Tamiya TRF415
#3826
how do you meen 48 pitch would be like 70-72, i was just wondering if a 96 48dp spur would work (as i only have 48dp pinions) on the car and another question to ask
what is the lowest spur you can go on the 415
Chazz
Chazz
#3827
why would a 96tooth not work?
chazz: the smallest spur kinda depends on whet ratio you are planning on using and the size of the pinion you want.
i.e a 67 would fit but you wouldnt be able to mesh it to a 20tooth pinion, if you see where im commin from
#3828
Chazz
Chazz
#3829
Chazz
Chazz
#3830
Originally posted by JDM_DOHC_SiR
I have a pic I can post.. I just have to wait till I get home..
one other thing you guys can try is the EVO4 sus blocks..if you are putting more than a 1mm spacer under them.. I have gone this route and have yet to have any problems
-Dave
-Dave
Greetings again,
back to an old discussion if I may, about the susp. block. in your quote, you said you are using the Evo 4 blocks in the rearfront and the rearrear correct?
Besides the heigth, are the other dimesions exactly the same as the 415 block dimensions?...i.e. length, degree angle of hinge pins.
In other words, is a 415 B block exactly the same as a Evo 4 B block?
Also, are 415 A,B,C,D block the same Evo 3 A,B,C,D blocks with just a 1mm difference in hieght.
Thank you very much for your help,
Sincerely,
obsidian
#3832
i think the evo3 outdrives fit on the 415
#3833
#3834
Originally posted by Obsidian
Greetings again,
Sincerely,
obsidian
Greetings again,
Sincerely,
obsidian
You can also use the 414M2 WCR Front/rear block as an A bridge on the 415, just need to shim this to even out the height against the E3 blocks.
Hope this helps.
#3835
Greetings again,
Sincerely,
obsidian
Greetings again,
Sincerely,
obsidian
-Ling
#3836
does anyone know the part number for the 6 degree hub?
Thanks!
Thanks!
#3837
Originally posted by linger
yup, you are correct. The evo4 block is identical to the 415 block with the exception of height.
-Ling
-Ling
Thank you for your response. What is the height difference? I think I've seen you around...Do you race in the greater bayarea? Stockton/Medesto?
Cheerz
Joe
#3838
Ok, let me get this right.
A to X blocks all increment by .5 degrees.
EvoIII, EvoIV and 415 are all the same width wise.
EvoIII raises the height to 2mm.
Is the EvoIV 1mm height?
Is the 415 0mm height?
I am pretty sure the 414 is 0mm in height.
Other than that do the screw holes match up?
Coop
Coop
#3839
Coop
Coop
#3840
**DELETED**
