Old 07-16-2004, 07:38 AM   #2956
just done some testing on the 415 and its so hooked.
ive gone to harder springs and raised the roll centre and now its so planted.
cant wait till i get my evo4
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 07-16-2004, 10:01 AM   #2957
V12
V12's Avatar
what rear aluminium uprights are you guys running on your 415?
the Tamiya one with 1 toe in or the Square one with 0.5 toe in?
Which one is better?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 07-16-2004, 10:12 AM   #2958
Hebiki's Avatar
Trader Rating: 26 (100%+)
V12.. i dont think its a matter of which is better. its just fine tuning. i have the tamiya 1 deg one. just to keep the car TCS legal. im sure the square one is just as high in quality, just different tuning options.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-16-2004, 10:14 AM   #2959
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I use to run the Tamiya 1 deg ones...but the square ones have less slop in the bearing area.... But now I use the EVO4 sus conversion on the 415 now... much better
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-16-2004, 10:14 AM   #2960
Paul_Kultcha's Avatar
I would have to imagine that it really depends what track you are on and how much or how little rear toe you need.
Where i race there are probably 5 or 6 TRF415s around and I'm the only person running alum. rear uprights (Tamiya ones). Everyone else is running with the stock ones and happy with them.
Paul_Kultcha is offline   Reply With Quote
Old 07-16-2004, 10:28 AM   #2961
V12
V12's Avatar
Thanks guys.
JDM_DOHC_SiR
What do you think is better with the EVO4 suspension?
Do you think its better in general or on large tracks only?
As there are no spares from the EVO4 suspension available currently you will have a problem when anything breaks.
Do you think the new parts are strong?
Did you have problems with any wheels? Some guys say not every wheel/rim will work with the new suspension because of the shorter wheelaxles.
Usually Im running zero offset wheels from Proline or Team Orion.
Old 07-16-2004, 10:34 AM   #2962
Thanks guys.
JDM_DOHC_SiR
Actually the EVO4 sus works quite well on a small high grip technical track and as for getting spare parts.....??? I have a bunch of spares that I just picked up 2 days ago ...so if I break something...I will have plenty for my EVO4 and my 415... but I have yet to break anything on the 415w/the EVO4 sus on it...the C-hubs are very strong!!!..now as far as wheels go...if you don`t use the red 1mm spacers with the EVO4 sus conversion some wheels will rub... but it`s also the same for my EVO4
-Dave
Old 07-16-2004, 10:45 AM   #2963
V12
V12's Avatar
Dave
Thanks for the informations.
Seems I shouldnt buy an aluminium rear hub for the old suspension but should go straight to the new suspension.
Old 07-16-2004, 03:43 PM   #2964
Hebiki's Avatar
Default Diff Balls
hey guys.. quick question... is there a different between the tamiya carbide diff balls..and the lightweight balls? or are they the same thing?
thanks!
Hebiki Design Works
Old 07-16-2004, 03:48 PM   #2965
Hebiki's Avatar
Here are the part numbers:
53124 OP124 3mm Tungsten-Carbide Diff Ball
53379 OP379 3mm Lightweight Diff Ball Set
Hebiki Design Works
Old 07-16-2004, 05:12 PM   #2966
I would imagine the lightweight are the ceramic diff balls, no?
Old 07-16-2004, 05:16 PM   #2967
What are the advantages or disadvantages between having ceramic compared to carbide?
g4t2 is offline   Reply With Quote
Old 07-16-2004, 05:27 PM   #2968
Hebiki's Avatar
lightweight dont look ceramic tho? weird: they look like they're made out of aluminum or some sort of steel alloy.
Hebiki Design Works
Old 07-16-2004, 06:15 PM   #2969
Ceramic is self lubricating and should be lighter (tungsten-carbide is very heavy/dense).
Old 07-16-2004, 07:36 PM   #2970
dsrbltoys's Avatar
The carbide nearly last forever! I have had one single ball fail over the last nine years, but the lt wt didn't seem to last for a couple weekends...
dsrbltoys is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
