Old 07-19-2004, 11:31 PM   #2986
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by tcmerf
I was looking back at the Reedy race pictures and I noticed a lot of guys were not running the supports for the mid decks. What would this do? My car felt pretty good at Tamiya Saturday although i would still like to find some more on power steering. I still have not ventured far from the kit setup other than the aluminum uprights in the back. Suspension mounts are all flush except for .07 up front for a little kick up. I also switched to the red sway bars. Where do you guys start when you are tuning?
The car is so tunable it is a little unnerving.
The reason that most of them were not running the supports was more than likely the chassis was to stiff for that days tracktion conditions ....
just some more food for thought
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-20-2004, 03:35 AM   #2987
Ballsie's Avatar
Hi Guys,
Does anyone know where I can get the reedy race "new" evo iv inspired lightweight suspension for the 415? I live in the United Kingdom but I don't have a problem with ordering from overseas. I also looking for some of the other hop-ups recently released.
Alan
Ballsie is offline   Reply With Quote
Old 07-20-2004, 05:41 AM   #2988
TryHard's Avatar
Well I have finally joined the club, car arrived yesterday morning, and I spent pretty much the whole night putting it together (well 4am to be honest, I just couldn't put it down un-finished ). All I can say is wow, it's an awesome piece of kit.
I'm so impressed with it, everything is of brilliant quality, and went together so easily. Even the shocks didn't take very long to get super-smooth (there something of a nemisis for me... ). Can't wait to get it on the track, and start playing with the setup.
I have a few questions though.
My drivetrain doesn't feel that free, I have set the front and rear tensioner's at 1 and 2 clicks tighter respectivly, and I also flushed out all the bearings of their greese, and lightly re-oiled them.
Is this because the belts and bearings are new and a little tight? Or should I just go back and re-do the bearings again?
To be honest the bearings spin ok-free, but i had better with my yokomo, then again I had removed the inside shields from them.
Also, so far i have built it with the stock setup, bar two points. 1) I have change the shock oil for 40wt all round, 2) I placed 0.7mm spacers under the front wishbone brace. Anything else that is a deffiente to adjust straight off (I also have the front A brace, but no alu rear hubs unfortuantly ). I did notice something in the de-structions about swapping one of the spacers on the steering for a smoother feel, has anyone done this? And if so was it a good/bad change?
Thanks in advance
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-20-2004, 06:06 AM   #2989
hey matey
give your car a good run in let some packs go through it and youll notice it get free'er. Also what class of motors are you going to be running?
the car rocks and its good to have you on team :-)
hope it goes good for ya, and you gotta come down to bedworth
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 07-20-2004, 09:13 AM   #2990
F1Junkie's Avatar
R/C Tech Charter Subscriber
Thanks in advance
Ed
If you are talking about the spacers in the steering, I tried it and it seemed to have way too much play. After I switched it to the normal spacers, it seemed fine. I would not recommend the larger spacer - it doesn't seem to to anything except make the plate move up and down more...
Dave
F1Junkie is offline   Reply With Quote
Old 07-20-2004, 09:47 AM   #2991
TryHard's Avatar
Well at the moment, I'm going to be running both Mod and Stock in it, but it's first race is going to be with the stock.
I'll plug a motor in this evening and get the drive train spining for a while, hopefully that'll free it up a little.
Whats a good belt tnesion setting for stock? as I have now (1 on front, 2 on rear), or should I go 2/2 or 1/1?
EDIT - Actually thinking about this mabe Ishould just get it running around the track first, and then see if the belt skips.
I deffiently try and get to bedworth at some point, be cool to meet other 415ers
Regards
Ed
Old 07-20-2004, 09:51 AM   #2992
well if your running stock try something like , 1 looser on the rear and 2 looser on the front, i know me and a few other dudes were doing it at the BTCC on sunday and it worked great with no slipping! try it , youll be amazed
Old 07-20-2004, 09:59 AM   #2993
Default BTCC Meeting
Hey Tarnjit,
Hope you sort your transmitter out sumtime, be a shame to have broken it fully, i was well pleased with my car at the weekend, shame for me driving like a retard in the 2nd leg final. Was running in 3rd then just started making mistakes as i relaxed too much. If i hadnt of i would have finished 2nd or 3rd overall, instead i had to settle for 4th. Bit of a shame but fastest non sponsored driver so not too dissapointed.
Love to come to bedworth as last time there i had only had the car for a week and now ive got to grips with it i may be able to give you bit more of a challenge. I need to rebuild my diff first use those diff seals, thanks by the way.
Who was the guy pitting next to you with the 415, how did he do?
rob
Robz is offline   Reply With Quote
Old 07-20-2004, 12:06 PM   #2994
I just received, some new 415 parts from r10, ordered them on friday afternoon, so super impressive. Only one problemo, I ordered the Evo III reinforced diff joint set, but to my surprise the normal ta04 diff rings don't fit...Doh! So does anyone have the part number for the evo 3 diff rings?
cheers
g4t2 is offline   Reply With Quote
Old 07-20-2004, 12:13 PM   #2995
s2
s2's Avatar
hi Rob
it was me
did ok qualified 10th in B finished 3rd, the looser belts seemed great, dunno what was up with me, car just felt dog-slow, handled very nicely though, back to 19t tomorrow will see what the belts are like then. guess i learned alot about the car thios weekend, so that kinda makes up fot the below average result.
Stew
s2 is offline   Reply With Quote
Old 07-20-2004, 01:51 PM   #2996
you WERE quick mate, its racing 19t, its gone to your head! it is difficult to race lower turn motors then race stock again, its difficult to recognise what "fast" is
Old 07-20-2004, 05:09 PM   #2997
TryHard's Avatar
Hi guys, i got some pics of my car up now.
www.thard.co.uk/rc/TRF415
Regards
Ed
Old 07-20-2004, 05:16 PM   #2998
Hey Ed, nice pics. Where did you get the blue strapping tape? i've been after some for a while now.
Old 07-20-2004, 05:27 PM   #2999
A pic of my car with the new bits....
Old 07-20-2004, 05:29 PM   #3000
and another
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
