Tamiya TRF415
#3166
i agree... it was well packaged. huge box with a ton of newspaper around it. i wish i had ordered some spares for the Evo too ... fraid ill break something! i was gonna order the LW suspension kit for my 415, maybe use it for spares instead. i guess in a pinch, i could swap it back to the old setup...
#3167
battery holder
will TAMIYA be coming up with a battery holder for the 415? some sort of a hop-up maybe
#3168
Originally posted by TryHard
I have got a spool, but haven't tried it yet, been waiting on the locked centre pulley to arrive, which it now has (along with low fricition belts). I'm going to try it in a little while, indoors on a rather low grip surface, but this weekend I'm racing indoors on carpet, and am very happy with the handling of the car with one ways in, so I'll leave it as is for now. (plus this weekend we've got 12th cars running too, so the grip is really going to shot up)
Ed
Ed
Keep me posted when you test your spool. THANKS....
#3169
Does the 415 come standard with a front one-way, or is it an hop-up?
#3170
Re: battery holder
#3171
#3172
Originally posted by jeffreylin
415 comes with one-way only. neither spool nor diff are available even as an option.
It's made by EP4.....I have one and I know several other people with one.
Tamiya also makes a locked Centre pulley now and it should be in the USA soon - so you can remove the layshaft centre one-way and replace the one-way up front with the EP4 spool.
Also there are two ways you can get a diff for the front. IF you read back through this thread you can make one from Yokomo parts...or you can order custom made, blue anodized diff halfs from Germany (I have these two and they are sweet ).
#3173
Hi Jeff how did your Evo IV perform yesterday at SoCal did it give you any problems
#3174
Originally posted by Paul_Kultcha
You can order a Spool for the TRF415 from www.Speedtechrc.com
To add to your comments, a front alumnium spool and alumnium diff outdrives are available from this guy Jürgen in Germany. Very high quality stuff and a nice guy to deal with.
#3175
#3176
I hit a guy standing inside the track during practice and stripped my spur gear. Other than that I had no problems. The car ran great and I TQed and won last night in stock.
Anyway Congrats on the TQ and win you have some awesome cars
#3177
Just borrowed a 415 from a friend to try out. I have a couple of questions.
1. what is the internal ratio
2. are the front blocks both 1d
3. does 1A - 1B blocks in the rear = to 2 degree total toe?
What's a good starting set-up for asphalt?
If this thing drives better than my EVO3s...I'll convert.
#3178
2. yes, though many changed to 1C & 1A for more on power steering
3. if you have the stock plastic rear upright (2 degree), 1A & 1B give you 2.5 degrees. but if you have the optional alumnium upright (1 degree), 1A & 1B give you 1.5 degrees. however, if you have 1A & 1B in the rear you are running narrower rear than the stock setup, which uses 1D in the rear instead of 1B.
The kit stock setup is good for asphalt.
#3179
Originally posted by g4t2
Peter, ok not to worry, I will try to get a B+B as close as possible to the track and get taxis, should be fine. Do we have to bring our own roof to pit under? Sorry for all the Qs, I only normally race indoors on carpet...lol
#3180
