Old 08-25-2004, 01:11 PM   #3391
rtypec's Avatar
You can try using the longer shock shafts from previous TRF shock sets. I don't have the part numbers but those shafts will get you more downtravel.
rtypec is offline   Reply With Quote
Old 08-25-2004, 01:24 PM   #3392
R/C Tech Charter Subscriber
I have a 415 on the way and was wondering if the Direct Center Pulley's that Steve is selling at Speedtech is the solid layshaft?
NismoSkyline17 is offline   Reply With Quote
Old 08-25-2004, 01:38 PM   #3393
AlanLim's Avatar
TAM53708 Tamiya TRF415 Center Direct Pulley
This one?
AlanLim is offline   Reply With Quote
Old 08-25-2004, 02:25 PM   #3394
jeffreylin's Avatar
Default Re: Shock lengths.
Originally posted by markp27
Could someone let me know what the lengths of the shocks should be?
The rear shocks are causing me some trouble - I screwed on the lower ball joints so that the fully extended shock length was 61mm, but now I can't achieve a droop less than 4mm And when I set the ride height to 5mm, the pre-tention ring is virtually all the way at the top of the shock body.
On my EVO III my shocks are also 61mm and I have no such problems.
Any suggestions?
I don't think this is a problem. It's how I have my car too. I usually run 5 rear droop.
jeffreylin is offline   Reply With Quote
Old 08-25-2004, 02:40 PM   #3395
Default Re: Re: Re: Re: 415 spool
Originally posted by trf racer
true but i think the yoke outdrives are a bit lighter then steel.
Guys do you think if we make enough noise we can get Tamiya to make more of these spools. I think Tamiya America only made about 60........I could be wrong though. The spool is on the right in the pic.
blewer is offline   Reply With Quote
Old 08-25-2004, 02:41 PM   #3396
SpeedTech's Avatar
Nismo,
That's the direct pulley, which the two center pulleys are now together as one piece and held on the stock layshaft with a single set screw. It's the part you need if you're trying to lock the center.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-25-2004, 03:07 PM   #3397
I dont think they made that many. Last I heard it was 10 or 15. Cost is huge also due to using the 1-way diff pressing out the bearings and pressing in the Alum inserts.
Go with the Speedtech unit it is made here in Washington by one of our local racers. Steve I think has put in an order for more due to demand.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 08-25-2004, 03:10 PM   #3398
Wow 10 to 15, I guess I was very lucky to get one!
Old 08-25-2004, 03:25 PM   #3399
TryHard's Avatar
Any suggestions?
I think if I remember rightly I'm using a shock length of 61 mm, I have slightly unwound the end caps to get this length and it seems to work fine. I can have a pretty much full range of droop.
However I notice your not running any spacers under the rear suspension toe brace. this could be causing the problem.
Hope it helps
Ed
Actually correction, just measured it, and I can't get lower than 4mm too, guess I'll have to extend the shock lengths, by undoing the ball studs a little. Actually I've put the rear shock at 63mm now, allows 3mm on the droop gauge, so it sits on 4mm with the droop screw resistricting it.
| THard.co.uk | Xray | MuchMore |
Old 08-25-2004, 04:09 PM   #3400
Hello,
Does anyone have an idea about where to get tech-racing parts in California? San Francisco area?
Obsidian is offline   Reply With Quote
Old 08-25-2004, 04:10 PM   #3401
MarkP27
I set my shocks to 62.5 mm. Works just fine, and leaves just enough room for various settings.
From what point to what point are you measuring your shocks from?
Some people measure from the very top of the shock to the very bottom. ( this is how I measure)
Others measure from the inside of the top mounting hole to the inside of the bottom mounting hole.
Cheerz
Old 08-25-2004, 04:14 PM   #3402
rcspeedo's Avatar
The 414M2 has longer shock shafts.
Part number # 9805504
Hope this helps
rcspeedo is offline   Reply With Quote
Old 08-25-2004, 10:57 PM   #3403
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Shock lengths.
Me, too - but for a base setup (carpet) I'm using Marc Rheinard's setup and he has 4mm droop at the rear.
markp27 is offline   Reply With Quote
Old 08-25-2004, 10:59 PM   #3404
markp27's Avatar
As I mentioned above, I'm using the Marc Rheinard setup for carpet and he didn't have spacers under the rear blocks. But I did try it before removing the spacers and it was the same.
I hope this doesn't mean that there is a possibility of pulling out the shock rod from the ball adjuster
Thanks for the info, Ed.
Mark.
Old 08-25-2004, 11:01 PM   #3405
markp27's Avatar
Originally posted by Obsidian
MarkP27
Cheerz
I do the same - very top to very bottom.
Seems I have to unwind the ball adjusters a little
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
