Old 05-09-2004, 11:59 AM   #2086
Overgear look back 2 pages or so Rod has his setup for TA. He has quite a bit of changes made to accomodate the spool
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-09-2004, 04:39 PM   #2087
over gear's Avatar
Trader Rating: 15 (100%+)
hmmm.... who is Rod?
over gear is offline   Reply With Quote
Old 05-09-2004, 05:07 PM   #2088
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Talking
Here you go.....http://www.rctech.net/forum/attachme...&postid=853986
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 05-09-2004, 05:07 PM   #2089
Posts here as rtypec
Old 05-09-2004, 07:34 PM   #2090
rtypec's Avatar
What's up Diff-abuser? Had another session with the 415 yesterday. I played with rear toe angles and I didn't like anything below 2.5 degrees. I tried 2.0 and even 1.5, but the car felt very washy, really bad in the dogleg hehe.
I broke my first 415 part yesterday as well, I stripped the rear belt clean of all it's teeth. wOOt!
rtypec is offline   Reply With Quote
Old 05-09-2004, 09:08 PM   #2091
TJ
TJ's Avatar
How did you do that????
Castle Hill Raceway: www.castlehillraceway.com
Facebook: https://www.facebook.com/groups/121817254587521/
"Anything I say can or will be used against me at a later date":
TJ is offline   Reply With Quote
Old 05-10-2004, 03:54 AM   #2092
Holmenkollen's Avatar
Anyone got the setup that Ben Cosgrove used to win in England?
Holmenkollen is offline   Reply With Quote
Old 05-10-2004, 06:13 AM   #2093
Albino2000's Avatar
Setup help needed.
Just got back from the Tamiya track for 4WD testing...
The car feels pushy and roll a lot like a boat... it feels like it stop at the mid corner. when i try to push harder, the car will sometime push, sometime oversteer... not very predictable... feels like it has a mind of its own..
What should I do to take away the push, yet being stable?
My setup is:
Front: white spring, 40wt oil. Speedtech spool. Takeoff27 tires.
Rear: blue spring, 40wt oil, Evo3 1deg rear hub, B/D suspension braces, Takeoff 27 tires.
everything else is stock setting....
i'm running a Reedy 19T, gear 78/29.
Hi guys!
Well, thats the same Problem a friend had day ago. I gave him this setup and it runs much better:
Front:
-60wt oil
-3 holes
-Associated Gold Spring
-Point 2 on the shock tower
-(VERY IMPORTANT) A-Blocks
- -1,5
Rear:
-50wt
-3holes
-Point 4 on the shock tower
-A-Block and B-Block and A-Block behind the motor
- -1,5
Thats it!
I hope I can help you. Let me know if it work's!
Regards
Manuel
Albino2000 is offline   Reply With Quote
Old 05-10-2004, 06:17 AM   #2094
Yes he sent me a pic of it, i will post it later. Rick
Rick Draper is offline   Reply With Quote
Old 05-10-2004, 08:32 AM   #2095
Rod sounds about the same here my rear belt is holding up but the front has got a few skips here and there. It shows up on heavy braking with the spool.
Toe is about the same. Did you holler at Fred to ship up a A bridge?
D
Old 05-10-2004, 09:10 AM   #2096
over gear's Avatar
rtypec: seems like you are setting up for the Reedy race
how many clicks of belt tension do u use? i have belt skip with a 19T. i can imagine a 8T!
Old 05-10-2004, 09:11 AM   #2097
over gear's Avatar
seems like there is an interest for the A bridge. what is it good for?
Old 05-10-2004, 10:02 AM   #2098
rtypec's Avatar
I've been running my belt at 2 clicks f/r for a long while up until I started running some low winds. Then they started skipping so I went to 3 f/r but the belts were already showing a lot of wear so it was natural that they'd give up the ghost.
Next rebuild with new belts, I'll start with 3 f/r and go from there.
Old 05-10-2004, 11:47 AM   #2099
rcspeedo's Avatar
Same here, I started off with 2 clicks f/r, feels ok in 19t but when I started running mod you can definitely feel the skip, specially from a dead stop. Adjusted it to 3 clicks. I am assuming that the belt might have more stress on a spool, specially the front belt.
Dan d'man - you coming up for the Cloverdale race? Should be lots of fun.
rcspeedo is offline   Reply With Quote
Old 05-10-2004, 11:55 AM   #2100
jeffreylin's Avatar
R/C Tech Charter Subscriber
I've only used the car for stock so I run it pretty lose. I have 0 in front and 1 in the back. The drivetrain is so free I can spin it for few seconds like a shaft car!
jeffreylin is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
