Like Tree2Likes
Tamiya TRF415
Old 07-05-2004, 07:40 PM
  #2851
jeffreylin's Avatar
Originally posted by JDM_DOHC_SiR
They Feel the Same... a little bit slower in the "CHIC's" but nothing that can't be fine tuned with some more time on them
-Dave
Which position did you have your shocks mounted? Now that there is 5 I am more confused than ever...
jeffreylin is offline
Old 07-05-2004, 08:17 PM
  #2852
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
3 position in the back out most hole and outer most hole on the rear tower
2 position on the front out most hole on front with outermost hole on front tower.
-Dave
JDM_DOHC_SiR is offline
Old 07-05-2004, 08:27 PM
  #2853
jeffreylin's Avatar
-Dave
Thanks Dave. BTW, why did you use these positions? Why not say use the 3 in front instead? Is this the kit setup? Thanks!
Old 07-05-2004, 08:36 PM
  #2854
I used this since this was the closest to the factory arm settings ...as far as kit set up.... There wasn"t one ..Oh well.... start over from square one ( Yellow springs and sway bars work well )
-Dave
Old 07-05-2004, 08:39 PM
  #2855
Team EAM
Trader Rating: 79 (100%+)
Wish I had a 415 for the TCS race this weeknd Oh well...Just have to stay home
hey dave any news on the radio? Still not here...my buddy is starting to get worried.
EA
EAMotorsports is offline
Old 07-05-2004, 08:43 PM
  #2856
EA
Just PM'd you
-Dave
Old 07-05-2004, 08:49 PM
  #2857
Turbonium's Avatar
Trader Rating: 27 (100%+)
EA
hi.. are you Jason's buddy? he said he knew a guy who was wanting to run this tcs weekend.
Turbonium is offline
Old 07-05-2004, 08:54 PM
  #2858
Team EAM
Yea Wes thats me....Im trying to talk Fernando into letting use his 415 but I think it's not TCS legal anymore....something they did to them for the Reedy race or something He does have an evo3 though...but I hit to much stuff for it!! LOL
EA
Old 07-05-2004, 09:00 PM
  #2859
Turbonium's Avatar
well, my extra car should be... only thing im not sure of are the turnbuckles... they look just like the originals, only without the small groove in them, plus they are Ti. i dunno who made them, as i got the car secondhand.
i told him id let ya run this car, but there is one rule: gotta get me in front of you!!!!! j/k...
i dont have all the tuning stuff either... although the springs are of course the same. may have some bars, too. ill have it with me anyway, so holler if you want.
p.s. remember when i bought that Alfa body for the 'cuda awhile back?
Old 07-06-2004, 12:25 AM
  #2860
What is the part# of the new conversion kit for the 415?
Cheers
Lycan
Lycan is offline
Old 07-06-2004, 02:51 AM
  #2861
Hi,
What is the part numbr for the white diff joints?
Regards
Hugo is offline
Old 07-06-2004, 06:10 AM
  #2862
Thumbs up 46mm dogbones
Hey guys.. just found out that you can use the newer Pro4 Dog bones with the EVO4 and with the conversion set for the 415 ( new style bones not the MIP ones )
since that is the case that means you can use the Square Ti bones for this conversion or the EVO4
-Dave
Old 07-06-2004, 07:01 AM
  #2863
jeffreylin's Avatar
Default Re: 46mm dogbones
-Dave
That's great news. How about the wheel axle? Are they compatible as well? Thanks.
Old 07-06-2004, 11:08 AM
  #2864
rtypec's Avatar
Tried out the EVO4 Sus conversion today... .. needless to say I have to set it up a bit different than the regular sus arms..I found that I could run a bit softer spring and oild with the longer arms.. not perfect but the new arms are quite strong and the new hubs can take a beating
-Dave
Dave, how was the fitment of the parts? Was there slop (shrinkage?) and did anything require filing? Also, did the droopscrews line up with the chassis okay? One of the uber fast guys here has been testing a pre-production sample for some time.
rtypec is offline
Old 07-06-2004, 11:29 AM
  #2865
Parts needed a slight bit of filing on the insides of the wishbones otherwise they were not free to fall under there own weight. C hubs and rear hubs needed no filing, the front ones needed some shimming but the shims are included (you get 1 pack of the small 0.1 shims and one pack of the wheel axle 0.1mm shims). Hinge pins on the outer edges are different as well, they are now just a straight bar with a thread on the end and you thread them in. Rear hubs look kind of fragile but we will see when i try it. Also the front droop screws dont really line up well at all and half over hang the edge of the chassis. Rick
Rick Draper is offline
