Like Tree2Likes
Tamiya TRF415
Old 10-13-2004, 04:38 AM
  #4261
Ballsie's Avatar
excellent - thanks!
Ballsie is offline
Old 10-13-2004, 06:30 AM
  #4262
Arrow diff mod
For people who used the YOK diff for the front, how does it hold up? Any problems running the plastic outdrives in mod?
nolan_racing is offline
Old 10-13-2004, 06:34 AM
  #4263
Turbonium's Avatar
Trader Rating: 27 (100%+)
i have run the Yoke stuff with plenty of 19T, but not a lot of open modified... so far it has held up fine. no notching or breaking as of yet. ...
Turbonium is offline
Old 10-13-2004, 09:40 AM
  #4264
Nolan there is a touch of notching with Foam Mod but nothing to be overly concerned about. Mine is right at the end of the outdrive where the shimming was a touch off.
Difuser is offline
Old 10-13-2004, 10:46 AM
  #4265
Thanks for the response guys, now to locate those outdrives.
Old 10-13-2004, 11:15 AM
  #4266
V12
V12's Avatar
Originally posted by Leini
ok, tell me about your test then....
Leini
it seems you´re here more often now
V12 is offline
Old 10-13-2004, 12:37 PM
  #4267
TJ
TJ's Avatar
Thanks for the info is that setup with the long arm set on the 415
@hugo:
there are different ways to messure the droop. on a medium traction asphalt track i drive almost the same droop front and rear. prettx less. i can lift the car 1 or 1,5mm then the tyres loose the ground contact.got me?
setup:
front
blocks a/a
caster 2degr
camber 1 or 1,5
no toein/toeout
dampers: 40/2 hole with tamiya yellow or asso silver
wheelbase1,7mm front of susp.arm, 6mm behind
no anti squat, rollcenter
damp.pos.:damper stay outside, arms outside of the 2 holes
rear:
blocks x/b or c (with 1degr. tamiyaalu hub c.)
camber1 or 1,5
dampers 40/2 holes, same springs
wheelbase5 front, 2,3 behind
no anti s, or rollc.
damp.pos.:damper stay outside (hole #5), arms insideof the 2 holes
no anti roll bars. i use the mazda.
hope this works on your track...
TJ is offline
Old 10-13-2004, 12:41 PM
  #4268
Turbonium's Avatar
judging by the amount of spacers he is listing on the arms, id say it almost has to be the new LW suspension. no way to use 7+mm of spacers without those narrower arms.....
Old 10-13-2004, 01:25 PM
  #4269
V12
V12's Avatar
It is the new suspension.
V12 is offline
Old 10-13-2004, 01:26 PM
  #4270
Hi, i was wondering if the suspension arms/wishbones are the same front and rear left and right
Chazz
Chazz is offline
Old 10-13-2004, 01:29 PM
  #4271
Also if the suspension arms come in a pair or on their own like the xrays
Chazz
Chazz is offline
Old 10-13-2004, 02:36 PM
  #4272
Turbonium's Avatar
they are front and rear... left and right are the same. not sure how they are sold, tho...
Old 10-13-2004, 03:07 PM
  #4273
Leini's Avatar
v12, it looks like....
samstag werde ich nochmal in auheim die aufhängungen vergleichen,dann poste ich nochmal meine grandiosen erfahrungen.
o sorry guys....
Leini is offline
Old 10-13-2004, 03:21 PM
  #4274
JimmyMac's Avatar
Old suspension arms are sold as a complete set (4arms) for around $16. The LW arms are sold with 1 front arm and 1 rear arm.
JimmyMac is offline
Old 10-13-2004, 04:07 PM
  #4275
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Too much talking...
hey guys.. my TRF415 is getting a lot of chatter up front... any ideas on what it may be? im running the LW suspension on there now
Hebiki is offline
