Like Tree2Likes
Tamiya TRF415
Old 09-27-2004, 08:27 AM
  #3961
rod how was your testing with the new sus.?
Evo_Uk is offline
Old 09-27-2004, 08:54 AM
  #3962
rtypec's Avatar
It didn't happen. I played with the Evo4 and tried to work on a setup with CS27's. Still working on it
rtypec is offline
Old 09-27-2004, 10:54 AM
  #3963
Regional Moderator
kansasracer's Avatar
Originally posted by RichO
I have to ask...
Has anyone run this car on carpet with foams yet? How have you done with it?
I should be on the carpet with this car in about 2 weeks...I will post on how it went...
short carpet track in stock...should be interesting...
kansasracer is offline
Old 09-27-2004, 12:21 PM
  #3964
Greetings everyone,
Could anyone post a good 19t rubber tire carpet set-up. Carpet season starts next week in Stockton, CA.
Thanx
Obsidian is offline
Old 09-27-2004, 12:22 PM
  #3965
Originally posted by Hebiki
hehe okay.. ill be at tamiya trying to figure out the LW on the 415. gonna be a long day tomorrow
How did the testing go? I think i will be out Saturday and could use a starting point. Thanks
tcmerf is offline
Old 09-27-2004, 03:18 PM
  #3966
TryHard's Avatar
Originally posted by Obsidian
Greetings everyone,
Thanx
Hi,
I assume your using the LWT arm set, if so, try this, it's what I've been using recently indoors, and it's a deffinate improvement over my last base setup (Lap times don't lie ). Admitadly its for 27t stock, I reckon it would be just as good with a 19t.
Indoor Carpet Base
Couple of things to note.
1) Gearing is super low, but thats because of the track I was last running on (suppose I don't really need it on a Base setup)
2) there are some extra 0.5mm shims under the camber link studs on the rear, this is mainly because i'm using a slightly longer fastrax ball stud on the outer ball stud, and it has a slightly longer thread than the Tamiya ones. So to stop it deforming the plastic, and rubbing/binding hte CVD, I've had to place a 0.5mm washer under it, and did the same on the inner stud to compensate.
3) I have 6mm hexes on the front, with 4mm+spacers on the rear, as this is to make sure the car is legal width. I'm not sure the front width on the sheet is entirely accurate, but I can't be bothered to check tonight
I'm not sure if running the 6mm hexes on the front negates some of the effect of running the C/A blocks, I personally think it makes the front end a little more stable (due to increased track) and hence slightly easier to drive over 5mins.
4) I've included the tyres/inserts I've been running too, should add they being coated with LRP Blue Factor additive before each round. At the local club it seems either T27's or CS22's are the most popular (with the T27's being a control tyre for the upcoming Carpet wars over here). I'm running the Sorexs, mainly cause I can't be bothered to change to the others, at it deffiently seems they can hold their own.
Anyway, Hope it helps, any feedback you guys can give would be awesome.
Regards
Ed
TryHard is offline
Old 09-27-2004, 04:22 PM
  #3967
Peter Busch's Avatar
Do Jaco 28 mm foams fit on this car? I noticed on mine the stock rims come really close to the ballstud on the front.
Peter Busch is offline
Old 09-27-2004, 04:24 PM
  #3968
Hebiki's Avatar
Trader Rating: 26 (100%+)
im following rod with this one. i slept at 5am.. and ididnt wake up til 2pm..so i just headed to socal.. from there.. the car was a mess.. luckily a very nice and helpful gentleman by the name of Tyree Philips helped me work some kinks out of the car. (Tyree, i owe you lunch or something! )
testing went okay.. more on tuesday to get a set up i like.
Hebiki is offline
Old 09-27-2004, 04:31 PM
  #3969
Thanks a bunch. If all goes well I should have The MKII and MKIII painted and ready to roll. ( or mangle which is more likely the case)
tcmerf is offline
Old 09-27-2004, 04:34 PM
  #3970
Hebiki's Avatar
oh duh.. i forgot to mention. i was using the stock set up for the 415 (always my starting point) and the stock set up for the LW arms (spacers and all)
if your going to socal tomorrow, come by my pit. im the bald filipino guy with the pink car and wires! maybe you could help me out some!
Hebiki is offline
Old 09-27-2004, 04:37 PM
  #3971
No such luck. I work in Rancho and it is a bear to get to socal. I will be out in a couple of weeks. My wife is headed out of town so i am going to hit TA in the morning and socal that night!
tcmerf is offline
Old 09-27-2004, 04:39 PM
  #3972
TryHard's Avatar
Sorry guys, looks like my webspace it MIA at the moment, so the pic link won't work.
I'll let you know when (if?) it returns
Regards
Ed
TryHard is offline
Old 09-28-2004, 12:24 AM
  #3973
JRRobiso's Avatar
Default TRF415 MS
Greetings fellow 415ers!
Quick question. Does anybody have any details on the next follow-up chassis Tamiya's coming out later called the ''TRF415 MS"?
Any info will be appreciated.
JRRobiso is offline
Old 09-28-2004, 01:45 AM
  #3974
Ballsie's Avatar
I couldn't get them to fit, so I bought Orion Fresh Kicks instead. I even have to use the wider 6mm wheel hubs with the orions!
Ballsie is offline
Old 09-28-2004, 02:41 AM
  #3975
razzo's Avatar
Default crappy bearings
Anyone else had problems with bearings in 415 kit?
Trying to free up these bearings before assembly, and I've got exactly 2 good wheel bearings, 2 ok ones, 2 sub-par ones, and 2 that are completely SEIZED, as in it won't spin, PERIOD. Far as bearings for bulkhead, 1 that spins forever, 1 that spins, 1 that WOBBLES, and one that'll barely spin. At least the bearing for lay-shaft are decent. I've done everything known under the sun to clear out the grease, ect, to no avail. Am I missing some secret to these things?
I know Tamiya isn't including their blue shielded bearings anymore in new kits, but this is un-real. This is probrably my 20th+ Tamiya RC kit, and never seen bearings this crappy. At this point, it's time to extract the blue bearings from my old 414M kit.
Anyone know how to extract the bearings in 414 bulkheads?
razzo is offline
