Old 07-23-2009, 07:42 AM   #20656
Originally Posted by Blueman Austria View Post
Hy everyone !
Wanted to share with you my mod on my 415MSXXMRE07, on the steering system.
Orderd a spare set of steering posts, cutted and sanded them into the right shape, and connected them with a carbon bar of my old Evo5 lower deck.
Take a look!
Attachment 479680
Attachment 479681
Greetz Blueman
Hey
Nice job
What is advantage with that new steering system vs old one?
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 07-23-2009, 08:21 AM   #20657
tc3team's Avatar
Originally Posted by Cruisaaja View Post
Hey
Nice job
I cannot be sure, but it looks like it makes it stronger/more responsive and with less play in it.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-26-2009, 12:14 AM   #20658
Blueman Austria's Avatar
Compared to the normal steering systems the car flex is a bit higher.
Quite similar to the 416 without the steering post screw.
I test the car next WE on a race meeting here in Austria.
Dont know if there will be a improvement in laptimes, but in my opinion there is a improvment of the look of the car
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 07-27-2009, 09:28 PM   #20659
haywood's Avatar
Trader Rating: 49 (100%+)
Default VTA SETUP
Does anyone have a solid setup for the 415 in the VTA class?Thanks
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-28-2009, 02:42 AM   #20660
tc3team's Avatar
Greetz Blueman
I have the 415msxx (not the mre) and get jealous when I see the 416, so I think on that theory, I am already 2/10ths a lap slower!!!
Old 08-02-2009, 07:48 AM   #20661
cheehtae's Avatar
Trader Rating: 15 (100%+)
anybody knows where to buy a fan for the msx? or have a picture of it?
cheehtae is offline   Reply With Quote
Old 08-02-2009, 10:22 AM   #20662
Asphalt or carpet?
For both:
  • Red springs / 55wt. oil on front
  • Yellow springs / 45 wt. oil (this is a taste thing, 45 wt. - 55 wt. depending) on back
  • Fixed center layshaft (no center one-way)
For asphalt:
I'm usually fighting nasty on-power understeer on asphalt
  • Front shocks laid all the way down
  • 0.5 deg front camber
  • 1 deg front toe-out
  • Stand up rear shocks depending on grip levels
For carpet:
Car works pretty well on rug
  • Front shocks 3rd hole in from outside
  • 0 deg front camber
  • 0.5 deg front toe-out
  • Rear shocks 2nd hole from outside
I don't actually have the setup sheets in front of me right now so I'm punting a bit, but these should be good enough to get started. Please report back with improvements!
BNiels707 is offline   Reply With Quote
Old 08-02-2009, 05:28 PM   #20663
STLNLST's Avatar
Trader Rating: 21 (100%+)
If anyone is looking for a 415 I finally got all the pics of mine taken.
http://www.rctech.net/forum/r-c-item...re-x-tras.html
STLNLST is offline   Reply With Quote
Old 08-02-2009, 09:37 PM   #20664
JimmyMac's Avatar
What up guys! If I replace my 16t pulleys to 18t pulleys on my MRE, but keep my diff pulleys the same (36t?) what belts do I need to run? Thanks.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-02-2009, 09:44 PM   #20665
haywood's Avatar
Default 415
I am looking for a carpet set-up
Old 08-03-2009, 12:14 AM   #20666
Skitee's Avatar
Cyclone front belt and T2, T2'007 rear belt
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-03-2009, 12:48 AM   #20667
JimmyMac's Avatar
Cool thanks! I just happen to have some cyclone belts laying around, just gotta see if I have any T2 belts laying around.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-04-2009, 06:17 PM   #20668
haywood's Avatar
Default TRF 415
Can anyone give me a source stateside that would have 415 rear uprights and also I am looking for the larger 7mm hex adapters so I can run larger 28mm tires.Thanks for any help.
Old 08-04-2009, 07:01 PM   #20669
JimmyMac's Avatar
Are you looking for plastic or aluminum rear uprights? Also, are you talking about the 6mm wheel hexes? I did not know they made a 7mm wheel hex. I'll have to look around after midnight, I should be finished with my exams by then.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-04-2009, 08:15 PM   #20670
haywood's Avatar
Default Wheel Hex
RCMODEL has Tuneup 7mm hexes available.I was looking for alum. rear uprights.Thanks.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
