Like Tree2Likes
Tamiya TRF415
Old 07-24-2004, 08:40 PM
  #3061
Regional Moderator
kumpol's Avatar
found this on ebay....
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5911481151
kumpol is offline
Old 07-25-2004, 12:31 AM
  #3062
jeffreylin's Avatar
Has anyone tried running the 415 without sway bars? A friend has the Tech MY02 Monster and told me that most people do not run sway bars on the MY02. So I tried it tonight and the car was so much better (in an indoor technical track). The car used to push a little and now it has as much side bite but with much more steering.
jeffreylin is offline
Old 07-25-2004, 12:51 AM
  #3063
Hi All,
Finally managed to get the rear end of my car sorted!
Carbide balls has certainly made the diff smoother but I found that reducing the EXPO to -30 on my transmitter has transformed the the car from undriveable to being only 2 secs off the leaders after 4mins race And for me, thats awesome
The only thing I can think of is our really low grip surface and the addition of the .06sec Sanwa servo I am running produced too much instant steering for the rear end to handle.
So happy to finally have it sorted
One thing I've been thinking about is what would happen if
I removed the spacers under the bridges of the rear suspension?
Are they there to increase or decrease rear end grip?
Cheers
Lycan
Lycan is offline
Old 07-25-2004, 01:56 AM
  #3064
=MisFitz= NuKe's Avatar
well, if you are talking about the aluminum suspension mounts, takingt out spacers in the rear will give more traction, generally...
=MisFitz= NuKe is offline
Old 07-25-2004, 04:24 PM
  #3065
ngo8's Avatar
hey do you know if they use the same axles os the evo3 and the 415 i hope so the we can use those nice titanium axles.
ngo8 is offline
Old 07-25-2004, 04:56 PM
  #3066
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
No the Newer EVO4/415 Sus conversion Axles are different.. the new Ti ones will be out on the 25 of Aug.
-Dave
JDM_DOHC_SiR is offline
Old 07-25-2004, 05:06 PM
  #3067
Hebiki's Avatar
Trader Rating: 26 (100%+)
-Dave
dave! are your echo low friction belts still on sale? if they're still available, please PM me. id like to take them off your hands. thanks!
Hebiki is offline
Old 07-25-2004, 05:12 PM
  #3068
ngo8's Avatar
hey dave i send you a pm about the belts you dont want to sell them to me ?
ngo8 is offline
Old 07-25-2004, 05:15 PM
  #3069
You didn"t get the PM..
Old 07-25-2004, 05:17 PM
  #3070
ngo8's Avatar
no i didnt.
ngo8 is offline
Old 07-25-2004, 05:19 PM
  #3071
no i didnt.
Back to you then
  #3072
PM sent
Old 07-25-2004, 05:20 PM
  #3073
ngo8's Avatar
Talking
ok
ngo8 is offline
Old 07-25-2004, 05:22 PM
  #3074
ngo8's Avatar
back at ya
ngo8 is offline
Old 07-26-2004, 04:32 AM
  #3075
TryHard's Avatar
Associated springs
Easy to set up the car with 3 different sets..
Gold
Blue
Silver
thats it
-Dave
Thanks for this Dave. I've actually got a set of Copper AE springs I used to run on the rear of my Yokomo, I take it they might be a little stiff though ...
I can only find the Gold and Silver over here in the uk at the moment, I assume the Gold is softest, with Silver being hardest (of the three)? How do they compare to the Tamiya springs (ie is AE Blue similar in stiffness to Tam Yellow) ?
Your using these with the EvoIV suspension though, right? Does that make any difference to the spring rate? or is it just a case of more options on mounting? I should be getting my set soon enough, although I don't think I'll use it straight off, but at least it means I don't have to shell out for the Alu rear hubs.
(Maybe I can stop spending money soon, along with the MRT-VX Pro I brought this week, gonna be a big CC bill this month...)
Finally I have one, more open question.
Having run the car at the weekend with stock wishbone mounts, I've now changed it to D/D on the rear (2deg toe with std hubs, right?) and C/A on the front (I brought the front A mount when I got the car). What sort of affect will this have on the car? I rember reading somewhere on here that the narrower front end (due to C/A) gives it more steering, whilst also providing -1 deg of inboard toe out.
How does this inboard toe-out affect the car? I assume it will affect it when the car has the suspension loaded, as otherwise it would be no different to the standard set-up right? (I usually run with 0 deg toe anyway).
Thanks in advance
Ed
TryHard is offline
