Old 07-28-2004, 02:11 PM   #3091
TryHard's Avatar
Originally posted by s2
Tamiya
Spring Rating [lb/in]
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Hi, just been looking over this again. Going on what everyone has said aboout the shorter tam springs being stiffer, surely the Yelllow and yelllow short in the chart above should be swapped over? Just trying to make sure I get muddled.
Oh and bumping it back up to the first page...
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-28-2004, 02:25 PM   #3092
koabich's Avatar
Send a message via Yahoo to koabich
I have a 415 but have not yet run it. I will be running it within several weeks and was wondering if I should go with the TRF reversible lightweight suspension. This will be my 19 turn car. I run on carpet with foam tires. It is a tight track. Would it be worth the investment?
Joe
koabich is offline   Reply With Quote
Old 07-28-2004, 04:34 PM   #3093
Ballsie's Avatar
Joe
I have just ordered the reversible suspension for my 415, I will be running it on carpet with a 19t in a few weeks. This will be my first time on carpet and I will probably use the standard suspension as I am going to imitate a setup I download of Marc Rheinhards car for the LRP Masters.
Ballsie is offline   Reply With Quote
Old 07-28-2004, 05:09 PM   #3094
TryHard's Avatar
Ballsie where did you get the setup?
Old 07-28-2004, 05:32 PM   #3095
I posted this in the Evo III forum and would like to get some thoughts on it here. Hope you don't mind.
Has anyone else had problems with the shock shaft guides being extremely delicate? I have the TRF Fluorine Shocks mounted on my Losi XXX-S and have found that one good crash will pretty much destroy the shaft guide as well as the piston (since I have the 3 hole pistons drilled out with a #56 bit).
Has anyone else noticed this problem and is there a solution?
Thank you!!!
Griffin is offline   Reply With Quote
Old 07-28-2004, 05:56 PM   #3096
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thank you!!!
No problems.. with the TRF shocks.. I have re-built my shocks only one time so far and thats 6moths worth of use the teflon shims just seem to wear a little.. but I have broken A-arms and had no ill side effects what so ever.. What was acctually broken on your car besides the Damper.?
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-28-2004, 07:05 PM   #3097
dsrbltoys's Avatar
Hey, another fix is to use the black plastic instead of the white teflon in the bottom of the shock...
dsrbltoys is offline   Reply With Quote
Old 07-28-2004, 07:10 PM   #3098
Hmm not a bad idea... have the part #??
Old 07-28-2004, 07:19 PM   #3099
rtypec's Avatar
Thank you!!!
You posted this in the Evo3 thread as well. What you are doing is modifying the piston and removing a lot of the material that takes an impact when you have those crashes where the suspension is pulled down. Again, there is nothing wrong with the shocks for the application that they are designed for. Next time try using the bumper droop screws, not just to set downtravel but to act as reverse bump stops in the event of a crash. Again, the TRF shocks some of the best in the business and you'll be hard pressed to find anybody having problems with them.
rtypec is offline   Reply With Quote
Old 07-28-2004, 07:55 PM   #3100
dsrbltoys's Avatar
JDM
They were on the tree with the shock bottom cup.
Old 07-28-2004, 07:56 PM   #3101
JDM
Whoops.. threw them out DOH!!
Old 07-28-2004, 07:58 PM   #3102
dsrbltoys's Avatar
Oh, thats too bad. They are available replacement. Purchase TWO packs 53334 low friction shock Y parts.
Old 07-28-2004, 08:01 PM   #3103
Thanks for the Part#
Old 07-30-2004, 09:25 AM   #3104
TryHard's Avatar
and bump up again....
Got my new lightweight arms set through today, look good, but not enough time to get them fitted for this evening, I'll get them done tomorrow instead. Gonna be running the car with the C/A and D/D blocks tonight, running a 12x1 mod indoors. Should be a laugh.
Ed
Old 07-30-2004, 11:43 AM   #3105
s2
s2's Avatar
http://www.rczone.net/files/tamiya/t...nard_lrp04.pdf
s2 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
