Like Tree2Likes
Tamiya TRF415
Old 06-26-2004, 04:36 AM
  #2731
Tamiyadriver : I used Tobee's lightweight version of the Tamiya F201 universal. Their not even close
Not entirely sure if its a Tobee issue or the F201 shaft not being compatiable with the 415 Outdrive.
I might wait for the TB EVO4 to be realeased and get the 46mm blue lightweight drive shafts from that.
Lycan
Lycan is offline
Old 06-26-2004, 10:40 PM
  #2732
Turbonium's Avatar
Trader Rating: 27 (100%+)
yup, its prolly a compatibilty issure between them. i recently bought a Tuned F201 kit, and the bones will fit just like the originals... but those Evo4's should do the trick nicely...
Turbonium is offline
Old 06-27-2004, 12:47 AM
  #2733
So, the Tamiya F201 dogbones fit the 415 axles?
Can you 2x check for me?
I thought the Tobee ones would be an identical copy of the original Tamiya's. Doesnt make any sense how Tobee can market a part for F201 which wont even fit the car.
Lycan is offline
Old 06-27-2004, 01:24 AM
  #2734
There is quite a substantial difference between the F201 unversial and the 415 version.
Square F201 Universal :
Square 415 Axle :
Would be awesome if you could try putting the F201 Drive Shaft onto the 415 Axle for me. Just need verification before ordering again
Lycan is offline
Old 06-27-2004, 07:26 AM
  #2735
Turbonium's Avatar
ill have to try it this evening... i am off to race in a bit, and the F201 is all assembled. ill pop it out as soon as i can to verify. you might pm "suradaj". as im pretty sure he posted a while back that it fit perfectly.
i think the difference is that each manufacturer may use its own pivot assy, although the complete unit will fit the 201. i know that looking at the R3/R2, TRF cars, Yokomo, etc. the pivots are all different sizes.
ill holler back when i confirm.
Old 06-27-2004, 12:44 PM
  #2736
racer's Avatar
Default Re: 415 one-way setup.
Originally posted by Martin Crisp
Here is a setup I used on carpet....
Rc: Setup 415 rubber carpet oneway
Front :
springs : yellow
sway bar : yellow
shock mounting position : outer holes top and bottom
uptravel : 2.5mm
front one way : yes
Kickup : none
Upper Arm : high rc - no spacers under innner link. No spacers under blocks
Caster : 8 degrees
Camber: -1
Wheelbase: all the way to back
Tires: cs 22 - med insert
Rear:
springs : yellow
sway bar : yellow
uptravel : 2.5mm
Anti-squat: one .7mm spacers
Upper Arm : 4mm spacers under inside link
Toe in: 1 degree upright - with 2.5 total toe (a/d).
Camber: -2
what number shock oil did you use for the front/back shocks?
would this setup be useful for stock racing with rubber on carpet?
i'm using the kit setup, and find the car understeering while cornering. i guess i need to setup the car for more steering
any help would be appreciated.
Thanks!
racer is offline
Old 06-27-2004, 01:05 PM
  #2737
lazyboy's Avatar
Post
i would assume that it would work on rubber tires with a stock motor, but since i dont own a 415 i wouldn't trust me on that 100%.
lazy
lazyboy is offline
Old 06-27-2004, 07:07 PM
  #2738
racer's Avatar
my appologizes if this is a repeat question, i could not find this info through the seach.
when people refer to 8 degree caster, does that mean that the front left and right "c" hubs are switch as opposed to the normal setting?
and is there any need to add spacers to the suspension blocks to achieve this 8 degrees?
i'm a newbie when it comes to setups so any help would be greatly appreciated.
Thanks!
racer is offline
Old 06-27-2004, 07:54 PM
  #2739
Ok im posting this in a wrong place but i just bought a 414m2 and i noticed people use servo savers what if i just use a servo horn. Will it mess up my servo if i dont use a servo saver.
Doug
Dougnuts55 is offline
Old 06-27-2004, 08:22 PM
  #2740
jeffreylin's Avatar
Doug
Depends on the servo you have. If you have a good metal gear servo you would probably be okay. Worst case you'd strip a internal gear which could probably replaced inexpensively.
jeffreylin is offline
Old 06-28-2004, 08:09 PM
  #2741
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up Bump
Up
Nothing new Guys..??
JDM_DOHC_SiR is offline
Old 06-28-2004, 08:13 PM
  #2742
racer's Avatar
has the derlin outdrive been released yet?
or is it out already
racer is offline
Old 06-28-2004, 08:15 PM
  #2743
Yep... EVOIII diff works
-Dave
Old 06-28-2004, 08:24 PM
  #2744
racer's Avatar
-Dave
really it does?
Thank you wise one
racer is offline
Old 06-28-2004, 08:26 PM
  #2745
really it does?
Thank you wise one
It needs to be shimed ever so slightly on one side
I"ll put up a pic later
-Dave
