Old 06-23-2004, 07:14 PM   #2716
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Need a 415 in good condition for a fair price- buddy wants to run TCS in Mempho. Thought I would holla at ya!!!
BigDogRacing is offline   Reply With Quote
Old 06-23-2004, 07:19 PM   #2717
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by tcmerf
Ni kidding. I am starting to think I killed this thread. As soon as i get the car, everyone quits talking!
Busy testing some things right now( Belts ) and different Set-Ups.. should be able to post a few after this fridays race
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-23-2004, 10:29 PM   #2718
JimmyMac's Avatar
I'm working on a new setup for Stock with the 415. Trying to get more rotation in the car for certain turns at my track. This weekend we are having our Region 3 Race at our local track. And I'm defending champ... Only problem is that I've been running the 415 in stock and it's been the faster car for me (as opposed to my Yokomo SD). But now with some testing.. I just shaved 4 seconds off my 415's best time with my SD (using same motor, batteries, and tires). So now it's the faster car.. So I gotta go to work on a setup if I am to race the 415... drats... Gonna try out a shorter wheel base than normal. Plus a few other things...
Any body mess with different spur sizes? Gonna try out a 96spur. Just curious if anyone has noticed any performance differences with different sizes.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-24-2004, 02:47 AM   #2719
Manfredo's Avatar
Can anyone tell me the spring rate (lbs) of the yellow Tamiya spring (the one that comes with the TRF Damper set).
Thanks a lot in advance.
Manfredo is offline   Reply With Quote
Old 06-24-2004, 02:56 AM   #2720
13.33 LBS
-Dave
Old 06-24-2004, 07:56 AM   #2721
Hi guys ,
I'just get the 415 , does anyone has a complete Spring chart for this car ??
wiget is offline   Reply With Quote
Old 06-24-2004, 08:25 AM   #2722
rtypec's Avatar
wiget - here is a spring chart done by Ling:
Ling's Spring Chart
rtypec is offline   Reply With Quote
Old 06-24-2004, 02:44 PM   #2723
rcspeedo's Avatar
Hi,
Need help with foam tire setup on carpet using the dbl oneways. Anybody here tried this out?
I know it's gonna be hard to run the car using the dual oneways, but I have not finished building the diff yet and the locked center pulley. I would need the setup just in case building the front diff and the center doesnt work out.
rcspeedo is offline   Reply With Quote
Old 06-24-2004, 02:48 PM   #2724
rtypec's Avatar
Default Re: foam setup
Here's a post from Martin...
Originally posted by Martin Crisp
xcrazybenx
For foam racing I made up a front diff and locked the center one-way eventually. I started with the double one-way, but it was hard to be consistent, but with 19 turn it is not too bad wth the double oneways.
Here is a base setup
Front
Springs : Assoc purple
swaybar : Tamiya Blue
Shock Oil : Assoc 70
Caster : 4 degrees
Roll Center : (Moderate) Upper links have no spacers. Other than the anit-dive no additional spacers under the hinge pin blocks.
Anti-dive : 1mm spacer under rear hinge pin block
wheelbase : all the way to the back
camber : -1.5 on front left , -1 on front right
Tire : Speedmind 35/52 shore
Rear
Springs : Assoc Copper
Swaybar : none
Shock Oil : Assoc 50
Anti-squat : none
Roll center : (low) Links have no spacers on inner pivot ball. Used inner hole on rear upright. Hinge pin blocks both flat on chassis - i.e. no spacers. You might want to try a 1mm spacer under the inner pivot ball on upper link to make the rear a little more stable.
Rear Toe In : Total 1.5 to 2.0 Since it is a double one-way you may even want to try 2.5 it the car is too twitchy for you. I liked 2.0 with the double one-way and 1.5 with no one-ways.
camber : -2.5 on rear left, -2 on rear right.
wheelbase : all the way tot he back
tire : speedmind 35 shore.
Depending on the track I will run slightly more camber on the left side of the car. i.e. most tracks seem to have their highest speed corners turning right. So to ge a more even tire wear I add just a little bit more (maybe .5 degree) camber on the left side.
Old 06-24-2004, 03:16 PM   #2725
rcspeedo's Avatar
Thanks Rod I'll try this out.
Old 06-25-2004, 02:29 AM   #2726
Ling's Spring Chart
Thank you
Old 06-25-2004, 05:27 AM   #2727
A question for those running the Hybrid front Ball Diff on the 415 (yokomo bits):
How do I get the F201 Universal Shaft to fit onto the 415 Outdrive? The small steel bit that has the grub screw in it is too big to fit the dog bone part of the universal
Do I require the whole F201 Universal including outdrives?
Lycan
Lycan is offline   Reply With Quote
Old 06-25-2004, 07:39 AM   #2728
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Lycan, i was using a conglomeration of Yokomo cvds when i ran the diff... kind of a pain in the rear. if you catch Suradaj on here, as i remember he was using the F201's drives. the outdrive isnt even close. are the ones you got Tamiya? i wonder how other manufacturers would fit...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-25-2004, 06:24 PM   #2729
Will Tamiya be releasing an OEM part that will end the hassle to convert to full 4wd? I'm just not a big fan of using custom done work or hunting down parts from various manufacturers.
nosNjection is offline   Reply With Quote
Old 06-25-2004, 07:11 PM   #2730
rtypec's Avatar
Yes and no... Tamiya is releasing a locked center pulley set and should be availabe within a couple of months:
Item 53708 TRF415 Direct Center Pulley
As for a front diff, you can either look into getting Jurgen diff halves or piece-meal one from other kits. If you want to run a spool, you can pick up a Speedtech spool or a Jurgen spool.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
