Old 09-23-2009, 12:06 PM   #20701
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by msxmre View Post
No m8 that's the spool in the pic. You only ever run a diff in the rear and a spool, diff or one way in the front.
That's not why it won't work though (rear spool is a common drift setup). It won't work becuase it will put the pulley in the center. The rear pulley on the 415MSX+ is offset. It might work if you mount the pulley on the wrong side and shim it to make the belt run straight...
94eg! is offline   Reply With Quote
Old 10-04-2009, 04:11 PM   #20702
Ok little help needed. I picked up a clean MSX and going to use it for RCGT, what I was wondering is, does anyone know if a aluminum C hub is made for this car? Is there one available for the TB or TA05 that will fit? Any help will be appreciated.
boyntoncyclone is offline   Reply With Quote
Old 10-08-2009, 09:56 AM   #20703
speedzer's Avatar
Hi
wish you guys can help mi out.
Does the 37t pulley from trf416 fits onto my trf415 msxx mre original front spool and rear diff ?
If I changed my pulley to 37t with center pulley 18t, do I need to change the belts ? If so, which belts do I need to chabge.
A millions thx to u guys first.
Team UnderGround
Yokomo DPM 1.5CS | HobbyWing Xerun 120A | HobbyWing 8.5T motor | Sanwa WRX servo | KoproPo EX10 Helios Spektrum
speedzer is offline   Reply With Quote
Old 10-09-2009, 10:46 PM   #20704
f1larry's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to f1larry
Need a spool for my TRF 415
Does anyone know of a spool for the TRF 415. If so what is the part number? I would prefer a Tamiya 1 to stay TCS legal. Does the one from the 415msx work on the original 415.
Thanks,
Larry
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is online now   Reply With Quote
Old 10-10-2009, 08:35 AM   #20705
Yes the spool from the MXS will work, but you also have to get the direct drive pulley for the layshaft. I dont have PNs handy but will post it later.
Old 10-11-2009, 08:23 AM   #20706
The PN for the direct drive pulley is 53708
Ok asking again, does anyone know of a set of aluminum c hubs that are made for this car, or will c hubs from a TA05 work?
Old 10-25-2009, 09:13 AM   #20707
Trader Rating: 70 (100%+)
Hello guys,
I just got a really good deal on a TRF415 and I will like to use it for RCGT class. My question is can I run 6 cell stick packs on this chassis?? Do I need to buy anything so I can fit them?? I know that on my EVO 3 you can run stick packs but not sure if I can on the 415.. Thanks in advance
Leo
lnc0321 is offline   Reply With Quote
Old 10-25-2009, 06:17 PM   #20708
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
Originally Posted by lnc0321 View Post
Hello guys,
Leo
Hey.
i guess u could run stick pack with the original chassis but would require a fair bit of taping the pack to the chassis. However there is a conversion for the 415 to fit stick packs.
http://www.tamiyausa.com/product/ite...oduct-id=49385
mild seven is offline   Reply With Quote
Old 10-26-2009, 03:44 AM   #20709
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default carpet
hi guys.
i am currently running a 415 MSXX MRE 2007 (42104) on carpet. could someone help me with a good rubber carpet setup?? i am running the short arms btw. seems like for this car nobody has any setup sheets whatsoever
vitomon is offline   Reply With Quote
Old 10-26-2009, 06:40 AM   #20710
tc3team's Avatar
Originally Posted by vitomon View Post
hi guys.
should be a few here if you click on the link at the bottom...
http://www.thard.co.uk/415/setups/
hth
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-30-2009, 10:32 AM   #20711
94eg!'s Avatar
hth
Those setups are so old. Not even one for the MSXX, let alone short suspension arms...
If your using short arms, just go with the more modern 416 setups. The base setups in the Jilles Groskamp thread should point you in the right direction...
Old 11-02-2009, 05:40 AM   #20712
thx guys.. i have now tried several setups incl the 416 ones. the car
is still way out of control with the xenon tires. cant figure it out. seems like
there is something broke but havent found it yet.
edit:
i was shortly changing to the short arms (53928) on my MSXX MRE 2007 (42104).
i am running CC blocks in front, which should give me no trouble with the 46 mm shafts.
i am a little worried about the rear. in the rear i am currently running XA - E (new 416 blocks) and also 46mm shafts. any experience on that?? do i have to change to 44 mm in the rear??
thx for the help!!
Old 11-04-2009, 03:46 AM   #20713
tudor_47's Avatar
Default Is there a gearing chart out somewere for the 415?
Hi
I am in need of a geraing chart for the TRF415MSX...
what total gearing is it if i put in pinioin this and spur that?
thanks!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 11-04-2009, 08:34 PM   #20714
94eg!'s Avatar
Originally Posted by tudor_47 View Post
Hi
thanks!
The gear charts can be found inside the manuals. The manuals can be downloaded on TamiyaUSA.com. Simply look up the kit (via part number) and there will be a link in the upper right corner to download the manual...
BTW: Kit spur gear is 102T 0.4module (similar to 64pitch)
Old 11-05-2009, 03:37 AM   #20715
tudor_47's Avatar
thanks!
It was too easy, I never thought of the manual!
/johnny
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
