Old 05-18-2004, 03:43 PM   #2176
rtypec's Avatar
You'll have to recheck front end settings if you go to a narrower front end. You'll have to check your camber as it might go positive and you'll have to check your toe angles at the wheels as they may toe in on you.
rtypec is offline   Reply With Quote
Old 05-18-2004, 03:45 PM   #2177
linger's Avatar
Originally posted by rtypec
edit: Hey Ling, it was kinda ironic that Beale brought his "racing vehicle dynamics" books with him to the track to point out exactly what's wrong with our toy car setups and logic...but nowhere in the books does it say how to fix it. Typical engineer books that are good at defining but not so good with applying... Oddly enough, one of the books said that front inboard toe out or anything that promotes roll steer, is bad. Go figure
Interesting,
I bet it made no mention about front 1-ways or "spools" either.
Those wacky engineers
linger is offline   Reply With Quote
Old 05-18-2004, 03:48 PM   #2178
but will they give different effects to the car on the track?
Evo_Uk is offline   Reply With Quote
Old 05-18-2004, 03:59 PM   #2179
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by linger
Hey, I beat Rod at posting!!!
At least I get to beat rod at something!
mr ling.. any chance you'll be revising your "funky fresh spring chart" any time soon? if you need samples... let me know. but ill need them back
i have your original spring chart... but some of the tamiya short springs are missing, etc...
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-18-2004, 04:05 PM   #2180
linger's Avatar
yup, definitely.
For example, a chassis with a couple of degrees inboard toe and 0 deg toe at the wheel is more agressive than having 0 inboard toe and 0 toe at the wheel.
Old 05-18-2004, 04:07 PM   #2181
linger's Avatar
Hmm, I thought I got all the short springs?....which springs do you need measured? If you ship them up here, I'll measure them and return them to you at the Reedy Race.
Old 05-18-2004, 04:12 PM   #2182
over gear's Avatar
Trader Rating: 15 (100%+)
How do you make the A block to clear the front belt? flip it upside down?
over gear is offline   Reply With Quote
Old 05-18-2004, 04:45 PM   #2183
Hebiki's Avatar
i think its a hopup... they mentioned it in this thread a few pages back. should be coming out soon.
Hebiki Design Works
Old 05-18-2004, 05:00 PM   #2184
You flip a normal 415 or Evo 3 A Block and use 5 mm spacer to raise it. Surikarn did this at the reedyrace of asia. Pics at: http://www.rczone.net/modules.php?na...rder=0&thold=0
Mr_Orange is offline   Reply With Quote
Old 05-18-2004, 05:12 PM   #2185
Hebiki's Avatar
WOW! thats great. thanks for showing us that! i guess we can just do that then
Hebiki Design Works
Old 05-18-2004, 10:30 PM   #2186
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
what will do this to the car handling?
Windtalkers is offline   Reply With Quote
Old 05-19-2004, 09:45 AM   #2187
tomdav's Avatar
Trader Rating: 42 (100%+)
Default Body post
Anyone know where to find the front body post and bumper kit.
50894 is the part if i remember correctly.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 05-19-2004, 10:46 AM   #2188
fowlerJr68's Avatar
It gives the car more steeting and some kickup.
STeve
fowlerJr68 is offline   Reply With Quote
Old 05-19-2004, 12:31 PM   #2189
over gear's Avatar
I tried it last night on a B block. the spacer cannot sit flat on the block.... Do i have to dremel a flat spot for the spacer?
Old 05-19-2004, 01:12 PM   #2190
Hebiki's Avatar
used a C block up front.. flipped an A block upside down..and used 5mm worth of spacers..and it worked great. clearance for the belt was good.
swept the arms back and gave me a ton of steering. didnt have enough time to experiment tho. this was on an indoor high bite asphalt track.
Hebiki Design Works
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
