Like Tree2Likes
Tamiya TRF415
Old 09-04-2004, 08:30 PM
  #3631
buboy28's Avatar
Arrow
Originally posted by work
where can i find square parts online?
try rcmodel.com in hongkong if not try the square website (rc-square.com)just use the babelfish so that you could understand the wordings its written in japanese
buboy28 is offline
Old 09-04-2004, 08:41 PM
  #3632
JimmyMac's Avatar
Nismo, it pretty much says it on the EvoIV thread. It's for the Evo IV suspension or 415 with LW. You can not use the Pro4 spindle on the stock 415 suspension. Must be LW suspension. What you need Besides LW suspension kit are...
1.Pro4 spindle
2.10x5mm bearings
3.415 stock axle
4.EvoIV dogbone and pin kit (should be in the LW kit)
5. .75mm shim
6. .9mm worth of axle shims (I use Alex racing/speedtechrc)
7. (optional for carpet) 6mm silver wheel hex
Preferred method with LW suspension kit....
1.Pro4 spindle
2.10x5mm bearings
3.Square Pro4 Ti axle (non MIP type)
5. .75mm shim
6. .1~.2 worth of axle shims
I don't think it can't get more simpler than that!!
But that's only for the front end... for the rear end it's different. I haven't done it yet....
Hope this helps
JimmyMac is offline
Old 09-04-2004, 09:14 PM
  #3633
ngo8's Avatar
nismo: thanks
anymore site aside from speedtech? i cant find the part im looking for
http://shopping.rcmodel.com.hk/
ngo8 is offline
Old 09-04-2004, 11:30 PM
  #3634
Hebiki's Avatar
Trader Rating: 26 (100%+)
get a hold of steve wang at speedtechrc.... he'll hunt down any parts you may need. he'll hook you up. tell him chris from TAOB racing sent you.. (not that that means anything! )
Hebiki is offline
Old 09-04-2004, 11:37 PM
  #3635
work's Avatar
buboy & ngo8: thanks i'll look in to it right away
work is offline
Old 09-04-2004, 11:39 PM
  #3636
work's Avatar
alright ill sent him an email
work is offline
Old 09-05-2004, 12:21 AM
  #3637
Turbonium's Avatar
Trader Rating: 27 (100%+)
Originally posted by g4t2
Would someone who also owns an EVO 4 be able to give me the Pt. Number for the EVO4 blue motor heatsink please?
thanks
the # in the manual is 9400169. im not sure which color it will come in, but of course the one in the kit is blue... hope that helps.
Turbonium is offline
Old 09-05-2004, 01:08 AM
  #3638
FUK_WRX's Avatar
Default 415 out of production
Guys i was ordering another 415 kit in for my mates only to find that the TRF415 is already out of production. Hopefully they will continue to manufacture spares and hop-ups for the model. I guess this is about right since the item is a LIMITED EDITION kit.
FUK_WRX is offline
Old 09-05-2004, 01:54 AM
  #3639
buboy28's Avatar
Default Re: 415 out of production
there is still one available kit here in Manila its in LILS HOBBY SHOP only problem is they do not have a website so you might as well ask one of your friends here to buy it here and then shipped it in Australia. the kit is around 23,500.00 in Philippine pesos( dont know the convertion in AUS $)hope this helps
buboy28 is offline
Old 09-05-2004, 04:06 AM
  #3640
AMGRacer's Avatar
I tried the C/A blocks as suggested by a few people in this forum. I found a really nice increase in steering and rotation, but is it just me or is the car very nervous and harder to drive?
I notice this rear rake is also used on the Pro 4. What is the actual geometry effect of this? It appears that it is mainly a wheelbase change when the suspension is compressed?
AMGRacer is offline
Old 09-05-2004, 04:30 AM
  #3641
415....limited edition?? i dont think so....
unless we got an updated 415 coming out soon...
Evo_Uk is offline
Old 09-05-2004, 04:52 AM
  #3642
V12
V12's Avatar
I havenīt tried it for myself yet but I also have heard itīs harder to drive.
I think when the suspension is compressed itīs not only a wheelbase change but also the castor is reduced.
V12 is offline
Old 09-05-2004, 05:40 AM
  #3643
AMGRacer's Avatar
OK yep I can see that. My HPI R40 also has this same thing but obviously with a different way of doing it with the pivot ball suspension. It seems to work really nicely.
AMGRacer is offline
Old 09-05-2004, 05:58 AM
  #3644
Cool tech forum newbie
Hi guys,
Karl from Johannesburg South Africa here
I am slowly tring to make my way through the posts on the 415 but it's gonna take a while
1. what are the white belts( maker, part no, reason???)
regards
Karl
414m
414m2
414m2 wcr
415
karlfawcett is offline
Old 09-05-2004, 07:38 AM
  #3645
JimmyMac's Avatar
The White belts are from Tamiya. 53706 Front and 53707 Rear. They are low friction belts to smooth out the drivetrain even more with less friction and more efficiency. They are softer belts.
JimmyMac is offline
Copyright Đ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
