Old 08-03-2004, 02:21 AM   #3136
TJ
TJ's Avatar
Originally posted by Difuser
Trevor, Fred has disallowed the car feeling that it was just too much race jellybean and not in the spirit of what TCS has been in the past good or bad. Also if it was allowed just about all would run that body only whether they needed it or not and it. This would make TCS just like any other club or national event with a bunch of the same car in different colors.
Yes I would have to agree I have my own concerns about it and in the spirit of the competion I think it is a bad move. Also there are not still avaible here in Australia and the is another good reason not to have it this year.
Thanks Diffuser
Castle Hill Raceway: www.castlehillraceway.com
Facebook: https://www.facebook.com/groups/121817254587521/
"Anything I say can or will be used against me at a later date":
TJ is offline   Reply With Quote
Old 08-03-2004, 04:31 AM   #3137
Hi Guys,
How would one go about reducing low speed steering?
The car is mint at high speed but its reacting/changing direction
far too quickly at low speed for our low grip surface. Makes the car
feel nervous and inconsistant.
Oh, also... a couple of questions regarding the suspension conversion kit.
1, Can you still run a ball-diff in the front? The Hybrid Yokomo/Tamiya Ball diff required the use of 46mm UJ's. With the suspension arms being longer... will the 46mm UJ's still be an option?
2, Do the Tamiya Aluminum Rear Uprights still fit?
Cheers Guys
Andrew
Lycan is offline   Reply With Quote
Old 08-03-2004, 06:11 AM   #3138
Registered User
For the steering question, move the tie rod to the hole toward the back on the steering knuckle. It wont make the car as quick.
O
O<------
Thats my attempt of making a diagram. Pretend that those are the two holes on the steering knuckle where you attch the steering tie rods.
2quick4you is offline   Reply With Quote
Old 08-03-2004, 07:42 AM   #3139
TryHard's Avatar
Not sure about the answer to Q1 Lycan, might work, but as I haven't run a diff in the car, I couldn't tell you.
Q2, you don't actually need to use the Alu hub's with the new suspension set, as you get graphite 1 deg rear hubs in the kit anyway.
Hope it helps
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-03-2004, 08:36 AM   #3140
Default KO Grand Prix UK
I was just wondering if any of the guys who drive tamiya's in the UK were racing this years KO Grand Prix on August 29/30?
g4t2 is offline   Reply With Quote
Old 08-03-2004, 09:10 AM   #3141
V12
V12's Avatar
Originally posted by Lycan
Hi Guys,
Cheers Guys
Andrew
1. In the suspension kit there are complete 46mm UJs included.
Front is with steel bones, rear is with blue aluminium bones.
Also there are some different oneway outdrives included.
2. No, the new wheel axles are shorter also different sized wheel bearings are used so the aluminum rear uprights wont fit.
But the included Rear uprights are also 1 toe in and the same style with vertical ballstuds.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 08-03-2004, 09:32 AM   #3142
Paul_Kultcha's Avatar
Hi Guys,
I have no idea what your setup currently is so it's hard to make a recommendation. Judging from your post you have the Alum. rear uprights - these reduce your rear toe by one degree. If you're finding the car nervous at low speed trying replacing the C Toe Block that is stock on the front of the rear arms and change it to a B Toe Block. This will put you back to the stock Toe In on the rear and should remove the nervous feeling.
Paul_Kultcha is offline   Reply With Quote
Old 08-03-2004, 09:40 AM   #3143
Default Re: KO Grand Prix UK
yeah iam goin there.
iam running my 415 with the new suspension kit.
iam running mod.
my names peter aynge.
you going?
if so maybe we can help each other out as we use sismilar equipment.
what you running stock?
also ill take my evo4 as a back up car.
are you going saturday for the practice?
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 08-03-2004, 11:53 AM   #3144
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
trf racer
They don`t allow beginners
If you had x-ray fk i could help you
See you there honey (only sun/mon)
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 08-03-2004, 01:11 PM   #3145
Originally posted by MR JOLLY
trf racer
lol hey, i only put ability on 5 out of ten.
that way iam not a beginner but not expert.
me am intermidiate methinks.
i hate the x ray car.cheap clone of 414.j/k.
yeah see you there.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 08-03-2004, 01:58 PM   #3146
Cheers guys.
Old 08-03-2004, 02:57 PM   #3147
[QUOTE]Originally posted by Lycan
[B]Hi Guys,
Try to put Steering Expo on your servo (-60%). It's from Mark Reinardt. Incredible results.
Hope it helps.
Hugo is offline   Reply With Quote
Old 08-03-2004, 04:32 PM   #3148
ngo8's Avatar
Send a message via ICQ to ngo8
if you have to much steering off power you can just dial out some steering exponetial it will also give better feel on the car and a little better traction as well.
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 08-03-2004, 05:46 PM   #3149
Hey TRF racer, my name is John Harrison. I'm gonna be there on sat for practice, you? I'll be running my 415 in 19t, with normal susp. Where are you staying? I need to book a B+B soon. Are you driving yourself? If so would it be possible to get a lift from the B+B (that is if your staying in one) to the track, as I'm getting dropped off sat and picked up mon. who needs backup cars, when you own a tamiya eh??
Old 08-03-2004, 11:02 PM   #3150
AlanLim's Avatar
so no one runs spool?
everyone using ony-way?
AlanLim is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
