Old 07-16-2009, 02:04 PM   #20641
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by sidecarphil1 View Post
what does front sweep do to the car ??
It's almost identical to altering wheelbase with the spacers on the lower hinge-pin, except that it also provides some dynamic effect (that I'm not aware of) while the suspension moves up and down.
94eg! is offline   Reply With Quote
Old 07-16-2009, 05:15 PM   #20642
haywood's Avatar
Trader Rating: 49 (100%+)
Guys,Do you know if the 3200 thunder power 40c pack will clear the bulkhead in a 415MS? Also are the suspension blocks the same for the 415 and 416?Thanks.One more question I need to replace the belts on my 415,will all 415 model belts fit on the 415 and will 416 belts fit in cause they are easier to find.If you know the part numbers that would be great also.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-17-2009, 12:54 AM   #20643
Skitee's Avatar
Yes the 415MS has plenty of space to fit LiPo's, the clearance between the top and bottom decks is enough for most if not all hard cased LiPo's.
The TRF415 and TRF416 suspension blocks are interchangeable.
All 415 belts fit between the different versions
51062 TRF415 Front Belt
51063 TRF415 Rear Belt
53706 TRF415 Low Friction Front Belt (White) not for mod racing
53707 TRF415 Low Friction Rear Belt (White) not for mod racing
6245013 TRF415 MSX Front Belt
6245014 TRF415 MSX Rear Belt
TRF416 belts don't fit the TRF415, 416 front belt is 3 teeth (9mm) longer and the 416 rear belt is 1 tooth (3mm) shorter.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-19-2009, 12:32 PM   #20644
haywood's Avatar
Thanks for the help,Does anyone know where I could find the rear uprights for a 415?part number?Thanks again
Old 07-19-2009, 03:55 PM   #20645
TryHard's Avatar
http://www.thard.co.uk/viewtopic.php...arm+sweep#p259
It's (unsuprisingly) quite complex.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-20-2009, 09:23 AM   #20646
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Haywood,
Here is a link to all the manuals.
http://www.tamiya.com/japan/download/rc_index.htm
You can try speedtech, that would be my first place to look.
tamiyarcracer is offline   Reply With Quote
Old 07-20-2009, 08:34 PM   #20647
Anyone converted the TRF415MSX-MRE to Center oneway, i got a stick pack conversion for MSXX and converted my car to fully a MSXX and now thought of getting the centre oneway for my 10.5R, i bought the center bearing yesterday and realise i need more stuff
Can anyone guide me wat to get? and is it worth converting? I am running front oneway now.
hoppie is offline   Reply With Quote
Old 07-20-2009, 09:56 PM   #20648
I installed the ta05 37T pulleys for the spool and diff. I'm still running the stock center pulley. I was wondering what my new IR is for figuring out my FDR.
Thanks!
home13oy75 is offline   Reply With Quote
Old 07-20-2009, 10:32 PM   #20649
94eg!'s Avatar
You will need all the parts from the MSXX kit. Check the instructions for the kit by looking up the MSXX on TamiyaUSA.com. That will explain everything.
You need the center shaft, spur holder, and all kinds of spacers and other junk. Not an easy changeover...
Old 07-21-2009, 02:56 AM   #20650
Skitee's Avatar
Thanks!
Your IR is 2.3125
IR is diff pulley divided by center pulley
Old 07-22-2009, 12:14 AM   #20651
chrisk's Avatar
Trader Rating: 32 (100%+)
I currently run the 37T pulleys
I want to run the 18T centre pulley and have read about teh conversion on THARD
but that is for a fixed centre pulley
Can i run a 18T on a centre One-way?
Has anybody converted a ONe-way to suit a 18T pulley?
Cheers
Chris
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 07-22-2009, 12:19 AM   #20652
Skitee's Avatar
I don't know if either of these would work but you could try the Porsche 934 center one-way and just replace the 16t pulleys with 18t or you can try the IFS-R center one-way.
Old 07-22-2009, 08:26 PM   #20653
I was wondering what lipo tray is everyone using other than the bitty design
Old 07-22-2009, 11:42 PM   #20654
Blueman Austria's Avatar
Default 415MSXX Steering Modd
Hy everyone !
Wanted to share with you my mod on my 415MSXXMRE07, on the steering system.
Orderd a spare set of steering posts, cutted and sanded them into the right shape, and connected them with a carbon bar of my old Evo5 lower deck.
Take a look!
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 07-23-2009, 07:36 AM   #20655
Hey there
Homemade tray is cheapest i think
I made my lipo tray from 2mm aluminium plate and i`m pleased with it.
As i remember wright weight is 46g so it is light too
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
