Old 11-06-2009, 10:13 PM   #20716
Hello guys,
I have been away from racing for the last 3 seasons and thinking of running again after the new year. I seen a lot of changes happened to carpet in brushless and Lipos for batteries.
I have a TRF415 original with MSX upgrades and a TRF415 MSX WRE.
Are you guys able to run a hard case Lipo pack in these at all? I am thinking of going with the Reedy #709 35C 5000mAh 7.4 pack.
I would appreciate any responses on this or anything on the brushless to look out for for fitment on these cars. Thanks,
John
190mph is offline   Reply With Quote
Old 11-07-2009, 04:03 PM   #20717
haywood's Avatar
Trader Rating: 49 (100%+)
Originally Posted by 190mph View Post
Hello guys,
John
I don't believe that pack will fit.I have a 415msx and I had to dremel the bulkhead to accomadate the smaller 3800 30c Orion's.Otherwise you could run the Reedy but you would have to hang the pack over the side of the
chassis with a lipo-tray.The Orion pack works great for me and I can just tape it in just like a nihm pack.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 11-09-2009, 04:44 PM   #20718
94eg!'s Avatar
Trader Rating: 17 (100%+)
The biggest I could get was an IP 3800mah 35C pack w/ bullet connectors. I had to remove all the decals from the lipo and file the cell slots a little extra to make sure it sat pefectly flat on the chassis. Then I had to file the hell out of the right bulkhead in 3 spots and underside of the center post. You will need a little room between the pack and the bulkheads cause of chassis flex. I also had to shave the bottom side of the upper deck at an angle to allow the ESC/battery wires to come through below the top deck. I didn't want them above.
This pic shows where to file:
94eg! is offline   Reply With Quote
Old 11-09-2009, 11:47 PM   #20719
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
haywood. no more trf banner.. lol....
got any asphalt set up?
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 11-10-2009, 05:01 PM   #20720
pinggoy's Avatar
need to know where i can buy front spool and center spool..... cant find any instock... also do i need the center direct coupling when using spool?
thanx
TAMIYA TRF416X
Old 11-11-2009, 04:52 AM   #20721
Skitee's Avatar
Center Spool and Center Direct Coupling are the same thing.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 11-11-2009, 10:00 AM   #20722
tc3team's Avatar
can anyone tell me what size the diff balls are in the msxx please? (probably the same as the MRE) as i might try to source some non tamiya ones locally.
also, how often do you guys change the thrust races? I know that greasing them is critical for their lifespan.
ty!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-11-2009, 10:20 AM   #20723
SammyZ's Avatar
Trader Rating: 138 (100%+)
ty!
415MSXX diff balls are 3mm and there are only 8 of them.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 11-12-2009, 02:31 AM   #20724
tc3team's Avatar
Thanks, I managed to get some locally
Old 11-15-2009, 10:31 AM   #20725
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Anybody racing on carpet, I have the 4mm chassis part number #1011 new in bag for sale. please pm me if interested.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 11-16-2009, 08:31 PM   #20726
pinggoy's Avatar
new to tamiya cars..need help with the suspension mounts..how many degress would each mount produce?
1xD
1XC
1XB
1XA
1X
1A
1B
1C
1D
1E
1F
TAMIYA TRF416X
Old 11-16-2009, 09:02 PM   #20727
94eg!'s Avatar
1xD
1XC
1XB
1XA
1X
1A
1B
1C
1D
1E
1F
You have them in order of narrowest to widest.
For each step they are spread apart, there is a ~.5* change in toe.
Examples:
1A & 1B = .5*
1A & 1C = 1*
1XA & 1F = 3.5*
1C & 1C = 0*
etc...
Old 11-16-2009, 09:17 PM   #20728
pinggoy's Avatar
cool thanx... that helps out...
so i can also play around with the trackwith too by choosing the right combination... ..
TAMIYA TRF416X
Old 11-22-2009, 11:51 AM   #20729
Thanks haywood and 94eg! for the info on Lipo fitment. I will order the BittyDesign lipo tray and I actually pre-ordered a 416X from Speedtech RC.
But I will run the 415 with 4mm chassis for foam and the 416X for rubber.
I wonder how much a mint never run TRF415 MSX MRE would be going for? Maybe I will sell that to reduce the cost of the 416X upgrade.
Old 12-03-2009, 11:17 AM   #20730
asw7576's Avatar
Originally Posted by Nexus View Post
Here's what I put together awhile back but took the website down...
Parts Needed:
Yokomo ZS-501 Diff Halves or ZS-502S for steel outdrives
Yokomo ZS-506 Diff Rings or Tamiya 50880 TA04 Ball Diff Plate Set
Yokomo ZS-507 Thrust Balls and Washers
Yokomo ZS-508 Diff Screw and Locknut
Yokomo ZC-S100 10.0mm spacer shim set
Tamiya 51055 TRF415 Ball Diff Pulley
Tamiya 53379 3mm Lightweight Diff Balls
2qty Tamiya 53030 Ball Bearings ( 850 )
2qty Tamiya 53126 Ball Bearings ( 1510 )
I'll have the actual website up and running again soon. Some people on this thread might remember I had parts and pics of everything needed and almost step by step on how to put the diff together.
Thanks Nexus .... I did it .... my MSX finally got front ball diffs she deserved.
I use white TA05 ball diff pulley ( 36T ) instead of black 415 MSX ball diff pulley ( 35T ). I have to replaced rear diff pulley as well to make it even with front, 36T.
Cheers ....
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
