Tamiya TRF415
#3181
Originally posted by Fatboy Joe
HI, technically, what does it do to the car's front end to make it have more On-Power steering? Thanks
this is a mod we did on the evo3 a while back.
evotech;yes you were the one i was refering to.
although i know another person who has one now as well in the south east.
#3182
http://rctech.net/forum/showthread.p...threadid=46175
#3183
Hey Peter, do you have msn?
#3184
Originally posted by JDM_DOHC_SiR
Yep... EVOIII diff works
-Dave
-Dave
#3185
Originally posted by tcmerf
What do you need for the lightweight diff from the EVOIII to make it work in the 415. I want to bulid one and use the stock one as a spare.
#3186
#3187
just in the rear... works ok, just have to shim a little, aas the total width of the evo outdrives is a little smaller. i have that in the rear of mine right now, cause when i was in Memphis, burned up the stocker.... all i could find were some Evos, and didnt shim them. walks back and forth a little, but allowed me to finish the day! with the shimming, should be perfect.
#3188
Jeffreylin and TRF Racer: Thank you for the info
#3189
Re: Re: battery holder
Originally posted by jeffreylin
Tamiya did come out with a optional chassis for stick packs for the 415. Not sure what the part number is but you can find it on Tamiya's web site.
#3190
why dont you pm me your fone number and il give you a call.
especially since the ko is in a couple of weeks.[cant wait]
fatboy joe;thats ok.
on the 415 this mod isnt really needed as we can just put trhe front wheelbase back,but if you need it to go back even more just buy the a block bridge and put that on to push the wheels back more.
#3191
Has anybody checked to see if 28mm foams fit the 415?
#3192
it should if you use the red and blue shims it works on my evo 3 and it should work on the 415 they do have the same suspension.
#3193
You can also use the 6mm silver wheel hexes. And if you need to narrow the width of the car, just use different blocks like C blocks instead of D blocks to move the arms in closer to center.
#3194
another thing i do is i cut my fronts down to 27mm and it doesnt rub at all also gives more steering being more narrow one thing i found out tamiyas like narrow tires on carpet with foams anyway.
#3195
What size of the spur gear are you guys using with stock motors?
I´m using a Xenon 88 or 90 teeth with my EVO III but this maybe is a little small for the 415.
