Old 08-30-2004, 10:39 PM   #3511
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The best way to remove play from ball cups is to insert part of the palstic bags parts come in between the ball end and ball cup. Find a plastic parts bag of suitable thickness and cut out squares bigger than the ball cup and slip it over the ball end and clamp down the ball cup.
Racing4Evo is offline   Reply With Quote
Old 08-31-2004, 01:13 AM   #3512
Originally posted by KilRuf
The part number for the spring set is 53440. Comes with Red, Yellow, Blue, and White in pairs. You'll need 2 sets to do both front and rear. Yellows are probably the best spring of choice though for asphalt. Unless if you like AE springs...
Thank you kilruf. Are the springs sold seperately or do I have to buy red, yellow, Blue and white together?
Cheerz
Obsidian is offline   Reply With Quote
Old 08-31-2004, 03:08 AM   #3513
TryHard's Avatar
Hey V12, interesting to note what you said about the tam drivers at the german mod nat using the alloy rear hubs+old wheel axles.
I guess by using them, and the Pro4 knuckles on the front, you could eliminate the need for the 950 sized bearings with the lwt suspension....
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-31-2004, 03:18 AM   #3514
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Ed
Now your thinking.... not a bad idea to try... but the rear hub on the 415 clears the 30mm foams just finor you could just use the pro4 hub on the rear to.. because it works also
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-31-2004, 03:30 AM   #3515
TryHard's Avatar
so I guess what ben cosgrove said to me is true then, that HPI pretty much copied the suspension off of the evo4....
Still I won't be trying it any time soon, got enough 950's to get through first...
Old 08-31-2004, 04:01 AM   #3516
Me too I have enought Squat racing dry bearings to last for about 4 really big crashes hahaha but on the EVO4 I have the HPI Pro4 hubs on it now and no problems to date yet..
-Dave
Old 08-31-2004, 07:14 AM   #3517
so there are no makes of bearings that make a strong 950??
Evo_Uk is offline   Reply With Quote
Old 08-31-2004, 03:11 PM   #3518
Not that I have found yet
-Dave
Old 08-31-2004, 03:41 PM   #3519
V12
V12's Avatar
I have uploaded some pictures from Marc Rheinards and Marc Fischers cars from the German Nationals at this thread.
http://www.rctech.net/forum/showthre...threadid=49028
Also there is one picture from the new prototyp aluminium rear diff made by Jrgen Horn for the 415. One special thing is he now makes the diffs and spool for the Corally blades. This just works on the original Tamiya driveshafts and lowers the friction and wear a lot.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 08-31-2004, 04:05 PM   #3520
What do you have to do to use the aluminum uprights other than drill out the hinge pin hole. I checked last night and it seemed the aluminum upright was wider than the new plastic one. I see the spacer on the hinge pin but it seems as if the arm would need to be fitted.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 08-31-2004, 04:18 PM   #3521
Looks like a hack and slash to make it fit... but it looks like the rear arm would be a bit weaker at the point where the material was used ...Just my 2 Yen...
-Dave
Old 08-31-2004, 04:58 PM   #3522
JimmyMac's Avatar
WYD... 6mm wheel clamps are 53569. Just under $20 for a full set. I also use them on my F201....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-31-2004, 05:06 PM   #3523
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thanks. I will be ordering some.
ST Racing Concepts (STRC)
Old 08-31-2004, 05:54 PM   #3524
TryHard's Avatar
hey guys, couple of pics of the new subaru shell
all masked up, ready for the black line detailing first...
Old 08-31-2004, 05:55 PM   #3525
TryHard's Avatar
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
