Old 05-19-2004, 02:05 PM   #2191
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by Hebiki
used a C block up front.. flipped an A block upside down..and used 5mm worth of spacers..and it worked great. clearance for the belt was good.
swept the arms back and gave me a ton of steering. didnt have enough time to experiment tho. this was on an indoor high bite asphalt track.
Chris, did you have it last night at SoCal? How did it feel compare to my car?
jeffreylin is offline   Reply With Quote
Old 05-19-2004, 02:12 PM   #2192
Hebiki's Avatar
Trader Rating: 26 (100%+)
yours was more stable.. a little more predictable.. mine was very nervous.. um.. edgy.
one thing i noticed was my car had a lot MORE steering on power also.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-19-2004, 03:11 PM   #2193
over gear's Avatar
Trader Rating: 15 (100%+)
Hebiki: What kind of spacers do you use? I use the left over spacers from the car, they do not sit flat on the flipped A block. Do you have that problem?
over gear is offline   Reply With Quote
Old 05-19-2004, 03:30 PM   #2194
Hebiki's Avatar
Over Gear
i used the same spacers that go on the hinge pins. i used two 3mms and two 2mms. let me know if you need some. i got a TON!
weren't u at socal last night? ill be at socal next tuesday again to race. ill bring some with me if you need em. or am i talking about someone else?
Hebiki Design Works
Old 05-19-2004, 03:58 PM   #2195
jeffreylin's Avatar
That actually sounds great. If anything the car pushes at SoCal. If I can get more steering especially on power I think it's easier to dial out the edginess.
Old 05-19-2004, 04:29 PM   #2196
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
can i get some part numbers
415 suspension blocks
i'm planning to throw them onto my 414mII. will it have any problems
thank you!!!
Calvin Ng is offline   Reply With Quote
Old 05-19-2004, 04:32 PM   #2197
JimmyMac's Avatar
I used a dremel on my A Block when flipped upside down. This lets the shims sit flat. I beleive I used a 3mm and 2mm shim to get it to sit at normal height. For the dremel, it took less than 20 seconds to do. Maybe less than 10 seconds. You just need to lightly grind into the "hump" or part that curves upwards. Very very simple and easy to do. This gives just enough clearance to let the shims sit flat.
Has anyone used a 6 Caster Block with the arms swept back? Just curious. I was gonna try it this weekend. But I don't know if the rain will hold out or not... Rain sucks.... I need asphalt setups... not carpet... Oh well, I can always bring out the Yok if it rains and we go indoors onto the carpet... That or I'll just race 12th scale.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-20-2004, 04:58 PM   #2198
over gear's Avatar
KilRuf: dremel works!
Old 05-20-2004, 05:21 PM   #2199
It was an official practiceday for the upcoming nordic championship today and I spotted a trick drivetrain mod to increase efficency on Steen Graversens car (one of the topdrivers in europe). He had fitted 20T schumacher pulleys on a custommade layshaft coupled with 32T diffpulleys from the 414. To get the required larger spurgear to fit the bulkheads were raised 2 mm. This is similar to what Xray has done to their cars. I will try to get pics of it next weekend at the nordics.
Mr_Orange is offline   Reply With Quote
Old 05-20-2004, 10:04 PM   #2200
Paul_Kultcha's Avatar
Couldn't you just trim a hole or a groove into the chassis where the spur gear fits to make up for bigger spur? It seems more logical to me then raising the bulkheads up 2mm. That would throw off the center of gravity, the roll center, etc.
Thanks for the info that - thats really cool. I assume the middle one way was locked up as well?
Paul_Kultcha is offline   Reply With Quote
Old 05-21-2004, 12:12 AM   #2201
Registered User
Suradaj's Avatar
thank you!!!
MK3(block B) 3454074
MK4(block A) 3454073
MK5(block C) 3454075
Those where the numbers out of my manual. Hope that helps some.
Suradaj is offline   Reply With Quote
Old 05-21-2004, 12:15 AM   #2202
Registered User
Suradaj's Avatar
Opps, sorry, that was for the 414.
For the 415:
51064 bridge
51065 A
51066 B
51067 C
51068 D
51069 X
Old 05-21-2004, 03:54 AM   #2203
i was thinking the same thing but whacking the blocks on my evo3, anyone tried this?
Evo_Uk is offline   Reply With Quote
Old 05-21-2004, 01:25 PM   #2204
Hebiki's Avatar
jeff.. are you racing this weekend? if you want.. lets hook up on saturday and you can help do some more testing with the 415.
Hebiki Design Works
Old 05-21-2004, 02:15 PM   #2205
jeffreylin's Avatar
Yea Chris, I will be going to SoCal on Saturday. I am going to try a few new things myself.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
