Tamiya TRF415
#3722
I was thinking about getting a trf 415, but I kneed to know iis it very fragile and is it hard to set up
#3723
The stock 415 is not fragile. It's very durable. But when you add on the LW suspension.. then it becomes a TC3 as far as arms go. Bearings on the other hand are kinda small. I haven't had any trouble with mine (I didn't blow out the grease either)... but I'm using Squat 950 in the rears and the Pro4 knuckle up front.
TryHard... have you seen my pics on the Pro4 knuckle that I posted up in the Evo IV forum? If there are any special pics you need of it... let me know.
#3724
what weight oil do you have in the shocks
#3725
KilRuf... I just found a 2.6mm reamer and drill bit
-Dave
#3726
Would it just be easier to leave the stock arms on then go through all the bearing/hub trouble?
#3733
that car is mad.
every hopup and evo4 or 415 suspension blocks?
how does it go with lw suspension?
#3735
yeah thatl be great.
