Like Tree2Likes
Tamiya TRF415
Old 08-07-2004, 05:04 AM
  #3196
T-man
Guest
Posts: n/a
Kimborough 78t 48dp
or
Corally 98t / 100t 64dp
Depending on trackconditions
Old 08-07-2004, 08:51 AM
  #3197
markp27's Avatar
Originally posted by V12
What size of the spur gear are you guys using with stock motors?
Im using a Xenon 88 or 90 teeth with my EVO III but this maybe is a little small for the 415.
Hey V12, have you got your car running? Mine will be here next week
markp27 is offline
Old 08-07-2004, 08:55 AM
  #3198
V12
V12's Avatar
Hi Mark
No, not running yet. Will send you PM.
V12 is offline
Old 08-07-2004, 08:28 PM
  #3199
JimmyMac's Avatar
I will run either an Xenon/SpeedtechRC 96 spur or a 101 spur.
JimmyMac is offline
Old 08-08-2004, 01:18 AM
  #3200
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
104~106 Xenon or Kawada Spur`s..Seem to be the best overall for Mod and Stock for gearing
-Dave
JDM_DOHC_SiR is offline
Old 08-08-2004, 02:36 AM
  #3201
RW spur gears are the best I've ever tried!!!
Hugo is offline
Old 08-08-2004, 02:43 AM
  #3202
Yes, but Xenon are even better....lol
g4t2 is offline
Old 08-08-2004, 01:55 PM
  #3203
V12
V12's Avatar
Thanks guys. So I have to look for some bigger spurs as my largest are 90 teeth currently. I had no RW spurs lately but the Xenon were really good on my EVO III.
V12 is offline
Old 08-08-2004, 04:11 PM
  #3204
Default setup
i have just got my 415. i have been running the 414 and thought i would upgrade to my new toy. Can anyone give me a good setup to start with or tell me where i can go elsewhere to find one. I run on concrete surface with reasonable grip levels, mainly stock class and rubber tyres. The car is stock and i will run the oneway as i am currently doing so with my 414. Any help would be great.
misterntc3 is offline
Old 08-08-2004, 05:34 PM
  #3205
JimmyMac's Avatar
The stock setup works great.
RW spurs are very nice. But if you go too big, they will warp on the spur holder on the 415. I ran a 112 spur like that. I had to put a backing plate on the spur because it warped so bad.
JimmyMac is offline
Old 08-09-2004, 05:11 AM
  #3206
does anyone have surikarns set upo that he used at the reedy race at tamiya?he used the long suspension kit and need to know hes set up.
cheers
trf racer is offline
Old 08-09-2004, 05:15 AM
  #3207
Turbonium's Avatar
Trader Rating: 27 (100%+)
Default Re: setup
my setup from parking lot yesterday is mostly kit, except i was on blue spring front, white rear... with yellow swaybar on front, none rear, CS-27 premount tires.
this was on semi-smooth asphalt, sprayed with lotsa VHT... running Peak Vantage V2 8x2.
Turbonium is offline
Old 08-09-2004, 11:37 AM
  #3208
stonedgti's Avatar
Trader Rating: 15 (100%+)
does anyone have Charlie or Fred's set-up for the KO race?
stonedgti is offline
Old 08-09-2004, 04:45 PM
  #3209
AMGRacer's Avatar
Default Re: setup
Hey Barry I ran my 415 with the stock setup 36R sorex with speedmind medium inserts and a Monster Stock with 81/23 gearing and it seemed pretty nice.
AMGRacer is offline
Old 08-09-2004, 05:15 PM
  #3210
JimmyMac's Avatar
For the KO Race, did they use oneway or spool? Just curious
Well let me go pack up for the Norrca Nats... I'll be bringin 3 cars... Yokomo SD, Evo IV, and 415. I'll see if I can't get any good pics....
Jimmy Mac
JimmyMac is offline
