Like Tree2Likes
Tamiya TRF415
Old 09-29-2004, 04:06 PM
  #4006
ngo8's Avatar
Default Re: 415 on carpet / foam
Originally posted by Martin Crisp
dr_hfuhuhurr,
I ran the 415 on carpet foam last winter at a number of events with high grip. When I first got the car I ran it with the one-way on foams -- fast but not easy to drive and be consistent. So I made a front diff and like the car much more.
Comparing the evo 3 vs. the 415 on carpet, i much preferred the 415. The evo 3 had too much steering...I thinnk due to a more flexible chassis. I glued two upper decks together on the evo 3, which helped it a lot, but the 415 being stiffer just seemed more stable and much easier to drive hard and fast.
hey martin do you have a set up for carpet foam youre websit doesnt work anymore thanks.
ngo8 is offline
Old 09-29-2004, 05:10 PM
  #4007
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default TRF415MS
coming soon!!!
http://www.tamiya.com/japan/hobbysho...0410/news2.htm
Hebiki is offline
Old 09-29-2004, 05:41 PM
  #4008
Hebiki's Avatar
Default Re: Re: 415 on carpet / foam
Originally posted by forty6
Martin,
What car did you use at the TCS Nats? Can you pls. post your setup? Thanks.
all the past champions used a TA04. he posted his set up on the Tamiya Championship Series thread in the Racing forum.
Hebiki is offline
Old 09-29-2004, 06:41 PM
  #4009
forty6's Avatar
Thank for the info Hebiki.
forty6 is offline
Old 09-29-2004, 07:18 PM
  #4010
forty6's Avatar
Default Re: TRF415MS
Originally posted by Hebiki
coming soon!!!
Rough translation:
The highest peak of 2 belt drives 4WD of TRF415MS chassis kit ƒ^ƒ~ƒ„, TRF415. The data which is obtained from numerous race/lace the fact that you bet the further polishing on the efficiency on the basis of continue to evolve always is fate of the top model. This time the section was taken a second look e.g., suspension mount position of ƒ?ƒ?ƒfƒbƒL is modified in order to obtain optimum setting attendant upon installing the popular lightweight reversible suspension set. Road surface following characteristic of suspension furthermore is raised, more sharpness sharp cornering is shown.
RC limited sale commodity 1/10 RC TRF415MS CHASSIS KIT (49349) * ƒ?ƒ?ƒfƒbƒL of the carbon make from 3mm modifies thickness in 2.5mm and refining rigid balance. * As for new model rear bulkhead heat sink standard equipment. * As for the front and back damper stay as for form it modified also damper installation position of course.
Release date: 11/25
forty6 is offline
Old 09-29-2004, 08:20 PM
  #4011
JimmyMac's Avatar
I'll just wait for the 416...
JimmyMac is offline
Old 09-29-2004, 08:41 PM
  #4012
Dave,
So what's the rumor for the 416. can the 415 be updated to a 416?
tcmerf is offline
Old 09-29-2004, 09:02 PM
  #4013
Isn't the tub-chassis 415 (aka: TA05) gonna come out before that?
The Black Kat is offline
Old 09-29-2004, 09:03 PM
  #4014
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by tcmerf
Dave,
STill way way early for that,..... Hahahahaha... ...I don"t even know that much... but I can pick the brains of my sorce a little bit more on Sunday
-Dave
JDM_DOHC_SiR is offline
Old 09-29-2004, 09:06 PM
  #4015
Its never to early! What is your take on the new 415?
tcmerf is offline
Old 09-29-2004, 09:10 PM
  #4016
The 415 that I have now pretty much has all of the same stuff that is coming on that limmited version ... ... minus the 2.5mm chassis....
Now if Tamiya was to offer it in Red that might be something nice
-Dave
Old 09-29-2004, 09:14 PM
  #4017
FW-05RR's Avatar
why red? how bout something different for a change maybe green
FW-05RR is offline
Old 09-29-2004, 09:15 PM
  #4018
mashimaro's Avatar
416? when is that going to be released? isn't it a bit early as the 415 incarnation is still less than a year old
mashimaro is offline
Old 09-29-2004, 09:35 PM
  #4019
buboy28's Avatar
Arrow Re: Re: TRF415MS
thanks for the translation bro
Rough translation:
Release date: 11/25
buboy28 is offline
Old 09-29-2004, 10:03 PM
  #4020
Runin Ronin's Avatar
-Dave
That might be called the TRF415 Surikarn Edition
IMHO, Tamiya will release a TRF415SE in Red whether he wins the Worlds or not... just as long as he runs the 415 and not the Evo4... If he runs the Evo4... perhaps a Evo4SE
Then again, what if Hara wins? Pro4HE!!!
Exciting times ahead...
Runin Ronin is offline
