmas if i deside to get the 415 (by the way i'm running stock 27t motor)
Chazz
Chazz is offline   Reply With Quote
Old 10-18-2004, 12:20 PM   #4317
Default jurgen diff halfs
Can someone post a website or email address for this jurgen person. I am interested in purchasing a set of front diff halfs for the 415, and I havent seen a way to get in touch with him. I am currently using the yokamo set up and it does work well but I broke one of the diff halfs, so the alluminum ones would work out pretty well. Also please do not reply with a vague reference of
"YGPM", what the heck does that mean.
mrodney is offline   Reply With Quote
Old 10-18-2004, 12:24 PM   #4318
RandyB's Avatar
You've Got Personal Message.
YGPM
Someone has sent you a message check your forum inbox
RandyB is offline   Reply With Quote
Old 10-18-2004, 12:56 PM   #4319
hey randy B. Thanks ygpm "you got personal message" right. Ok well that part is solved I still need to know about this jurgen diff guy, so if anyone out there knows drop the link to this person or his company or what ever.
Old 10-18-2004, 01:19 PM   #4320
Default Re: jurgen diff halfs
mrodney,
It means "you've got mail" basically.
Obsidian is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
