Like Tree2Likes
Tamiya TRF415
Old 10-15-2004, 11:43 AM
  #4291
linger's Avatar
Default Tweak
So how do you guys avoid tweak on the 415? I noticed that one good hit and the car tweaks significantly. It seems as if all the tweak is coming from the front of the car where the spacers connect the top deck with the mid deck. Once I loosen the screws, you can see the top and mid decks snap back to place.
linger is offline
Old 10-15-2004, 11:47 AM
  #4292
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Tweak
ling... my car was hurting at ROAR12 due to the tweak you mentioned. when tyree helped me out with my car... i noticed he REALLY cranked down on the screws.. kinda scary how tight it was. next time i jumped a board.. it became loose again.
has anyone counter sunk the top deck? and if you have.. does it help?
Hebiki is offline
Old 10-15-2004, 12:38 PM
  #4293
Another option that has been done by Dsrbltoys is to countersink all of the locating points on the mid decks. Not sure how effective it has been.
I have gotten in the habit of taking the tires off each round and loosening the topdeck on a flat plate and then putting it all back together.
Difuser is offline
Old 10-15-2004, 12:40 PM
  #4294
linger's Avatar
Hebiki - I'm already using countersunk screws on the topdeck!. Countersinking the topdeck won't help....the screws don't shift there. The screws are locked into the topdeck, but upon impact, the screw bend a little and the blue spacers between the top deck and mid deck shift.
linger is offline
Old 10-15-2004, 12:44 PM
  #4295
linger's Avatar
Dsrbltoys gotta figure out a way to lock in the blue spacers to the mid deck.
linger is offline
Old 10-15-2004, 12:48 PM
  #4296
Hebiki's Avatar
ling.. YGPM. ill try some things this weekend..and let you know.
Hebiki is offline
Old 10-15-2004, 01:14 PM
  #4297
maxepower's Avatar
Default Re: Tweak
I remember seeing Surikan's car or reading his set -up somewhere, I don't remember but I thought he had eliminated the mid-deck or just didn't use the posts that attach the deck with the screws only, which I guess would allow the chassis to flex but not tweek? Food for thought!
Maybe? Something to consider!
Just my 2$
maxepower is offline
Old 10-15-2004, 01:21 PM
  #4298
over gear's Avatar
Trader Rating: 16 (100%+)
Default Re: Tweak
linger crash?!
over gear is offline
Old 10-15-2004, 02:12 PM
  #4299
Default 1/8 diff balls
Will 1/8 diff balls fit the diff pulley? 1/8 is 3.125mm if I am not mistaken. It is more accessible to me than 3mm diff balls.
elnitro is offline
Old 10-15-2004, 03:22 PM
  #4300
linger's Avatar
Default Re: Re: Tweak
Originally posted by over gear
linger crash?!
Me crash? Err....I'm asking about chassis tweak for a friend... yeah, that's it.
linger is offline
Old 10-15-2004, 03:46 PM
  #4301
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: Tweak
Yo have a PM
JDM_DOHC_SiR is offline
Old 10-15-2004, 05:21 PM
  #4302
Whoa.....looks like Tamiya decided to bring out "another" car. Saw a pic on the net...the $415MS.
It looks good. Not sure what else is new besides the suspension. Wonder if they're gonna release an update kit with all the mods. for you $415 owners.
dasupacat is offline
Old 10-15-2004, 05:56 PM
  #4303
Default 1/8 Diff Balls
elnitro,
I was hoping for the same as I could not find any 3mm Diff Balls anywhere. The one hobby shop that has them I frigen forgot to buy them at and they are over 100kms away. I just bought some RC12L 1/8 balls and tried them. They do not fit. Shoot!
1/8" = 3.175mm , BTW
Need exactly 3mm for those inner holes on the diff pulley.
190mph is offline
Old 10-15-2004, 06:06 PM
  #4304
koabich's Avatar
Default Re: 1/8 Diff Balls
Originally posted by 190mph
elnitro,
You can order them directly from Acer or Schumacher.
koabich is offline
Old 10-15-2004, 07:11 PM
  #4305
Default Diff Balls
Actually a good place to buy diff balls for Silicon Nitride if you don't mind spending up front to buy a bag of 100 is Salem Specialty Ball Company. There is no minimum order. I am going to order some 100 packs of 3/32" and 3mm.
I had a quote in March 2002 for 3/32" at $0.64 each for 100 qty that I was going to use for the TC3. That is grade 5 ones. 100 pcs will last for a long time.
I am going to order some this week.
190mph is offline
