Like Tree2Likes
Tamiya TRF415
Old 09-05-2004, 09:19 AM
  #3646
Runin Ronin's Avatar
Originally posted by TryHard
Yup, Part# TAMIYA49343 TRF415 BELT STABILIZER.
From what I've been told it adds a pulley underneath the top plate, and pushes down on the top of the front belt.
Hope it helps
Ed
Here's a few pics of the TRF Belt Stabilizer. I'm still in the process of installing it, I'll post more pics when I'm done.
Some other hop-ups that I need to install:
Runin Ronin is offline
Old 09-05-2004, 09:34 AM
  #3647
KREATOR1's Avatar
Default heat sink beam
im wondering where to install the heat sink beam?
cant find any holes near motor mount.
Could you please snap some photos of installed beam
KREATOR1 is offline
Old 09-05-2004, 09:39 AM
  #3648
Phil C's Avatar
Have a look under the rear lower deck, u see there are holes on each bulkhead to screw the beam in.
Phil C is offline
Old 09-05-2004, 09:47 AM
  #3649
KREATOR1's Avatar
yup,the hole its very near to the pulley. wont it rub the spur+ pulley?
KREATOR1 is offline
Old 09-05-2004, 09:50 AM
  #3650
s2
s2's Avatar
if you look at the beam youll see part of it is flat towards one side, this goes pulley side so it doesnt rub, as it would if there was no flat part
s2 is offline
Old 09-05-2004, 10:10 AM
  #3651
the has anyone got Marc Rhienards , Euro's Wet setup?
Winter racing is coming soon... need to start thinking ahead
Evo_Uk is offline
Old 09-05-2004, 10:39 AM
  #3652
V12
V12's Avatar
I have heard that setup was very special and won´t work on other tracks. But also wasn´t published anywhere.
But look at the thread from the German Nationals there are some informations as it was wet there also sometimes.
V12 is offline
Old 09-05-2004, 07:47 PM
  #3653
dsrbltoys's Avatar
9400169 evo iv blue heat sink!
dsrbltoys is offline
Old 09-05-2004, 09:33 PM
  #3654
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: heat sink beam
Ask and you shall recieve
JDM_DOHC_SiR is offline
Old 09-05-2004, 09:34 PM
  #3655
Here you go:
Old 09-05-2004, 09:36 PM
  #3656
Good timing Dave!!!
Any luck with the TRF Blue Maintenance Stand????
Old 09-05-2004, 09:39 PM
  #3657
KREATOR1's Avatar
Default heat sink
Thanks guys for the pictures.
Does the beam makes alot diff. heat transfer?
Like the Ta04 motor mount heat sink makes a very very big
diff. compare to the stock motor mount.Does this one do the same thing?
KREATOR1 is offline
Old 09-05-2004, 09:42 PM
  #3658
Originally posted by Runin Ronin
Good timing Dave!!!
No luck..all gone...only shops that have them have them in Red..
-Dave
Old 09-05-2004, 09:51 PM
  #3659
-Dave
Dave, Thanks for checking.
Old 09-05-2004, 10:24 PM
  #3660
Default TRF Tool Stand and Motor Stand
Wanted to share some pics of two TRF items I just bought.
TRF Damper and Tool Stand 53669
TRF Motor Stand 53668
